Question about Garmin Nuvi 660 GPS Receiver
I bought a used 660 on ebay, it seems to have some propriotory splash page and on display page there is no option to change splashpage. how do i get it back? also on whereto page there is no go home icon, how do i get that back? thanks
  • dolphan199 Mar 17, 2011
    well it is a DTAG unit
  • Garmin Master
  • 2,130 Answers
At the menu, press the wrench (settings), then the display icon. On the display menu, select "splashscreen" and you'll be able to change the boot-up screen if there are other images on the unit. You can add your own images by uploading them to the unit via a USB cable connected between the GPS and Nuvi.
You have to set a location as the HOME destination first. If you already entered your home address, press "WHERE TO", then "FAVORITES" and click on your home address. Select EDIT and you should see a prompt to set the address as your home address.
- Jim
SHARCNET-USA
Posted on Mar 17, 2011
Testimonial: "as i said in the problem...there IS NO icon on the display page for splashpage,by the way I already have a 660 in my truck, I got this one for the wif"
  • 11 more comments
    any other suggestions? i'll try the home thing when i get home
  • SHARCNET-USA
    SHARCNET-USA Mar 17, 2011
    It is very possible that it has a unique firmware. If you look on the back of the unit, look at the serial tag under the flip up antenna. A stock unit will say 660NA. If it's a custom unit, it will say something else, like 660 DTAG, which stands for "Thrifty Dollar Automotive Group". These were units used in rental cars. This may explain why you don't have a HOME selection because rental cars, etc. don't have a home location. The problem is when you try to upgrade the firmware, WebUpdater will see that is unique and only allow you to upgrade to a newer unique firmware. What you would need to do is put the unit in pre-boot mode and force it to take a standard 660 firmware.
    - Jim
  • SHARCNET-USA
    To force the unit to take the standard firmware, you need a program called "UPDATER.EXE" and the .RGN file for a standard 660 unit. When you flash that file into the Nuvi, it will overwrite the unique firmware making it a stock unit and you will then have the standard icons back.
    is there some file or something i could copy from my good one and replace on the "other" one?
  • SHARCNET-USA
    The firmware is not located on the unit's user accessible drive. The firmware is loaded (flashed) into internal memory. There is a file however called GUPDATE.GCD, located on the user accessible drive, which can be copied over from one unit to another that can be used to update another 660. This is a file that is created when you use Web Updater. If you have that file on another unit, you can try copying it and pasting it into the other unit in the Garmin directory and then reboot the unit. Make sure you have a good charged battery or immediately plug the unit into a power source after you have SAFELY REMOVED the unit from Windows and pulled out the data cable. If the power dies during the update, you will get a Missing Software Error. This works great between standard 660's. Whether it will work between a stock 660 and a unique one, I'm not sure as I have never tried it. I do believe though the differences you are seeing is that the unit is flashed with a custom unique firmware that adds certain features and is missing other standard ones.
    cool, I did notice that file on my good one, i'll try it when I get home, by the way just how long would this reboot take..ie necessary battery life?
    also, it seems like it was from a trucking company
  • SHARCNET-USA
    The flash will take about 1-2 minutes. You will see "LOADER" appear on the screen, then "SOFTWARE LOADING" and then the unit will reboot. Again, that is when you are doing this between two stock 660's.
    so...if my other one does say something other than 660na, i should NOT try this?
    so a hard reset probably won't do much good?
  • SHARCNET-USA
    If the firmware version on your unit matches the firmware version of the GUPDATE.GCD file, it will not reflash. The current versions of the firmware is contained in a list file called GarminDevice.xml. The firmware version of the GUPDATE.GCD file is compared against what is listed in the GarminDevice.xml file. If the GUPDATE.GCD file is newer, the flash will proceed. If they are the same value, it won't. If the file is older that whats listed in the file, you will be given a prompt asking you if you want to install an older version.
    it is a DTAG unit and tried reflash, loaded but no change.....what now? lol
  • honster Jun 20, 2011
    Did this method work for you? I have given it a try with no luck
Cannot sign in ebay page cannot be displayed
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line
(type in Ebay.com) or your preferred home page
or once the Ebay web page is open right click on the page select add to favourites this will add the Ebay shortcut to favourite drop downlist
right click in the top toolbar selct the menu tau tab
this will add the File Adit View Favourites Tools and Help tabs to the toolbar
hope this helps
Jun 13, 2012 | eBay Auctions
What type and size screwdriver does it take to disassemble the cover of the Garmin NUVI 660?
you need a T5 security bit...thats a torx with a hole in the center to prevent tampering...they can be bought on ebay, least thats where i got mine. EBAY TORX LISTINGS
make sure you get the security bits or they wont work...i also recommend getting a few other sizes, like from 4-7 due to the poor quality of those screws, sometimes a 5 wont work and you either need a 4 or 6 because it seems no two are the same.
bill
Standing Member of G.O.T.
Oct 07, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin 660 "Display unit " won't seperate from mount
If you have the suction cup holder in the middle of the bottom of holder there is a tab there... hold gps while thump underneath and press thump upward to release and pull out unit
Mar 13, 2010 | Garmin Nuvi 660 GPS Receiver
Can't locate FM Transmitter options on GPS
Page 35 of the manual, here is the link to the manual if you don,t have one.
Not all units have transmitters, check the garmin site if in doubt.
https://buy.garmin.com/shop/store/manual.jsp?product=010-00540-00&cID=164&pID=31946
Hope this helps.
Ed
May 05, 2009 | Garmin Nuvi 660 GPS Receiver
No unlock code for Garmin Nuvi 660
Sorry but that is a security feature. There is a chance you've purchased a stolen unit from ebay. Unfortunately, only Garmin can unlock it and they will require a receipt from a Garmin dealer.
Jan 10, 2009 | Garmin Nuvi 660 GPS Receiver
"completed" remains on display
I solved this problem be removing the batteries briefly so that I was able to start again with a clean slate.
Dec 29, 2008 | Marantz PMD660 Digital Voice Recorder
Garmin NUVI 660 - can not locate satellite
Please read this solution, which might help you. On the 660, you press and hold the upper-left hand corner of the screen while turning on.
http://www.fixya.com/support/t1155473-garmin_nuvi_660_not_locate_sattelites
- Jim
Nov 06, 2008 | Garmin Quest 2 GPS Receiver
Garmin Nuvi 660 - how do I get FM Transmitter firmware
I believe in your location it comes as an option. transmitter is an optional module. You can browse the user manual at following link (PDF file) http://www8.garmin.com/manuals/1262_OwnersManual.pdf
You can see at 35th page, simple instructions have been given for FM transmitter settings.
If it doesn't work please contact to the Manufacturer. I couldn't find Garmin's Ireland number. However you may call UK number +44-870-8501242. Or simple you call your reseller.
Good Luck
Jan 23, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
469 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
