My hard drive stop working and cant open it am no good on computer would like to talk to someone on the phone if it possible my number is 705-969-8679
    Brigadier General:
  • 10,406 Answers
If the disk-drive has "failed", then it must be replaced:
* turn the computer off
* disconnect the AC power
* remove the side-panel(s)
* remove the cables (data & power) that connect to the disk-drive
* remove the screws that hold the disk-drive in the frame
* remove the disk-drive
* take it to a computer-store
* show it to them, and they will sell you a compatible disk-drive
* reverse all the above "remove" steps to connect the new disk-drive
* turn the computer on
* insert the "System Restore" CD/DVD disk that came with your computer
* Windows will be installed onto the new disk-drive
* run Windows Update, several times, to get all the latest security-updates for Windows
* install free anti-virus software: http://www.Microsoft.com/security_essentials
However, it's possible that your disk-drive is still working, and all your "data" files on the disk-drive can be "rescued", even through Windows is not starting-up completely & properly.
Take your computer to a qualified technician, for trouble-shooting & repair.
Posted on Mar 17, 2011
Lacie Case Only lighting up when HD is disconnected
I had the same problem with a 1TB hard drive. The fault was caused by the casing being knocked from the computer and falling onto the desk. If the hard drive hadn't been powered up it would have been ok...
I removed the hard drive from the casing and fitted it into my computer as a slave drive, hoping to access all the music and movies stored in it. No go .. But, it's worth you fitting your hard drive as a slave and trying the same. It's worth a shot.
I took the hard drive to a computer market here in China, where I work. These guys take hard drives apart to fix them, if possible. They couldn't fix my hard drive as it had been powered on when it fell ..
However, I bought a new desktop hard drive and they were able to transfer 95% of all things from the old hard drive to the new one. The cost of transferring from the old hard drive to the new hard drive was the same as the price of the new hard drive. That specialist service doesn't come cheap ... but it can be done. I paid simply because I didn't want to lose what had taken more than a year to download.
Try fitting your hard drive as a slave to see if you can access the information on it. If not, a new hard drive and the cost of transferring your music from your old hard drive may be the only course of action left open to you
Jun 05, 2013 | LaCie Big Disk External USB 2.0 1TB Hard...
I cant open my fujitsu siemens external hard drive, 3.5", storagebird, 35EV840. Tried uninstalling and reinstalling but still no luck. Not visible in 'My Computer'. Please help.
try this one
turn off computer and ext drive
keep drive plugged in but not powered
turn computer back on and stabilize
power up ext drive
does windows see it now?
May 31, 2012 | Fujitsu Computers & Internet
My simpletech simpledrive 1tb stopped working and wasnt being recognized by my computer, i talked to a tech person on the phone and they said the controller stopped working. told me i had to take it...
If you are suppose to send it to the manufacturer to get it fixed, opening it will generally void the warrenty.
If the hard drive enclosure is bad you can buy a new enclosure for around $6-$15 online. Buy the right enclosure either a 2.5" or 3.5" just measure the shorter side and it shoukd be close inside to the drive. Open the old case slide the drive out and into the new enclosure and your done
Alternately if you want to just back it up and try and sendd it in to get fixed. --Open the enclosure and slide the drive out. (This only works with a desktop) for hooking it up to a laptop use will need a sata to usb adapter. Remove the side panel on a fairly new computer 3-4 years old or newer (you will need a extra sata data cable) plug into the drive into an open sata port in the desktop and connect the power. Turn on the desktop and it should discover the new drive.
D
Aug 03, 2011 | SimpleTech 1TB External USB 2.0 Hard Drive...
I had someone clean my computer and re-install windows xp and all the other disc's that come with my Dell computer. But when I plugged it back in this screen comes up and it stops What can I do to make...
Talk to the person who did the work. If he tested the computer when he was finished it should have been working properly before he returned it to you (or left your home if it was a housecall). Something isn't right and needs to be corrected.
Feb 14, 2010 | Dell Computers & Internet
Cant hear outta phone unless on speaker phone
If the problem is intermittent, and is affecting multiple components we are talking about a damaged ribbon cable. This cable feeds information from the main board to the board in the flip top. if damaged, you may see these symptoms or more; flickering screen, scratching or no sound from earpiece, screen blacks out, and all the symptoms may fluctuate when the phone is opened or shut. The only reason your speaker phone still works is its placement on the device. Here is a link to a public site that ranked it the top google results.
pls rate this post as fixya and good luck!!!!!!
Jun 30, 2009 | Motorola Mobility i580 Cellular Phone
Keyless entry keypad doesn't work
no idea what you are talking about. is it a wireless or hard-wired keypad? Did you recode it if wireless. give more info.
Jan 24, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Freezing
Mine also spun. It made a clicking noise when it did. I guess it couldn't find the starting sector to locate my data. I read online this is because the heads that read data are stuck together. Freezing can shrink the metal these heads are made of and keeping them cold allows data to be read before they swell again. It won't always work, and you may not even have the same problem.
I had a computer guy tell me to take it all apart and then hook the hard drive up as an IDE slave, but I was nervous as I've never done it before. When the drive had been frozen for about a week or longer, I plugged in another external hard drive (new) that booted up right away into the USB of my computer, then plugged in the bad one next to it. People who know about computers told me that the new one gave the operating system the software it needed to boot up the old one.
There were some videos on YouTube where other people had similar problems and showed solutions. You could try there to see if someone else has your exact symptoms. Good luck!
Nov 18, 2008 | Western Digital (WD3200JS) 320 GB Hard...
Motherboard blew up
I would recommend buying a replacement computer, and install the Dell IDE drive in an external 3.5" IDE hard drive enclosure. This way you can pull your information off the the Dell hard drive, and then blow it away.
Keep in mind that new computers use a SATA drive, your old Dell '8200 has an IDE drive. Also keep in mind that your Dimension 8200 drivers won't work on the new computer.
You might be able to install your Dell drive as a slave if you have an open IDE channel available.
Good news is, your old Dell uses RAMBUS memory, which is worth a lot. It's a good parts computer, and most people who look for computer parts know of the bad capacitor issue on Intel made Dell motherboards from that era.
May 15, 2008 | Dell Dimension 8200 PC Desktop
My mac computer do not reades or recognize my external hard drive 60GB smartdisk from firelite
well. Open Disk Utility in the Applications folder under Utilities and see if it shows up and possibly mount it from there. Also open the System Profilier (also in the utilities folder) and check under USB - if that's how it's connected.
Nov 12, 2007 | FireLite (USBFLB80) Hard Drive
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
