Question about Panasonic TH42PX60WALL 42 in. Plasma Television
TV shutting down automatically after a minute
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 17, 2011
Tv timer shuts off
If the TV gets very hot it maybe shutting down on its own accord however there should be a way to navigate to the sleep menu through the buttons on the front of the set.
Feb 19, 2013 | Samsung Televison & Video
Tv will shut off after 30 minutes- sony brand
try cleaning the filter. sometimes when the filter is dirty it heats up fast and shuts the TV down.
This is because the video ic is heated up and automatically shuts down to prevent overheating.
G
Jun 06, 2011 | Sony KP-57WS500 57" Rear Projection...
My tv shuts off after only two minutes
try using a master reset to fix this.
Sometimes after being used for awhile electronics tend to malfunction.
press and hold these buttons in this order....
power / volume up / channel down.
The tv should shut off after doing this.
Turn it back on manually.
This will reset the TVs internal memory chip.
I dont guarentee this as a permanent fix....but it worked for me.Good luck
Sep 19, 2009 | Sansui DTV2760 27" TV
I also have this TV but mine will not power on at all. Did you ever find a solution?
Max.
Jun 25, 2009 | LG MU-60PZ10 60 in. Plasma Television
Turns on and off automatically
getting hot and shutting down try to clean it out could be very dusty inside
Jun 21, 2009 | Gateway GTW-P42M303 42 in. Plasma...
IBM 2647 -41U automatic shut down
How old is your computer??? is it getting overheated?..what operating system did it have before xp? does it give you any messages before shutting down?
let me know
Apr 10, 2009 | IBM ThinkPad T20 2647 Notebook
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
KP-51HW40 - Auto shut down problem
I had the same problem. i was told by one of these so-called experts @ fixya that my flyback transformer needed to be replaced (the 8 blinks on the standby was the indicator). but i recently replaced it and im having the same problem. sorry. no advice. good luck.
Jun 18, 2008 | Sony KP-51HW40 51" Rear Projection...
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Panasonic TH42PX60WALL 42 in. Plasma Television Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
