Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
The plug on the bottom of the garbage desposal is loose and water is coming out
It sounds like the disposal is rusted out if water comes out the bottom.
Check top and sides to see if water is seeping down from the sink strainer of dishwasher connection.
Check tailpiece to see is drain is leaking.
If disposal is rusted, it has to be replaced.
I wrote ez steps from days I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Posted on Apr 17, 2011
How do I fix a frigidaire galarie dishwasher. The water will not drain out of the bottom
if you bought it new it is under warranty and if you do anything repair wise you void any you have left contact the seller
Mar 21, 2015 | Frigidaire Dishwashers
Tip
Garbage Disposal Leak from bottom of motor
If you have a garbage disposal and you find that it is leaking then you need to first of all figure out where exactly the water is coming from. The reason is that depending on where it is leaking from will determine whether it is easily fixable or if it would be better to just replace the entire garbage disposal.
With this is mind the best way to find the leak is to put the plug in place and fill the sink with water. Then place a food coloring or non-toxic dye into the water. Red often is a very easy color to spot under your sink. Then let the water down the sink with the disposal running. If the water runs down the side of the garbage disposal then you have a leak at the seal where the garbage disposal hooks up to the sink. This can easily be fixed by removing the garbage disposal, cleaning the old plumbers putty off of the ring and sink bottom, and then reinstalling the garbage disposal.
If you do not see any water coming down the sides, but it comes out the drain pipe, then the drain may be clogged and/or the seals for the drain piping are bad. The seals can easily be tightened. They may have come loose from the vibration of the motor or just the expansion and contraction that occurs from hot and cold water going down the drain lines. If the drain lines are clogged a garbage disposal safe drain cleaner can be used or the drain can be taken apart, cleaned and snaked.
If you have the dreaded water coming out of the bottom of the garbage disposal then you have the worst problem. The internal seals that are to prevent the water coming into the motor where the shaft goes through to the actual grinding chamber have deteriorated to the point where they no longer keep the water from coming into the motor. The water will make its way down through the motor and run out the weep hole or the reset button.
These seals are replaceable, but a new motor is needed for a complete fix on many garbage disposals. Because of this, many times the parts to repair this leak will be at least 75% the cost of a new garbage disposal. This makes repairing your garbage disposal, not a very good option. Replacing the whole unit is often the best way to go to make sure you have a fix that will last for a longer period of time.
That should cover all of the potential ways that your garbage disposal can leak. Hopefully you are able to pinpoint the leak and make the correct call to fix your leaking garbage disposal.
on Sep 23, 2010 | Kitchen Appliances - Others
Frigidiare galarie dishwisher
This sounds like a question already answered by another expert, where he mentioned that if the dishwasher is only 9 months old, that you should contact the seller, lest you void the warranty by trying to fix it yourself. That being said, I would recommend that you check the end of the drain hose where it goes into the garbage disposal, and make sure it is not plugged or clogged there. Also make sure that port in your garbage disposal is clear. If you just bought a new garbage disposal, be aware that they come with a molded-in plastic plug at the end of that dishwasher port, and you have to knock it out with a nutdriver (or some similar tool) and a hammer.
Mar 21, 2015 | Dishwashers
KUDS35FXss is dripping from the bottom of the door
Bad door seal drain plug not knocked out of garbage disposal other would be main seal at pump u can take bottom dishwasher off and watch were coming from if it's at door then door seal if still has water when done then check drain and disposal drain plug hope this helps
Feb 21, 2013 | KitchenAid 24 In. Stainless Steel...
My garbage disposal makes grinding noise, as if glass or metal is in it; I've checked and checked and see nothing; what could be causing this problem?
Thanks, Geno_3245. Another thing you may be able to try is this:
(1) find your "garbage disposal wrench" - an offset Allen wrench designed to be inserted int the bottom of the disposal which was supplied with the unit (in a little plastic baggie) when the unit was brand new.
(2) with poweroff, insert the whench into the bottom of the disposal and use it to manually turn the impeller around a few times an see if anything pops loose.
If nothing comes loose, its the bearing screaming before it dies, like Geno_3245 says... so start pricing a new replacement.
May 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
No lghts come on on the front panel
check breaker first. most homes have the dishwasher and desposal on one breaker. if breaker ok the home line going into the dishwasher may be loose. make sure the breaker is off befor checking this.
Jan 10, 2011 | Kenmore Dishwashers
Water standing in bottom of dish washer. Just replaced the garbage disposal.
You forgot to remove the round "Knock Out" Plug in your new garbage disposal. Check your new garbage disposal manual.
Feb 23, 2010 | Jenn-Air Dishwashers
Water is coming out the bottom of my Badger 1 disposal. Solution???
Check the fittings, the hoses could be loose... If the leak isn't coming from there then you have a seal leaking or a rust through that is causing water to leak and would need to replace the disposal.
Oct 06, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water sitting in the bottom of washer, and will not cycle
Check your vent drain or your Garbage disposer connection and make sure it's not plugged.
Nov 21, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Installation
It sounds like you have connected your dishwasher to a garbage disposal.
  1. The 2 hoses provided with your dishwasher connect together.
  2. You run the drain hose through a hole in the bottom/back of your cabinet, then up to the top of the cabinet, then connect it to the drain on the garbage disposal. (The reason that you run your drain up to the top of the cabinet is: This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.)
  3. Be sure to knock the plug out of the drain of the garbage disposal. A garbage disposal is designed to work with or without a dishwasher. The plug is in the center of the drain. The best way to knock this plug out is to pull the garbage disposal, and with a flat screwdriver, knock the plug out.
  4. Then remove the plug from the disposal. Reinstall the disposal.
  5. Install the drain hose. The drain hose will connect right up to the disposal using the clamp provided with the dishwasher.
This should help you. If not please attach more info.
Please rate this solution
Sep 09, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
168 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
