Question about Orion VR213 VHS VCR
The unit doesn't respond to ANY button pushing, on remote or actual unit. And when it's plugged in the power light just blinks.
  • 902 Answers
Sounds like you activated the built in surge protector . you need to unplug it for about 10 minutes to reset the surge protector let me know if this works for you
Posted on Mar 17, 2011
  • orionw420 Mar 17, 2011
    Nope, that didn't help. It's actually been unplugged for more than 24 hours, and when I plugged it back in the power light started blinking and no button did what it was supposed to (including the power button).
  • brian shevack Mar 17, 2011
    looking up the model it seems like an older unit it may just be fried. there is a possibility that there is a fuse inside that may be blown im sorry i couldnt help i did as much research as i could for you. really wanted to help you out.
Philips htl2100/12 soundbar doesnt respond to remote control after plugging in
My soundbar won't power up. So I pull the battery out of remote, press a few buttons, put the battery back in and all of a sudden the device can be powered up and controlled. Until next time it stops responding. I replaced that original battery with a new one but the problem still persists.
Dec 10, 2013 | Philips SoundBar DVD Home Theater with...
I have a Sharp flat panel model LC-20SH4U. The units power LED light is red. No effect (sound or picture) when remote or on/off switch is activated. The LED light slightly blinks.
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope this may help;
Regards,
VOTIT
Aug 09, 2008 | Televison & Video
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
I pushed the sync buttons by the battery and inside the flap-and the lights blinked repeatedly on the remote-but the remote and game still do not respond to each other
Try pressing just 1 + 2 without syncing, this will enter guest mode which disabilitates the POWER button on the controller
Mar 07, 2011 | Nintendo Wii Console
For no reason I know of, my Marantz SR8001 will not come on and the display will not light up. It will not respond to activation using the power button on the display panel, or the power activator on the...
blinking power lights are a factory setting to inform the customer there is an internal electronic fault. and the unit needs to be repaired by a service pro in 99% of cases the owner can do nothing to fix it.
send it in
best luck
Oct 14, 2010 | Marantz SR8001
Blinking Timer Light
Relay or capacitor on or by the power supply
Jul 08, 2009 | Pioneer DV-285-S DVD Player
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
GARAGE DOOR OPENS AND CLOSES ON OWN LT BLINKS SEVERAL TIMES
Anytime a door opens and/or closes by itself I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
This can also interfere with remote controls
HOPE THIS HELPS
Mar 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Unresponsive buttons
First, try unplugging the unit for a couple of hours. That should reset the internal microprocessor. If that fails, try pushing all of the buttons one at a time. If one of them is stuck, nothing will work properly. You should be able to feel the button working. Report back here with your results.
Dan
Mar 12, 2008 | Sharp XL-MP130 CD Shelf System
Orion VR213 VHS VCR Logo
148 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
