Question about Dell 3200MP Multimedia Projector
The image is kind of..green..basicly more dark then usuall
  • 442 Answers
If your graphic card output signal is "sync on Green", you should have no problem syncing.
apart from that i need more info
Posted on Mar 19, 2011
Staircase wiring circuit diagram for 2 way switch
Copy following link for wiring 3-way switches (where 2 switches control same lights)
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Each 3-way switch has 3 screws (plug green ground screw)
Two screws are 1 color usually brass, and other screw is different color usually dark.
The dark screw is common screw.
There are two basic wiring diagrams: Line-side/Load-side with neutral wire. And Line-side/Load-side without neutral wire.
Open link above and scroll down to see both wiring diagrams.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 04, 2012 | Prime 10 Amp Circuit Breaker
HP Screen Problem
dark screen and dead pixels is caused by the invertor or the screen.
new invertor are usually about 5-15pounds on ebay, new screen probably around 50 pounds,
try pressing the fn + one of the f1 keys that has a monitor image on it to switch to external display if it has.
Jun 09, 2012 | HP Computers & Internet
Power on green light flashing no display on da monitor
The flashing green light and no display usually means that the backlight circuit has failed. You can verify this by shining a flashlight on the dark screen and see if there is an image. If there is an image, then the problem is the backlight circuit. Often the problem with the circuit is that the transistors burn out. There are sellers on ebay that sell repair parts kits to fix these monitors if you are handy or you can bring to to an electronic repair service to have it fixed.
Apr 19, 2011 | Dell Computers & Internet
My pictures are coming out too dark
There are four ways to make the image lighter
a) more light (flash, sun, etc)
b) slower shutter speed (allows more time for light to "expose" the sensor)
c) larger aperture (bigger hole = more light)
d) higher ISO (basically, amplify the available light more).
If you are using a point and shoot camera, the flash is usually only good for about 10 feet, so trying to get a good bright picture of subjects further away won't work.
Items b, c, and d are handled by the camera in automatic mode. In manual mode, set the iso has high as it can go. Set the aperture as large as it can go, and decrease the shutter speed.
Depending on the camera, you can enable the histogram to see if the images are too dark, usually by pressing the display button while taking pictures. If the histogram is off to the left edge, the picture will be too dark.
In post-processing, (e.g. photoshop), you can use Levels (control-shift-L for auto-levels) and it will move the histogram to the right, making the picture look brighter.
Feb 27, 2011 | Cameras
Hitachi L32HO1UA HD TV blurred images very dark unwatchable scree
Hi Ellie!
Maybe in the manual you can find any information how to resolve this problem.
On this page of the manual there are shown most common receprion problems: http://manualsbrain.com/ru/manuals/979781/?page=72
Apr 26, 2017 | Hitachi 61SWX10B 61" Rear Projection...
Viewsonic VA702B
Monitor going black after a few seconds can be caused by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Jul 28, 2008 | ViewSonic VA702b 17" LCD Monitor
My panasonic HDTV bbl 1080i was purchased about 6 or 7 years ago. The image shows two or three other images from the original image which are florence green and pink. So basically I see a triple image of...
I have a Panasonic PT-47WX53 rear projection TV and the picture was pretty dark for the last year but for game it was OK but know the blue is out of sequence, do I need to change the lamps?
And where to find them?
Jul 26, 2008 | Panasonic Televison & Video
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Dell 3200MP Multimedia Projector Logo
90 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
