We have a distorted picture due to colours fading and lines appearing only recently. What is wrong
When flat panel televisions are placed in areas with a lot of direct sun light this happens I am not sure if there is a way to restroe and/or fix the damage already done but you could limit further damage by moving the television in an area where there will be no direct sun light hitting the screen
Posted on Mar 17, 2011
If there is a wide faded vertical line that is showing on the screen and a black film that shows up periodically across the screen. Does that mean that the picture screen need to be replaced?
Picture tubes are one of the last components to actually die in any CRT television. Usually the only reason they are / were changed was due to colour degradation or dead pixels. I would be looking at either the colour boards or for yoke damage. If the picture still fills the entire screen then the high voltage section and tube are still OK.
Hope this helps a bit. Cheers Bob
Nov 17, 2016 | Televison & Video
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Olympus u820 image distortions colour and form
One answer time for a new camera the cost to repair is about the same as new.
Mar 15, 2017 | Olympus Stylus Stylus 820 ยต Digital 820...
I have a satellite A350 and recently its been freezing then these white vertical lines appear and the screen fades out to white, then colour patches appear and eventualy the screen just goes black. ive...
It's definitely a hardware problem that a software "fix" cannot repair. It sounds most likely a problem with the video processor (GPU) on the motherboard. It might also be a problem with the LCD panel.
Mar 24, 2011 | Toshiba Satellite A135-S4527 Notebook
I have bpl tv model FYR 21 NEPTUNE and there is a problem in its colours uniformity. due to les green colours of pictures reflects the purple colour. please tell me the solution for setting its colours
my tvs volume has been increasing suddenly on serving the channels mostly above 20th channel recently the picture disappeared it shows red line in the middle but volume is present quickly give me the solution
Sep 29, 2010 | Televison & Video
FinePix F470 Lines on images and faded colors on photo mode.
You have over exposed pictures due to the shutter sticking.
The video is the clue to the problem. It doesn't use the shutter.
Shutter needs to be cleaned. This is no easy task im afraid
Sep 11, 2009 | Fuji FinePix F470 Digital Camera
Sony Bravia KLV-40U100M-screen is distorted, overlay or various vertical lines
The resolution on this was to check the surge protector the television was plugged into. Once we unplugged and plugged into another surge protector, the screen went back to normal and the appearance was great. We believe this was due to one of the resistors within the surge protector may have become faulty.
Oct 08, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Distorted picture
still having to do with your power anyway make sure your mains is not too high or fluctuating .if buy a voltage stablizer then change your power module
Jul 23, 2008 | Goodmans W280NS Television
Colour distortion
dependes on the make of TV set it is, is it a Magnavox or Philips?
Jun 11, 2008 | Televison & Video
Tv Screen Problems
as you see green screen with lines through it
lines you are seeing is called retrace lines.
the problem is due to green video output section failure
please check the followings as given
  • supply to green video output & video output itself
  • components in green video output circuit
  • crt base loose.
  • connector loose in video ckt.
  • signal from signal processor to  green video section is absent.
hope this will help.
good luck.
Oct 15, 2007 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
