Televison & Video Logo
Posted on Aug 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blurry tv monitor
Sir:
Hello! My problem is a blurry display of our sharp tv 21" Cenimaborg, pl;ease help me Sir fix the problem.
Thank you very much for your assistance.
Regards.
Nelson H. Freo
[email protected]
Anonymous
Level 2:
Champion:
  • Expert 317 Answers
  • Posted on Aug 03, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
317
Questions
0
Helped
62549
Points
462
Try to adj picture settings.
Hi I am waiting for your help to fix my TV as I have explain to you. Are you there E-mail me regarding my problem. Thank you. Mohammed S. Faruqui 50 cottonfield Cir. Caledon, Canada
Good day!!!!!
Sir may I know again what is the problem of your Sharp LC60LE810UN 60 in LCD TV?..
Please send it to me so that i can help you to fix your TV...
Thank you and have a nice day!!!!!
My sharp tv 21" model 21AG2-S have three colours
screen not coming coming standby only display led light
I changed the setting on the display and now the monitor does not display anything. how do i fix that?
Hello friend,
You must go into your tv setting and change the display make sure your setting is saved.
My acer X183H monitor won't properly display a resolution.
DEAR SIR / MAM,
FIRST OF PLEASE GET ME YOUR PC'S CONFIGERATION .. MAY I TRY TO SOLVE THIS PROBLEMS...
OK , THEN FAST TO SEND ME IF YOU NEED..
1helpful
2answers
How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Westinghouse LVM-37W3SE PC Monitor
1. Genaraly 14" and 15" Monitors supported Up to 800by600 some monitors 1024by768pixels 17"monitors supports 1024by 768 to 1280by960 pixels and Other 19",21" are supported 1280by1024 pixels at the same time change the screen Refreshrate at display properties.
2answers
2001 Sharp TV MODEL NUMBER 27N-S300
Click here to download the user's guide and go to page # 21 or read everything about disabling the V chip feature.
4answers
Monitor dispaly problem
I think this problem appear video o/p section.Dry solder Pl. solder video output section
Re: CTX monitor getting blurry
Hi Beth,
Your focus screen network turn faulty. It can be solved by by passing the original focus screen network to a new assembled focus screen network.
2answers
P1110 Blurry/dubble image
your beam needs calibration take it 2 a pro... windman
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
