Question about Nikon Coolpix S203 Digital Camera
My S203 camera's lens is in the open position and with the battery in it continually makes clicking noises
    Brigadier General:
  • 3,006 Answers
Your camera almost certainly has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Nikon service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the memory card as it can be used in other devices. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome.
Posted on Mar 17, 2011
Clicking noise from extended camera lens on Nikon camera
fixit or junk it
the clicking is the plastic gears jumping over each other
Apr 25, 2017 | Nikon Coolpix S8100 Gold Digital Camera...
How do I fix a Lens error on a Nikkon s203
Go to this website for possible solutions:
Oct 25, 2011 | Nikon Coolpix S203 Digital Camera
Keep getting lens error on my s203 what do i do
Your lens could possible be stuck from opening. Check to see that the lens casing is clean and free from stickiness :)
Jun 21, 2011 | Nikon Coolpix S203 Digital Camera
My Nikon Coolpix S203 has a "lens error". Every time I turn on the camera, then lens goes crazy, moving in and out and zooming in and out of focus, all the while making a beeping noise. It then...
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Dec 04, 2010 | Nikon Coolpix S203 Digital Camera
Clicking noise when it turns on and won't focus, lens error also
What you are describing is probably the beginning of a possible lens error. If the camera still operates correctly (the lens extends correctly, you can still take photos that are correctly focused) then there may be sand or dirt in the lens mechanism that will eventually cause a failure. Just as an initial step, get a can of compressed air and blow out the space between the lens barrel and the camera body. If the clicking noises continue and the lens movement is not smooth, it is time to contact Nikon support at the link below
http://www.nikonusa.com/Find-Your-Nikon/Product/Digital-Camera/26156/COOLPIX-S630.html
If, and only if my answer to your question is helpful, please rate my solution and leave a Positive Feedback.
May 31, 2010 | Nikon COOLPIX L20 Digital Camera
Camera won't turn on. It just makes clicking noise.
After i replace standard alkalines with rechargeable NiMH batteries Sony 2700 Ni-MH or Varta 2700 Ni-MH it's was working!
My camera it's working now!
Jul 18, 2009 | Fuji FinePix A850 Digital Camera
Lens is stuck in the open position and when i try and turn on the camera, it makes a clicking sound and displays a LENS ERROR message
lens is stuck inthe open position and displays a lens error message and when I try turn on camera ,it makes a clicking sound
Jul 06, 2009 | Casio Exilim EX-S600 Digital Camera
Kodak EasyShare lens makes clicking noises
try going into the menu 8 clicks down onto theaf control,and make sure its on single AF ,not continuous,as if its on continuous it will keep trying to stay in focus,if this dosent solv it its probabley a faulty lens
Jan 08, 2009 | Kodak EasyShare V1003 Digital Camera
The lens on my Olympus m760 camera is stuck in its out position. Even When i turn my camera off or take the battery out, the lens stays fully zoomed out and makes a funny noise like its tyring to retract....
this is probably caused due to a fall or so.. try to technically have a 360 look at the sides of the lens were at one instant u will notice a slight droop.. now u have to carefully push the lens in carefully with **** like motion for which a click noise will be heard... and will go back in...
Sep 16, 2008 | Olympus Cameras
Nikon Coolpix S203 Digital Camera Logo
89 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
