Question about Samsung Televison & Video
Samsung TV Model # LN40A330 Have changed two 1,000 uf Capacitors in power section that were convex on top. Now when turned on get tone and a small red light. Before changing caps it would not turn at all. Now what?
  • 4 more comments
  • murthapj Mar 17, 2011
    This TV is new to me; but, I did see a mention in the Operation Manual that there is an option to have a turn-on tone and a turn-off tone. You say that these tones mean that there is a short in voltage regulator??????
    Yes, they are installed with the correct polarity.
    Is CN801 the 24 pin connector? What pins do I check?
    Now I do not read any voltages there is no tone and no red light.
    I can not measure any voltages, there is no red light, and no tone?
    President:
  • 1,961 Answers
Hi, did u have a multimeter? you have to measure if the power supply has a complete voltage output in order to power up your T. there are 3 voltage requirements/output from your power supply.they are ;
1)5 volts -this voltage use to power up the mainboard
2)12 volts - this is a supply for the audio amplifier(sound)
3) 24 volts - this the supply for the backlight lamp.The lamp is the illuminates the screen.
I these voltages are present then your TV will turn on.there are reasons why the power supply doesn't turns on.When there is a shorted circuit on the section being supplied by the power supply the power supply will shut down.this is a fail safe operation of the power supply to prevent further damage and fire.The primary suspect of a shorted section in an LCD TV is the inverter section. this section is the supply of the lamp.the primary voltage input of this board is 24 volts and the output voltage is 100 volts AC.check the components of this board for any shorted.Check the diodes,transistors,regulators,and the ballast transformer.or you can replace them with a new board.They are available at stores on line.
After changing the capacitors at the power supply section and still it wont power up check also for any open resistors.All resistors must have a resistance if you measure an open resistors replace it immediately with the same color code resistance value.This power supply is also replaceable.this is available at shoppejimmy.com just search for you model and brand of your TV.I'll give you the link..
Posted on Mar 17, 2011
  • Samsung Master
  • 2,098 Answers
Hi murthapi,
Tone that you heard means that you're supply voltage gone to shorts. Shorted parts is you're voltage regulator transistor(mounted in heat sink) in line with this capacitor. If you're not familiar troubleshooting the said parts, you may replaced the entire board for your convenient, click this link http://shop.ebay.com/i.html?_nkw=LN40A330&_sacat=0&_odkw=37RV530U&_osacat=0&_trksid=p3286.c0.m270.l1313.
http://www.shopjimmy.com/catalogsearch/result/?q=LN40A330.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
  • 4 more comments
  • Jdvillanueva
    Jdvillanueva Mar 17, 2011
    Sorry I'm assuming that the tone was coming from the power supply. Check the polarity of the new installed cap if it is in the right place...
  • Jdvillanueva
    If you have a multimeter check the output voltage in line with this new installed cap. Let me know the reading...
  • Jdvillanueva
    check all output voltages in CN801.
  • Jdvillanueva
    You're reference voltages are printed in the board itself if you don't have an schematic diagram...
  • Jdvillanueva
    If none voltages at the output means that you're volt regulator section didn''t go into complete cycle. You have to check for an open fusible resistor. Check also the voltage regulator transistor (mounted in heat sink). If you have a capacitor checker, test all capacitor near the 2 1000uf cap that you've already replaced.
  • Jdvillanueva
    Another option, if you can't troubleshoot the said parts, bring your power supply board to repair shop or look for a qualified technician to do the job for you but I think its is much cheaper if you will buy a new board rather than repairing it. I've suspected that you're board has a factory defect since you've mention that it is a new unit.
I know that it is in the low volt supply because there is no sound or pic. How if u unplug the tv for about 30min. and plug it back in the tv will come on.
change the capacitors on the power supply ,look for bulging tops on the caps,the caps will have white letters on them that will read 1,000 ufs at 25 or 35 volts,make sure tv is unplugged when doing this,if you cant solder i would highly recommend getting it serviced by someone who is qualified
Feb 27, 2011 | Vizio P2 42 in. HD-Ready Plasma Television
My tv wont turn on
Remove the back off your tv, and just take a look at the small array of capacitors near the top right corner of the centrally situated power board. there are 4 identical capacitors rated at 1000uf 10v 105 degrees C. I think the silver capacitor lids should be flat or even slightly concave. The ones I replaced were all slightly convex and 2 of them had a tiny amount of what looked like brown corrosion right in the center of the caps.
Dec 19, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My Samsung PS4297HD TV started to turn itself off after about 5 minutes and noe wont turn on at all but just makes a constant clicking sound
Hi
A common fault with this model is bad capacitors in the power supply, Remove the back from your tv and look at the power supply for bulged / swollon capacitors on top, they may even leak a brown like substance and should have a value of around 1000uf 10v
Change these where possible with the same uf but higher voltage lets say 1000uf 25/35v
Hope this helps
Please rate my reply++++
Apr 05, 2010 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Clicking sounds and delay when turning on lcd tv LE52M86BD
Hi
Hope this helps
Jan 09, 2010 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
When I try to turn on our relatively new Samsung flat screen TV, it clicks off/on, off/on numerous times before actually turning on and staying on. Any ideas what could be causing this?
A lot of these Samsung LCD and Plasma TV's used marginal electrolytic capacitors in the power supply. You can usually tell which capactors are bad, because their tops will be swollen (rounded) instead of flat. The usual values of the bad capacitors are either 2200 uF or 3300 uF, usually rated at 35V, depending on the model. I've seen these capacitors go bad after just 1 year of use. It's a relatively easy repair for any qualified electronic or TV technician.
Dec 17, 2009 | Televison & Video
Tv won't turn on
Hi my name is Eric,
I hope I can help you with your issue ,
If the TV is totally dead a voltage test would tell if its the power or mainboard (only two boards in the TV)
The TV not starting properly you should hear the tone noise (bleep bleep) not a ticking noise or no sound.
A long time coming on is a classic example of what I am detailing for you below. .
These Samsung LCDs have problems with the power supply capacitors going bad, a servicer will charge between $200 and $450 to repair it replacing either the capacitors or the whole board.
here is a DIY (do it yourself) solution:
It could be just a few bad capacitors on the power supply, if you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on top.
We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.
with the back removed you will usually see two circuit boards the upper one is the power supply, it has a few capacitors on it (cylindrical standing straight up soldered in mark on the sides with the positive/negative sides and uf and Volts values)
Samsung uses mostly 1000uf at 16Volts rating capacitors, they cost about $1 each (680mfd will also work fine)
usually I replace about four of them (or all the bulged on top ones) .
To buy capacitors click here
The power board and back unscrew with a medium philips screwdriver, if you do not know how to desolder and resolder then do not attempt this as you may damage the TV more than fix it.
Im am posting a photo of some swollen caps on a board so you know what they look like below
best of luck to you
If you feel good about my solution please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 01, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
My t.v suddenly won't turn on! Please help..it sounds like its trying to turn on, but nothing now!
Hi
Hope this helps
Nov 17, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung LN-S4051D Tv Cliking noise only but tv does not come on.
I had the same problem. I work for a mother board manufacturer w/offices in New Jersey and brought mine into our engineering lab after Samsung told me tough luck. Anyway, one of my engineers fixed it in 10 minutes. Essentially, he replaced the 1000uF capacitors on the power supply board with 2 cent capacitors instead of the 1 cent capacitors that had blown out on the CHEAP SAMSUNG POWER SUPPLY BOARD. You can tell the caps are blown via visual inspection. The top of the cap should be perfectly flat and a blown cap will be convex on top. Unfortunately, there are also 2500 uF caps by the same cheap manufacturer on the board as well and we don't stock that value for our products. According to my engineer, those will most likely blow next since he replaced the others with better caps, but I'm getting samples of those and will replace them shortly. After that this piece of **** should last me at least another 2 yrs! It's been working for about a week now w/no problems. Hope this helps.
Dec 15, 2008 | Samsung LN-S4051D 40 in. LCD Television
My 42" LCD HDTV LNS40ID won't turn on PISSED!!!!!
I had the same problem. I work for a mother board manufacturer w/offices in New Jersey and brought mine into our engineering lab after Samsung told me tough luck. Anyway, one of my engineers fixed it in 10 minutes. Essentially, he replaced the 1000uF capacitors on the power supply board with 2 cent capacitors instead of the 1 cent capacitors that had blown out on the CHEAP SAMSUNG POWER SUPPLY BOARD. You can tell the caps are blown via visual inspection. The top of the cap should be perfectly flat and a blown cap will be convex on top. Unfortunately, there are also 2500 uF caps by the same cheap manufacturer on the board as well and we don't stock that value for our products. According to my engineer, those will most likely blow next since he replaced the others with better caps, but I'm getting samples of those and will replace them shortly. After that this piece of junk should last me at least another 2 yrs! It's been working for about 3 weeks now w/no problems. Hope this helps.
Dec 13, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung lns5296dx will not turn on center blue on but not TV
LN-S5296D - Cheap Fix, replace the blown capacitors on the power supply, 1000 uF - 10V (anothe forum member reported that they used 35V capacitors to replace), less than $10 in parts and takes a little basic knowledge of electronics and soldering skills. I had 3 bad capacitors, some report more or less.
Expensive Fix, replace the entire power supply board, BN44-00150A, $140. If you can replace a computer motherboard, you can do this.
I ended up ordering and replacing the power supply board but after looking at it, I could've just replaced the capacitors. They will show a buldged top or there will be some black goo oozing out of the X's area at the top of the capacitor. Oh well, I now have a spare board for the future.
Symptoms: Blue light on, would not turn on. Unplugged waited and plugged back in the Blue light did not come back on but after a few minutes it did. Unplugged for about a week then the TV came back on but after shutting off it came back on and the picture was a garbbled and pixelated, no sound. After shutting off the blue light was flashing and would not turn back on.
Nov 18, 2008 | Televison & Video
Televison & Video Logo
193 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
