Question about Toshiba Se-r0177 Remote Control
Ordered a new Toshiba SE-R0177 remote for TV model #15DLV16. New batteries installed. How do I set it up? It did not come with a manual and the original manual no longer exists. Can't find one online either. Standard "universal" remote methods do not work. If one holds down "setup" button, there are no lights that blink or anything. Any help would be appreciated. Thanks
  • 902 Answers
. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed
OK.
Posted on Mar 17, 2011
I bought a replacement remote for Toshiba TV and it was the same model number CT-90325 same as the original. but it won't operate the TV, does it have to be programmed to the TV somehow?
Sounds like the manufacturer did an upgrade. You can look up the remote control codes for that TV. Turn the TV power on. Then using the codes you found set each one into the remote you have and check the functioning by trying to turn the TV off. If you are unable to see instructions for setting the codes into your new remote, or if they weren't supplied by the seller, you'll have to find it's manual online and follow those instructions. It could be that Toshiba used the same control model for more than one TV set model. Often just putting in batteries will work but when it doesn't you have to treat the remote as a universal remote. If you can't use the primary unit setting to work you can try to set it up as an"AUX" unit as you would do for a second TV.
Dec 20, 2016 | Televison & Video
Need operators manual for Toshiba SE-R0071 remote
I don't know how to recode but you can get the manual by googling Toshiba Toshiba SE-R0071 Manual
Mike
Mar 20, 2016 | Toshiba TheaterWide 52HM84 52" Rear...
Hello my Toshiba SE-R0398 controller is not working. I ahve tried changing batteries. Any possible solutions to this problem?
Search Results
    Where is my User's Guide / Owner's Manual? - TOSHIBA FORUMS
    forums.toshiba.com/t5/Toshiba-Forums.../Where-is-my.../268741
    May 28, 2013 - Answer. Most products do not include a printed manual but Toshibaoffers free, downloadable PDF User's Guides at support.toshiba.com.
    1 - Toshiba Blu-ray Players : Questions, Answers, How To ...
    answers.toshiba.com/answers/0293/category/.../blu.../questions.htm?...
    It had been working fine. Wired to modem, home computer working fine. It does a ...My remote SE-R0377 will not operate my BDX3200KY player. Im not sure if ...Missing: controller
    Remort se-r0398 not working - Fixya
    www.fixya.com/support/t16019942-remort_se_r0398_not_working
    Jan 20, 2013 - remort se-r0398 not working remote and buttons on blu-ray player not working model bdx1100kb - Toshiba SE-R0398 ... Question about Toshiba SE-R0398Remote Control AH802703 ... I need help with syncing my controller!
    Toshiba Blu Ray Remote ' eBay
Jan 14, 2016 | Toshiba Computers & Internet
Hello, I have had my Home Theate packed for a few years now. I have 2 Toshiba remotes. Neither of them operate the system. One is an SE-R0094 and the other remote is an NB001. I tried new batteries in...
The SE-R0094 is the original remote for the SD-KT50. So should work with it unless it's faulty.
You can get the service manual for the SD-KT50, that might give you clues as to why it doesn't work. It's free the manual, just type the model number into Google.
Jul 06, 2017 | Toshiba SD-KT50 System
Remote won't turn tv off or on. Mute, volume also does not work
Take the set apart and see if there is a separate board in front of the set. Remove the board and check for cold solder joints first. If o.k., replace sensor. Then again you could contact toshiba and order another key pad for the set.
Jul 07, 2009 | Toshiba 13A24 13" TV
We installed a new lamp for our LG tv, model #RU52SZ61D
Most LG sets need to have it set by a LG authorized repair shop with a service remote. But you can try this proceedure as it will work on most models of LG
Press the ? button on the remote then press 9876 then press OK. The led s should flash for a minute then stop
Mar 15, 2009 | LG RU-52SZ51D 52" Rear Projection...
Need to know "HOW TO" set up RCR312W
You have to hold the component button (TV) and enter the code from http://www.rca.com/codefinder. The SKU it asks for, on my RCR312W, was under the lid from the batteries. Hope it helps.
Feb 15, 2009 | RCA Universal Remote Control
Toshiba 15DLV16 lcd/CD combo
mostlikely code is 11256 if ok select switch on the remote is red
Dec 26, 2007 | Toshiba CT-90157 Remote Control
Remote signals
If you tryed a universal remote , that remote should have at least worked the volume and the channels selector. It could be whats called a remote sensor assy thats mounted up toward the front of the set on the inside between the buttons. Its not really a user changeable part as there is soldering involved to replace the sensor. Realisticly, the correct way to trouble-shoot this set is to look at the data or logic line coming out of the remote sensor with an osilliscope to see the data and if it goes all the way to the microprocessor IC. If it does and no remote operation happens then the Micro's bad. Theres way to much Hi-voltage in these sets for a handi-person to tinker with, and its advised that a tech take a look at this set for you . Sorry I couldnbt be of more assistance. Good Luck
Jun 12, 2006 | Toshiba CZ36V51 36" TV
Toshiba Se-r0177 Remote Control Logo
209 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
