Question about Dell Computers & Internet
My computer's DVD drive does not work. Also There's no sound! The computer is DELL VOSTRO 220.
  • Dell Master
  • 27,725 Answers
Make sure that the dvd is getting enough power test all leads that are attached to the dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Mar 17, 2011
  • Brian Sullivan
    Brian Sullivan Mar 17, 2011
    if your computer came with a motherboard disc the sound drivers could be on it
    click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
    click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
    (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
    also
    click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
    if his does not fix the problem
    have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices to expand,system speaker right click properties then select use this device (enable) also you might check
    the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
    try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
    hope this helps
How to eject dvd tray on vostro 220 dell computer? There is no dvd drive and no button on dvd rom
Is there a small pin hole on the DVD door? use a paperclip and press until the tray opens
Jan 23, 2018 | Dell Computers & Internet
Tip
Dell vostros 220 cd/dvd drive not working
my cd/dvd drive quit working device manager showed the triangle and ! mark, properties showed code 10. shut power off, took side case off, unpluged both cd/dvd's, from the board, restarted machine let it reboot, shut power off again,plugged both cd/dvd's back in, restarted machine, both were reinstalled and now working. hopes this is some help to somebody else. thanks jim.
on Jun 22, 2011 | Dell Vostro 220 Desktop Computer
Is rge sb0410 compatible with vostro 220
It is not an option as the specs do show any free slots.
It also has Integrated 5.1 Channel Audio HD built-in.
See Dell site. Vostro 220 Mini Tower Desktop
Mar 02, 2015 | Dell Vostro 220 PC Desktop
Why amber light stays on dell vostro 220 computer
Is it the light that is used to show that the HD is working? Where on the tower is this light found?
Jun 30, 2014 | Dell Vostro 220 Desktop Computer
How do I print in color from Dell vostro 220 to HP Deskjet 6940 printer
1. Check if the printer has colored ink.
2. Check the settings. Make sure that the colored ink is activated.
3. Update the driver for your printer. Scan your computer with RadarSync.
Let me know if you have any questions.
David
Apr 08, 2013 | Dell Vostro 220 Desktop Computer
From time to time Dell Vostro 220 freezes, starts to create a high pitched noise and the screen starts to show everything all messed up.
you need to run a virus scan it sounds as though you have gotten a virus if that isent the problem then try restoring the computer with your restore disc
Jul 08, 2011 | Dell Vostro 220 Desktop Computer
Have a Dell Vostro 220a with a DVD/CD-RW but it won't recognise most of my CDs. It recognizes some but not most. It will make sounds like its trying to read them then nothing....
If the drive was working before normally then the lens of the drive has started to Mal-function. please contact the manufacturer if the product still has warranty.
Dec 24, 2010 | Dell Vostro 220 PC Desktop
Does the Dell Vostro 220 have built in speakers and if so how do I activate them?
No the desktop doesn't have internal speakers. Connect external speakers to the Line Out (green audio jack) for basic computer headphones and speakers with an integrated amplifier. See the manual for directions on setting up surround sound systems. http://support.dell.com/support/edocs/systems/vos220/en/index.htm Make sure the speakers are on and have power, if needed.
I hope this helps.
Sep 23, 2010 | Dell Vostro 220 Desktop Computer
Dvd will not eject from slot drive of dell vostro 1510
Restart your computer and enter set up bios. Try ejecting your dvd rom from there... it that doesn't work, get a pin and insert it in the pinhole on the dvdrom whuile pressing the eject button... that should do the trick!
May 24, 2010 | Dell Vostro 1510 Laptop
Vostro 220 with vista boots but screen is black. The mouse moves around but nothing works In safe mode the mouse icon is on the screen but does not move and screen is black. I repair mode it can't fix...
Re install Operating System (Vista)
place the disc Vista DVD in cd/dvd player. Restart your computer and press F12 when you see the Dell logo. pick the option on board cd/dvd player. press enter and start tapping on the space bar to boot to cd. follow the steps in this sites to do a reinstall of Vista.( oh yeah you will lose all your data and files)
http://vistahomepremium.windowsreinstall.com/reinstallvista/index.htm
Feb 22, 2010 | Dell Vostro 220 Desktop Computer
Computers & Internet Logo
446 people viewed this question
Alun Cox
