Question about Pentair Pool & Spa
I have a 2 year old pentair whisperflo wfds-28 2hp part 7 177456-03 that works fine on low speed but only humms loudly when trying to go on high speed. Is there a capacitor or something that has gone bad? Thank you, JOE WARD
    Top Expert:
  • Pentair Master
  • 8,673 Answers
Possible 2 speed relay
Posted on May 08, 2016
SOURCE: pentair whisperflo pool pump motor replacement
No there is a cover on the other side of the motor thet comes off and with a 9/16 wrench holding the shaft - spin the impeller off
Posted on Jun 28, 2009
  • 990 Answers
SOURCE: my pentair whisperflo is making a load squealing
When you have noise in the pump it is usually a rumbel or rattel. If you have a squealing it is probally in your motor and is more than likly a bad bearing. If you have any water leaking at your seal this is probally the problem and it will just get worse. Sorry to say you are very close to a new motor.
Posted on Dec 07, 2009
heatman101
  • 43501 Answers
SOURCE: What are the specifications for
Take the cover off of the capacitor...it is the bump on the top of the motor...then look on the capacitor and find the numbers that end with mfd. that is the size or rating of the capacitor...also then look for the voltage of the capacitior...you need to match that also...there are so many different motors used, even for the same pump that it is hard to say for sure what you may need there with out looking at it.
You can do that and then you know you are getting the correct cap for your motor...
My guess is that you are looking for something in the range of a 20mfd 370volt cap. but please check it out for sure they vary alot!!
heatman101
Posted on Aug 28, 2010
jandjsay
  • 25 Answers
SOURCE: How do you replace an impeller on a 1.0 hp Pentair
Remove the bolts that hold the 'wet end' of the pump to the 'dry end'. If the impeller is held on with a screw, it is a 'left-hand' tighten which means it turns the opposite way of normal screws. Be careful not to damage the impeller. Any scoring on it will effect its performance and it will only be worth doing if everything goes back together cleanly and properly. Replace and lube all O-rings with silicone lube. Make sure all bolts are tightened and do them in an alternating fashion to ensure that you get a good seal.
www.cpo2go.com
Posted on Dec 03, 2010
UglyPoolGuy
  • 46 Answers
SOURCE: My Pentair Whisperflo pump is
Inside the pump is a set of bearings that help the components of the motor run smoothly. When they become clogged with dirt and debris or wear down, your pool pump may get very noisy or stop working altogether. This high pitched squealing you are hearing is fairly consistent with bearing failure.
t might be best to have the motor seperated from the pump housing and take it to your local pool outlet or motor shop. Installation of the bearings will be a breeze for them and make sure that no damage is done to the shaft of while the new bearings are being installed. At this time, they can also inspect the motor and make sure that there are no other problems with the pool motor.
Also, you should ALWAYS, ALWAYS, ALWAYS replace the shaft seal whenever you take the pool pump motor apart. This will ensure a positive seal for the motor and minimize the opportunity for leaks to occur.
Replacing the bearings in your pool motor:
1. Turn off power to your pool pump by unplugging it from the power source or by turning off the circuit breaker. 2 Remove the plumbing from the pump. Take off the unions on the suction and discharge side using a wrench. Loosen the pool pump from the fitting holding it to the ground and move it to a comfortable area to work in. 3 Remove the housing from the pool pump and separate it from the motor. Look at the owner's manual for your pump to see the specifics on how to remove the pool pump housing, since each model is different. Usually you will need to loosen a bolt with a socket wrench and loosen the metal band that holds it in place. 4 Remove the four bolts that hold the pump together. These are located on the hand bell of the frame. Remove the motor end bells. 5 Pull out the motor armature to expose the ball bearings. Insert your ball bearing puller to pull out the old ball bearings. Inspect them for damage. Replace the old ball bearings with new ones after greasing them with bearing grease, and reassemble the pump.
To be honest with you, I don't even let our technicians replace the bearings in the field anymore. It is a little difficult and really, how many people have a "ball bearing puller" laying around their house.
*Please note, this should ONLY be attempted if you are comfortable with the instructions and taking apart the pump, have the necessary parts and tools to make the repair, and are familiar with ensuring that everything is back together properly!
Please take a moment to let me know if this answered your problem or not! All of us here a Fix Ya do our best to help each person with their questions, and we know that we may not always be "perfect", but we do try!
The Ugly Pool Guy www.WeFixUglyPools.com
Posted on Dec 15, 2010
My Pentair pump is just 2 years old and it was working good yesterday I turned off I turned it on in now it humms for a minute or 2 then it just turns off completely how do I fix this
motors that hum indicate 2 things
seized pump or failed start /run capacitor
as it was running recently I would be checking the capacitor
the stopping altogether may be the thermal overload switch cutting in because of the high current draw from the failed capacitor
Jun 05, 2016 | Pentair 2.0 Hp Whisperflo Pump
Turned off breaker and pump will not come back on. Not start capacitor
might be a bad breaker, test power at motor you should have about 220v on the line 1 and 2 terminals if the motor is set to run on, there is a daigram on the side of the motor for refrance
Jan 07, 2015 | Pentair 011773 WhisperFlo WF-26 High...
Lost high pressure to spa jets. Pump running , gauge on sand filter shows 30psi ?
backwash and try again if sand is over 3 years old replace but try on recirculate if ok you have a filter problem that I told you about if still no pressure see if impeller is plugged
Apr 22, 2013 | Pentair 1.0 Hp Whisperflo Pump
Pentair WhisperFlo 1hp, 230v, Dual Speed won't start in morning
If the high speed side of a two speed pump will not operate it is because there is a problem with the windings on the high side of the motor.
You will need to either take it to a motor shop and have them fix it or replace the complete motor.
RodUS Parts Center888-521-6813
Feb 27, 2013 | Pentair Dual Speed 1hp Full Rated 230v 60...
My 3 year old pool pump whisperflo is running a louder. What do I need to check?
Loud operation is an indication that the bearings need replacing. A local small motor repair shop can probably get it done for $70 or less. Call around...
Apr 18, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Pentair 2 speed pump will not go on high speed jandy system indicates on high but pump remains on low
check to confirm jandy system is wired for high. if all wiring is correct you could have bad hi speed windings.
david
Apr 24, 2009 | Pentair 2.0 Hp Whisperflo Pump
Pool & Spa Logo
350 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
