I have water running into my garden, from where noone knows. not getting any help from authorities, where do I go for help?
    Master:
  • 325 Answers
Your water supplier charges you for both supply and drainage, they are responsible for this.
Posted on Mar 17, 2011
Can't get tractor to move...forward or reverse. New to me and acts like it is not engaged in gear.
sadly noone can tell you or help when you do not include a MAKE , model,year
May 18, 2016 | Garden
Why would my 1 hp pump only maintain 45 psi running 1 garden hose?
Without knowing all your variables with well it is hard to say. Bladder tank needs to have 30 psi with no water pressure. It is possible that the screen down the well is restricted and you are only getting that much water. Or you may have clogged impeller in pump.
Sep 04, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
How to i flush a radiator on a 2000 expedition and what tools do i need?
you need, knife/ gear clamp,screwdriver /nut driver (for gear clamp) and garden hose
with water pressure hook up hot water is better
you can buy a can or to of rad flush but dishwasher soap works good (it wont suds up )
also rad flush kit with garden hose addapter (most kit are compatable)
1-drain existing coolant in container for recycling
2-locate heater return hose to block and cut to installed flush kit addapter
always better to reveres flussh system with engine off and rad cap removed
drain valve closed hook up garden hose and run hot tap water true system
it will eventually cove out your rad cap (surge tank) until it runs clear
know sut off the garden hose add your cleaning additives installed rad filler cap
run engine per direction on can or 10 to 15 min. sut off engine removed filler cap
open drain valve on radiator and drain out system open water from garden hose
run water until clean water run true shut off garden hose and removed cap off with
cap supplied with kit let system drain completly . repeat cleaning operation until
water runs clear
add 1 jug of concentrated coolant (will mix with ressidual water and finish filling
system with premix used recomended coolant only for your engine your freeze
point of new coolant should be above spec and will be fine
do not used pure concentrated coolant only .your ownners manual spec section will
give capacities system will hold
Apr 03, 2011 | 2000 Ford Expedition
I need help and i dont want to pay anyone can someone help me?
Whats the problem?? if noone knows than noone can help
Dec 31, 2010 | Nintendo Wii Console
Fountain pump motor runs but no pressure to push water
You can try to force prime with a garden hose. Put the hose in ether side suction or discharge.
Jul 07, 2010 | Little Giant Submersible Fountain Pump
I have a sim card but i dont know the telephone number
i have sim card but i dont know his number wht can i do
Aug 18, 2009 | Nokia N70 Cellular Phone
When I power up the roadmate 300 says there are not maps....the drive shows that they are there ? when I connected to computer with disk asked for authorization code.....would not let me enter one...called...
Unfortunately the authorization code comes from Magellan so there is no way for us as end users to bypass it. I would call back to Magellan and ask to speak to a supervisor or manager. Someone there has to be able to provide the authorization codes, tell them you have a very popular blog and plan to let everyone know just how horrible Magellan's customer service is unless they help you. It is ridiculous that they would be holding you hostage essentially like this. I wish I could provide you with the authorization codes but unfortunately it is tied to the unique identifier from your magellan unit, and the serial number of the map software, both things that Magellan can easily check, and then provide you with the code.
I would keep calling until someone gives it to you, that is simply not acceptable.
So sorry to be the bearer of bad news, but noone on here will be able to give you those codes, it is a manufacturer dependent thing.
Good luck, sometimes it just takes a little persistence, and like I said, make sure you are talking with at least a level one supervisor.
Jul 11, 2009 | Magellan RoadMate 300 GPS Receiver
When i engage the blades the tractor dies.the tractor is only a month old.
Do you have a service warranty?? If so I would call them and have them go through it. If not there is a switch under the seat that may be bad. It shuts the tractor down when the blades engage and there is noone on the seat. Check that and let me know..
Jul 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Amana ASD 2620HRZ side by side not cooling at all!
if all of that is running your ref. should be cooling.can you hear your compressor running?or can you hear it run for a few seconds and click.If you hear a clicking noise the relay to compressor has gone bad,if it is running then you have a leak in the sealed system.
Mar 08, 2009 | Amana ASD 2624 Side by Side Refrigerator
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
