Question about General Time Corporation Westclox Bell Ringer Quartz Analog Bedside Alarm Clock The clarity of a bell alarm with the conveni...
Looking to replace an electric movement for a ship clock uses one "D" battery. Wall hanging. Cat. No. 1047, "CHESAPEAKE" Model # 1047-000
  • 604 Answers
Go to www.klockit.com they make replacement movements of many types
Posted on Mar 17, 2011
Having major trouble setting it after D.S.T. Could you help? The "it" is a Universal TechTronics U.S. Perfect Time clock.
16d25m. \FixYa.com /mm
... I'm not familliar with your particular clock, but, I'm assuming you may have a;
BATTery operated, wall-hanging, 'self-syncronizing' clock with 'hands' on it.
These are often marketed as 'Atomic' Clocks that 'keep perfect time - all the time'.
Generally these work by 'accuratizing' the Minute-hand as it approaches the 'top-of-the-hour' position (e.g. the 60th. or the zero- minute marker at '12'. They often achieve this by either 'double-Clocking' or 'half-clocking' (doublespeed or halfspeeding) the electric pulse that makes the 'SECONDs' hand advance to it's next mark. These 'SynCHRONO-ize' to a low-frequency Amplitude-Modulated (AM) radio-wave signal, (perhaps near 430Khz?) emminating from a source near "The Atomic Clock" out in Colorado (I believe).
One that I used to have hanging had recommended something like the following:
-manually adjust the time (via the small grey wheel near the BATTery, but set it about 7 to 12 minutes 'early' or before the actual correct time, (preferably at about 10 min. before an Hour).
-then remove the one " double A" . . .
... battery (for about 30sec.) and reinstall battery.
-then hang it up, and watch for the second-hand to do its 'Double-clocking' (for part of it's revolutions ) as the Minute-hand apprpaches th '12'. {note; it may take ~2 or 3 hour-cycles for the minute-hand 'to catch-up on all it's "Lost" minutes}.
(then, hopefully, your model will stay 'synchonized' there, for that 'Hour's' setting, and accept It (DST Hour value) with accuratizing Minutes. (and not go crazey over the next few days trying to get back to "Real TIME"). /mm
butifallelsefailsreadthedirectionsand,
basicinstructions'boutlife(on)earth.
Apr 25, 2016 | Home
How do i reset the chimes for a Strausbourg Manor Quartz Movement wall clock? and what is the magnet for?
Try removing the batteries. Set clock to 5:45. Reinsert the batteries, and set to 6:00. it may take an hour for the clock to sync., but it should do the trick. The only thing I can think of for the magnet would be that it may have fallen out of the pendulum swinger where your pendulum hangs. Hope this helps. Good Luck.
Nov 07, 2014 | Home
Equity model 29002-1
Anon, replace battery with a good strong AA Energizer or Duracell Alkaline not a cheap battery, make sure battery contact point in clock are clean and no corrosion. If this does correct the problem, the clock mechanism is probably just wearing out from age which is normal unless it is digital. Read through the links and learn how some time mechanisms can be made to work properly again. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Maintain Battery Powered Quartz Wall Clock
Save Money Quartz Battery Wall Clock Repair Fixing Disney Winnie The Pooh...
Clock repair and troubleshooting
How to identify and replace quartz clock movement
Feb 15, 2014 | Equity By La Crosse Equity 29003 10"...
Pendulum wont swing
Clock may either need to be decked out from the wall at the top, or pushed all the way up against the wall. These clocks have inexpensive quartz movements that aren't of the highest quality. If the clock is more than a few years old, it may be that the electromagnet that impulses the pendulum back and forth has just expired. You might try Clockit.com, or maybe Timesavers.com to find a replacement movement. Hope this helps, Good Luck
Dec 04, 2013 | Sterling & Noble Scroll Pendulum Wall...
Metal pendulum wall clock run by AA batteries... does not run... new batteries do not solve the problem.
Hi! the movement must be bad, you can actually have a battery clock movement replaced easily at a watch or clock shop! We charge about $30.00 to 50.00 if the movement is available, you did not mention what type of clock? if you can let me know i may be able to help further. thank you!
Sep 20, 2011 | Watches
General Time Corporation Westclox Bell Ringer Quartz Analog Bedside Alarm Clock The clarity of a bell alarm with the conveni... Logo
233 people viewed this question
Top General Time Corporation Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a General Time Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
