Question about NewTek Tek Tricaster Live Production Studio TC0000000101
I am getting a gray screen when I booth my Tricaster. The only thing that I can see the the mouse on the screen. I restore it hoping to solve the problem but that did not help. Please advice.
Screen on Sony lap top fades to grey Touch pad and mouse not responsive
as for the lines its natural the camera is picking up the the pixels flickering. as for the mouse and your screen turning gray its either one of the following.
1. Motherboard is going bad or contacts inside are not centered(which means the mousepad isnt sitting on the sensor that picks up your finger)
2.you have disabled the mousepad via the FN keys on your keyboard
as for the grayness im not quite sure as i cannot see it via the video.
hope this helps
George :)
Nov 14, 2012 | Computers & Internet
Mouse has gone crazy,you click on arrow and it will keep on clicking,it start draging while crossing web page,it highlite every thing blue
Try booting up in safe mode then Restore your system back to a date and time before you came across that web page and started having problems.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.Click Start/Programs/Accessories/System Tools/System Restore
Select a Restore Point (date and time) that is before you started having problems. You don't have to use the restore point that is shown just select option to see more restore points.When System Restore finishes, reboot your computer.Report back and let us know if it is solved or not.
May 03, 2012 | Dell Inspiron 1521 Laptop
I have a sony viao and trying to do a recovery on it want booth are start in normal are safe mode
If you have not burned a set of recovery disks, I believe when you boot up you can get to the recovery partition. During the boot with the splash screen on (the thing that says VIAO in the begining), start pressing the F10 or F12 key. This should bring up the boot options and allow you to boot from the recovery partition and restore the computer back to factory settings. If you burned the disks for the computer, just place disk one in the drive and boot.
Hope this helps and it was what your were looking for.
Jan 29, 2012 | Microsoft Windows Vista Home Basic Edition...
1999 buick lesabre 3800,heater, notgetting hot enough. coolant flushed and thermostat replaced
Blow out your heater core hoses with compressed air. I had the same thing happen with mine, and i blew it out, and it solved my problem. :) Hope this helps. James Booth
May 18, 2011 | 1999 Buick LeSabre
Smoke from exhaust when start ls400 model1991 lexus color of smoke is gray it ends few second
the smoke is from engine oil, it is caused by leaking valve seals , after the engine is shut down for the day oil is leaking past the valve seals and getting into the cylinders then when you start up the engine the oil is burned off, this is a common problem, and there is a couple of things you can do to help the problem with out taking the engine apart and replacing the seals, try this first at your next oil change add some Restore to the engine oil it will soften the seals and give them a little more life, if this does not cure the problem after a few 100 miles then you will need to have the seals replaced, and this is a costly repair, but you could just live with the smoke it wont hurt any thing just keep an eye on the oil.
May 17, 2011 | Lexus LS 400 Cars & Trucks
I can't get any video out of the monitor output when I power up the tricaster studio
hi i have the same problem, What Can I Do ? my email altimallc@gmail.com
thank you!
Feb 21, 2010 | NewTek Tricaster Pro Live Production...
S-video and phono video outputs not working
will it feed in to the tricaster at all?? if it does not then check your input typer and make sure its set to s-video and not composit, if it is working then make sure your connected to the correct output, the tricaster has alot of them and honestly i could only get the one's on the first card to ever work, also try feeding into it from the output on the front.
Mar 02, 2009 | NewTek Tek Tricaster Live Production...
BLACK SCREEN AFTER START UP IN XP PRO
Hi you may try follow:
1) go bios setup screen set default configuration and save it and test same error go next
2) take out wireless card and test same error go next
3) reinstall winxp at same HD test same error go next
4) change a HD and install winxp test
nothing solved above is motherboard hardware trouble, need to repair
Dec 21, 2008 | Dell Latitude C840 Notebook
Every time i re boot my asus eee 700, the mouse sticks on the same thing and keeps saying moxilla - problem loading, the only way to get it working is to take it back to factory settings, please help,...
if you are using windows xp operating system.. you may boot in safe mode( press and hold F8 while the computer boots) and select safe mode and when you are asked whether you want to use system restore, select the last restore point created on your computer and follow the on screen instructions and restore your system to a previous date's configuration. if that doesn't solve, update your virus scanner and make a complete scan.. some trojan might be the culprit..
Mar 12, 2008 | Computers & Internet
Televison & Video Logo
105 people viewed this question
Top NewTek Televison & Video Experts
Are you a NewTek Televison and Video Expert? Answer questions, earn points and help others
