Question about Fire Stone Legacy 36i (LP)
I have the Fire Strone Legacy 361 and the electornic ignition does not work. How do I fix it or how can I get a new one. Thanks
    Brigadier General:
  • 4,736 Answers
Before investing money ... have you changed the battery in the ignitor button? If so, one of the most repeated mistakes grill users make is inserting the battery in the wrong direction. Generally, the + end of the battery should be up, facing you. If that's not the case, then the ignitor will not work. Also, make sure that there is no corrosion inside the battery holder. If there is, clean it out using a Q Tip and WD 40. It also helps to check the wiring of the ignitor , by tracing all the wires to make sure they are firmly connected. And that the spark ignitor for every burner is clean and free of grease.
if after all the above, you find you need to replace the ignitor, you can order one directly from the manufacturer or from the dealer/retailer you purchased it from.
Hope this helps you solve your problem and Happy Grilling!!
Posted on Mar 17, 2011
If my 1981 flt has points ignition, then I don't have to purchase a centrifugal advance to convert to electronic ignition. Is this correct?
Hi, Douglas it all depends on the cost of electronic ignition that you purchase most brands use a mechanical advance for cost reasons on some of its models and then offer straight electronic ignition without a mechanical advance for more money if you upgrade to a stock Harley electronic ignition no problem do your homework and find something that you and your wallet are comfortable with check out Crane, Dynatek and Compufire for more information about your issue and free downloads that you will need please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day. http://www.v-twinforum.com/forums/twin-cam-engine-mods/1112-points-electronic-ignition-conversion.html
https://www.denniskirk.com/crane-cams/single-fire-crane-hi-4-ignition-system-8-2100.ph20024.prd/H20024.sku
Compu Fire Ignition System for High Compression Motors 361 826 Harley Davidson Manuals Mark Workshop
Jan 31, 2016 | Motorcycles
What does fault ing control mean on a LRZE pool heater
means it tried to fire 3 times and didnt light ignition failure make sure gas valve is on then see if ignitor is glowing if not need ignitor
May 18, 2014 | Jandy LRZ250EN Legacy LRZE Pool & Spa...
2000 subaru legacy ignition coil fires only on one side
Have you changed the engine? I put a 2001 engine in a 2000 and had to change the timing belt pullies that corispond to the 2 crank angle sensors because the 2001 had 2 tabs on the pully to activate the coil and the 2000 had 4 tabs. It had the same problem you discribe.
Dec 06, 2013 | 2000 Subaru Legacy
NEW HARD DRIVE DOES NOT WORK IN LEGACY LAPTOP
Make sure you have the drive set as "Master"
Can you tell me what error your getting?
Then I can further assist you.
Thanks
Apr 27, 2010 | Dell Inspiron 2500 Notebook
Oven wont fire
99% chance the igniter is the issue.
Nov 30, 2009 | Washing Machines
Subaru Legacy Wagon 4WD engine does not fire up
take a look to the timing belt, it may be broken. hope it help
Sep 14, 2009 | 1995 Subaru Legacy
Subaru Legacy LS 4WD won't fire
timing belt broke most likley
Mar 19, 2009 | 1990 Subaru Legacy
1994 Subaru Legacy Lsi has intermittent problem starting
With it not wanting to turn over, my guess would be a bad starter solenoid. I would get a second opinion on the engine cylinders. I have never heard of an engine that could not be bored out to some extent, and I would be very surprised if the grooves were deeper than .030'.
Mar 19, 2009 | 1994 Subaru Legacy Outdoor
Fire Stone Legacy 36i (LP) Logo
177 people viewed this question
Top Fire Stone Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Fire Stone Grilling Expert? Answer questions, earn points and help others
