Question about Elna Heirloom Edition 6005
I was sewing a little heavier material the machine stopped a said to go no further for safety issues. I have re-threaded machine, changed needed and cleaned out the bobbin case. the machine still refuses to sew. What have I done
  • Elna Master
  • 1,129 Answers
Have you lifted out the bobbin case and replaced it in position? These cases are held in position with a magnet and sometimes will dislodge and turn a little which then causes the error message.
Your manual should cover lifting the case out and putting it back in - it will lift out towards you and goes back in matching up a marker on the case and the stopper in the holder.
Posted on Nov 10, 2011
Fy5318 breaking thread on multiple layers of material, how to adjust?
either the thread is old, or the tension is to tight.
or there is a bind some where in the line layout.
you mite goto there website and look under FAQ section for other help
or
www.youtube.com/sewing/canvas/material/
www.youtube.com/fy5318/multiple/layers/of/material/setup/
www.ask.com/sewing/multiple/layers/of/material/and/setups/
Sep 17, 2015 | Yamata Fy5318 Mechanical Sewing Machine
Bobbin thread will not catch on heavier materials but will catch on lightweight
You need a heavier needle, and if you can adjust your presser foot to increase the pressure, that would be helpful too. The needle is just not getting through enough to catch the bobbin thread. The higher the needle number, the longer the needle.
Jul 28, 2014 | Singer Sewing Machines
Juki ddl 8700 my machine was sewing fine I put in a heavier (jean) thread. Now it wont pick up the bobbin thread to sew at all? Help?
try changing the needle to one that will work with heavier thread
you may have to change the bobbin to heavier thread also
try adjusting the tension also
Sep 25, 2012 | Juki DDL-8700
Husqvarna lily bobbin tension issues
Not sure if I can help, but it may have to do with the heavy thread as well as the fabric and needle combination. If the fabric is thick or tightly woven, be sure to use a brand new sharp needle. (If the fabric is tightly woven (like Batik), a thicker thread may present a problem.) In your case, if using a heavier thread, perhaps a top-stitch needle would be beneficial since it has a bigger scarf to protect the thread. With the heavier thread in the top, the top tension will need to loosened. BUT, if you loaded the heavier thread in the bobbin, the bobbin tension will need to be adjusted to accommodate the thread thickness. However, remember that if you adjust the bobbin tension for this project, you will most likely need to readjust it for the next project using different materials.
FWIW, if the machine still works fine with regular fabric and thread, then you'll know that the issues revolve around the current project.
Understanding Thread Tension Threads
How to Achieve Ideal Sewing Machine Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 11, 2017 | Husqvarna Sewing Machines
I have a Euro Pro Shark Automatic. It works perfectly as a rule. I am trying to sew heavier material than usual - new inserts for my exterior sling chairs. The thread is heavier nylon and it catches on...
Most domestic sewing machines will not handle heavier thread than the standard 50 weight. I'd suggest you go back to regular polyester sewing thread and use a 110 or 120 size needle to cope with the heavier fabric. Sew slowly and give it some help on the flywheel when crossing a seam allowance. Maybe stitch each seam twice, with a 1mm gap between to give it strength.
If you need to use the heavier thread to do the job then you will probably need an industrial sewing machine that can handle that grade of fabric and thread. Something like a Singer 20U machine in a table with seperate motor drive.
Fabrics like Canvas, ticking and PVC for exterior items are generally going to be beyond the functionality of a domestic machine and you can damage the machine, particularly the timing by trying.
Aug 23, 2011 | Euro-Pro Shark 80 - 7133
Is it o.k. to use heavy duty thread on the top and regular thread in the bobbin? Also, I went to the address you reccomended for a manual but the url could not be located?
Up to a point it is OK to use a heavier thread on the top with your regular thread on the bottom. If you go too heavy with the thread you might notice thread locks on the underside of material. Tightening the the tension on the top thread will usually solve this issue. However if thread is too lheavy you will not be able to adjust for tension issues. You may also find that a "too" heavy thread will catch under the throat plate. Good luck.
Jun 22, 2011 | White Sewing 1418 Mechanical Sewing...
Needle stops when it goes into the machine.
Hi
Thanks for using FixYa. Is the bobbin case pushed all the way in? Is your needle up too high or down too low in the needle holder? The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool and then re-thread the machine. Try lowering it a little and see if that helps and use a scrap of material to test it out. Make sure the flat part of the needle rests on the flat part of the holder. You probably need to insert a new needle. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 04, 2010 | Singer 3820 Mechanical Sewing Machine
Thread breaks right away and is all bunched up on the bottom stitch
ok u have a tension problem with the top of you system. also make sure that all thread is caln and no little pieces remain a cleanign kit should of come with your machinee. re thread both of the threads and pull on them there tension shoud be close to one another. use the top tensioner to adjust the top threads tension to amtch the bobbins this should fix the problem. also makle sure yoru not jerking around the material as the machine sews as it moves the neede and the bobbin catch tiomes gets off. use the stomp foot with the machine to help guide the cloth or abric. when you have to change directions. stop sewign and turn that fabric. this should also help prevent the bunching. please feel free to contact me at rdrteck@gmail.com for any further assistance.
Aug 11, 2009 | Kenmore 756A-30BH Mechanical Sewing...
Material is puckering.i was hemming pants ,that went good;so i tried working with a very light material.threads are nor releasing, i guess, as the material is pulling together as i sew, its all puckered.
you should always use needles that are the right size and sharpness for different fabrics. any fabric store can help you with this. according to your machine the smaller the # on the needle the finer teh fabric it will sew. also using the right weight of thread is important...light weight thread for light weight fabric and heavier for thicker fabrics
May 18, 2009 | Singer Sewing Machines
Thread breaking during sewing on Ericco sewing machine
replace the needle, use a heavier thread, insure the material is advancing properly as you sew.
Feb 08, 2009 | Singer Sewing Machines
Sewing Machines Logo
105 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
