Question about Zanussi Dishwashers
Door lock/retainer broken - Zanussi Dishwashers
  • Brian Holt Mar 17, 2011
    Requires new Dishwasher Latch Bridging Plug (Door Catch) ordered one from eSpares, quite cheap. To replace undo screwws on inside that hold top panel on, then 2 that hold switch, remove wires, then replace with new part.
  • Zanussi Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Mar 18, 2011
2011 hyundai sonata passenger back door lock making odd sounds won't unlock I have to unlock it by hand 1
need to remove door panel to look at the lock linkages --a linkage rod possible disconnected from a broken or disconnected retaining clip
Nov 28, 2016 | Hyundai Cars & Trucks
2008 hyundai accent rear driver door stuck locked. Won't unlock automatically or manually
You will need to remove the door card and check the lock linkage rod to the door latch, it may have come off, most likely from a broken retainer clip..
Nov 08, 2016 | 2008 Hyundai Accent
Lock barrel has gone in to the door
remove door panel and at bottom of door frame will be lock retaining clip and actuator rods if the clip is broken most auto stores carry them bring with you for correct size --if lucky all but the retaining clip is on bottom and lock can be reinserted and clip replaced
Jul 12, 2016 | 2005 Kia Sorento
Remote doesn't work to unlock drivers door nor doesn't the key work to unlock what should I do
The lock rod must have fallen off due to a broken retainer. remove the door panel and repair whatever issues you find with the lock rod. If the plastic rod retainer is broken the dealer can supply a new one for about $2.00 US
Jun 06, 2016 | 1998 Holden VT Commodore
Rear door handle broken. Mazda mpv 2001. lock works fine.
The relay rod inside the door has broken (not likely), one of the retaining clips that hold it in place are broken (most likely) or the tab on the door handle assembly is broken (again not likely). to gain access you will have to remove the door panel. You did not say whether the handle you are having a problem with is the interior or exterior but to remove the door panel you will need to have the door open, you might want to purchase a Haynes or Chilton manual for your car to get the proper instruction if you have never removed one before.
Dec 12, 2011 | Toyota Cars & Trucks
Error code 41
The error code E41 means the control board is detecting an open door switch. It might be due to a broken wire harness, broken door lock/switch assembly, or in worst cases a faulty control board.
Unplug the machine or disconnect power. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the spring of the retaining hoop then remove it.
Carefully peel off the part of the door seal from the lip of the door opening near the door lock/switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock/switch assembly
to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock/switch assembly out of the front panel then
disconnect the door switch harness then short circuit the terminals by putting a jumper wire between them.
Put the door lock/switch assembly back into position in the front panel then secure it with the securing screws previously removed.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop. Reconnect power and run a test cycle. Replace the door lock and switch assembly (part #131763202) to address the problem if the washer works fine with the door switch bypassed. If not, replace the control board.
Jul 18, 2011 | Frigidaire ATF6700FS Front Load Washer
My driverside door will not allow me to use my key to unlock when i turn the key to unlock the key just spins around what is the part where key unlocks the door called and how can i fix it
The linkage between the lock cylinder and the lock assembly has broken or simply come loose because of a broken or faulty retaining clip.
Apr 03, 2011 | 2002 Dodge Stratus
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
DOOR WON'T OPEN FROM INSIDE OF NISSAN ALTIMA 2002 ON DRIVER'S SIDE
There is a cable that attaches to the inside door latch release handle. The plastic that retains this cable is most likely broken. I have seen this before. If the retainer is not holding the cable sheath correctly, the entire cable moves when the handle is pulled and does not release the door latch.
Remove the door panel and inspect this cable. You will see 2 cables (one is for the door lock). If the plastic is broken, you will need a new interior handle assembly.
Hope this is helpful!!
Nissan Scope Technician- 10+ years experience in Nissan dealership
Nov 09, 2008 | 2002 Nissan Altima
Dishwashers Logo
74 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
