Question about Magellan Maestro 4350 GPS Receiver
Plug for power came unhooked. Loose inside - Magellan Maestro 4350 GPS Receiver
    President:
  • 1,111 Answers
hi ultrapresser follow the link near the bottom for more help..
The following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Please Support Our Troops
Posted on Mar 20, 2011
No green light on my logitech speakers
First and foremost, did you test those speakers at the store before you bought them? There must be an ON/OFF switch somwhere on those speakers. Or maybe, the AC cable is defective or loose. Try unhooking it from your speakers then hook it back. Or did you forget to plug it in the wall electrical outlet?
Jul 13, 2012 | Logitech Audio Players & Recorders
Speedometer inop intermittant
This may be a problem with the speedometer cable. From the back of the gauges there is a thick cable that goes to the transmission. Check if it is loose or there is wear. You may have to unhook it or apply grease to it or replace it. Otherwise it could be the gear inside the transmission which counts the rotation that is faulty or loose.
Apr 26, 2011 | 2000 Chevrolet 2500
My HP laptop was working fine, and then suddenly the screen went blank. When I reboot, the power light stays on and you can hear the hard drive spinning, but the screen stays blank.
unhook all usb cables and power cable, take out battery. Hold down Power button for 60 seconds, which will get rid of all static electricity. Plug in all cables again and check.
If still facing problem there will be some connection issue inside the lap.
Please let me know whether this works or not.
Dec 20, 2010 | Computers & Internet
Rack and pinion went out on my 1997 ford taurus need to remove it
will need jack stands and a tie rod pickle fork. jack car up and support it securely and remove front tires. unhook tie rods get a pan to catch power steering fluid and unhook the power steering lines.. recommend tubing wrenches for this .once lines are loose you will have to unhook the steering wheel shaft and then loosen the mounting bolts holding the steering rack to car.. recommend you have help as you lower it.
Mar 29, 2010 | 1997 Ford Taurus
Car will not go into reverse, only in drive 3yrs ago linkage was unhooked to tow the car by the tow co driver. Dealership was told about the linkage being unhooked. When the car was originally returned,...
Sounds like the shifter cable is out of adjustment. Check at the transmission and see if it is loose. Then, inside take the console out and look at the cable at the shfter lever. make sure it isn't loose there. A retaining clip may be broken or pulled loose.
Jan 30, 2010 | 2000 Saturn SL
Dryer won't start
Check the plug, both the male and female side. Sounds like a loose connection. Check the connections going in the back of the dryer too...remove the little plate (with it unhooked) and check the tightness of the wire.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 12, 2009 | Whirlpool WED6200S Electric Dryer
My inputs dont work
I don't believe the moving and unhooking was the issue! First I would look inside to see if the ribbon like cable came loose,that goes from signal board (input board) to lcd controller. The lcd controller will be on the back of the lcd screen, you will see a small board under a metal cover.
Second It may have been a coincidence, and the signal board was starting to fail. There could be some visual issue's with board maybe some bad caps (capacitors) on the board. They will look bulged on the top an may be a little leaky (brownish stain). Good luck, I hope this was helpful!!
Mar 01, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
LOOSE CABLE IN FRONT AREA OF MONITOR
The two vx900 s I have here have more of a rectangular plug for the power. Inside it is three large prongs and on the backside should be 3 wires. Two of which go to a smaller plug that connects to the power board.
The power cord is the same as found in many desktop computers.
If this is what you are referring to. Then the plug should be connected inside and it snaps into place onto the meatl part inside the monitor.
You may have to disassemble the unit to get it back together.
Sorry for delay in reply, I never was notified that you had replied.
Fran
Oct 10, 2008 | ViewSonic VX900 19" LCD Monitor
TV plug came loose inside tv
The damage most be heavy for the power cord to come out with the conector that attaches to the main board,telling you where it goes will not help because most likely you have a broken main board,you shoud get an estimate from a qualified technician.
Sep 04, 2006 | Philips Magnavox MT1905B 19" TV
Magellan Maestro 4350 GPS Receiver Logo
37 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
