Question about Sony Cyber-Shot DSC-S500 Digital Camera
Sony memory stick pro duo
I am using sony memory stick pro duo stick in sony cyber shot camera. I am not able see the photo from the memory stick if I try to read from card reader. But I am able to see the photoe from camera if memory stick is inside the camera.. yes i am having the same problem everytime i put in my memory stick in my cybershot camera it would say acess on the screen. later a blue screen would pop up and say "reinsert the memory stick" c:13:01 blinking
  • moemoe550 Aug 02, 2008
    well when i push in the memory stick in the camera the camera read "acess" when i push the memory card to pull it out of the camera. the Sony Memory Stick (E:) pop up. the file system is FAT . but when i pushed the momery stick back into the camera. the (E:) disappear and the camera read "ACESS" again... i tried to put the memory stick to it's adaptor to put it in my laptop but it's not reading the adaptor at all. it appear then second disappear. please help!
  • 659 Answers
Well alot of the time there is a issue with the formating that the camera does on the stick and also when formating it on the computer it formats it another way as well. some in FAT and some in FAT32 this is ushally a error for the most part I would definatly plug your duo stick into a card reader and then go to my computer and the find the drive that the stick is in and right click on it and go to properties and do a error check on the stick to make sure that there is no errors. and if you can defragment after the scan then by all means do it and then format the card and try it and hopefully it will work out to your advantage.
*note this problem seems to only happen with the non branded duo sticks not the sony branded ones.*
Posted on Aug 02, 2008
  • Wesley Gardner
    Wesley Gardner Aug 02, 2008
    well I think when that happens you will have to reboot your laptop sometimes when a usb device is recognized too many times too quickly it causes a internal error with it I have that issue before with digital cameras my computer would recognize it disconnect it and then reconnect it then causeing the drive to not show up.
    so I woud reboot but have the memory stick not inserted wait till the laptop is completely booted then insert the stick into the reader.
    do you have any other sticks to try in the reader as well?
    just to rule out any possible damage to your reader. if its a software issue then there is a few things we can try to fix this issue.
    try that and let me know if that works and make sure that no other usb devices are plugged in to the laptop when trying to prevent any conflict. with other devices.
What memory sticks do i need
Quoted from the technical specifications available on the Sony website UK. http://www.sony.co.uk/electronics/cyber-shot-compact-cameras/dsc-h300/specifications Storage Media Internal MemoryApprox.55MB Compatible Recording MediaMemory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO Duo (High Speed), Memory Stick PROHG Duo, Memory Stick Micro*10 , Memory Stick Micro (Mark2)*10 , Memory Stick XC-HG Duo, SD Memory Card, SDHC Memory Card, SDXC Memory Card, microSD Memory Card*10 , microSDHC Memory Card*10 , microSDXC Memory Card*10
Mar 26, 2015 | Sony Cyber-shot DSC-H300 Digita Camera -...
Why can't I access my photos on my computer from sony memory stick pro duo 4GB but can view on camera?
You may be able to get the images from the card. try using a program called BadCopy Pro. I used it a few times to get back images from memory cards that would not work on any computer. Good Luck.
Jun 01, 2014 | Sony 4GB Memory Stick PRO Duo Memory Card
DSC-H2 will not accept memory card
The DSC-H2 works with Memory Stick Duos, not with Memory Stick PRO Duos.
Nov 26, 2013 | Sony Cyber-shot DSC-H2 Digital Camera
Bought used camera Sony Cyber Shot Model DSC-P32. What Memory Stick do I need?
You can use Memory Stick standard, pro or pro duo up to 2GB with the Camera.
    A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo™ or MagicGate Memory Stick Duo media.
I have provided the Memory Stick compatibility chart for your reference.
http://esupport.sony.com/US/perl/support-info.pl?&info_id=12&mdl=DSCP32
Feb 09, 2011 | Sony Cyber-Shot DSC-P72 Digital Camera
I want to download photos from memory stick pro duo of sony company
Use card reader and insert your cams stick pro duo memory card/chip into it. Then insert card reader into Pc usb and copy your photos from memory stick pro to your pc.
Aug 19, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Can I use 4GB Sandisk Memory Stick Pro Duo in my Sony Cyber shot DSC N1 Digital Camera''
Yes, a Memory Stick Pro Duo is the right card for this camera. The manufacturer shouldn't matter.
Jun 05, 2009 | Sony Cyber-shot DSC-N1 Digital Camera
MY PROBLEM IS THAT MY LAPTOP HAS WINDOW VISTA SYSTEM AND I CANNOT LOAD MY PHOTOS FROM MY SONY CYBERSHOT DSC P73. I NEED THE PROGRAM OR WHAT I NEED TO DO?
To make things easier, you should buy a card reader. There are different types.
MS Pro Card Reader - Is ONLY for the sony memory cards
Multi Card Reader - Will read sD, xD, Ms Pro Duo, Ms Pro, Compact Flash, Smart Media, etc.
Sony has a new memory stick out called the memory stick pro duo. Your P73 does not take this. The P73 takes the Memory Stick Pro. Which is a longer stick. You can go out to best buy or ritz camera and buy a card reader (Memory Stick Pro) and stick your memory card into the card reader and stick that into your USB port on your computer. Since it is USB, this will require NO SOFTWARE.
Your camera came out in 2004. Vista did not come out until early 2007. A lot of software does not work with vista.
Mar 29, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
CAN I UPLOAD PICS FROM MY SONY CYBERSHOT W55 USING A SANDISK??
what do you mean nothing happens???
the memory stick pro duo should fit right into the sony cybershot....
if your struggling to load your photos onto your computer buy a universal memory card reader!
you should try and use a memory stick in a camera that needs an sd though!
Oct 16, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Can you use the PSP Memory Stick Pro Duo cards on your DC?
Yes! The Memory Stick Pro Duo's are one in the same. (Just out of curiosity, where are you finding them cheaper?) One note, however; as strange as this is, though the PSP plays mp4s, they will not play mp4s from a memory stick pro duo that comes directly out of your M1 camera... I've tried it, I have both a PSP and an M1. (The PSP will show off your M1 still photos, though.) Hope this helps! Susan
Sep 08, 2005 | Sony Cyber-Shot DSC-M1 Digital Camera
Sony Cyber-Shot DSC-S500 Digital Camera Logo
161 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
