Question about Sentry Fireproof Safe
I have a Sentry Safe Model: PL048E and it wont open. Can anyone help me?
SOURCE: sentry safe V530
Send a notarized letter stating you are the owner of the safe with the serial number and a $8.00 money order to
Sentry Group
Attn: Dept 200,882 Linden Ave
Rochester N.Y. 14625-2784
Posted on Oct 23, 2007
SOURCE: Sentry Model 1610 Won't Open
I have a Sentry Model 1610 safe with an electronic lock. Entering the factory 5 digit code gives the green proceed light but the handle won't turn and the door won't open. How can I get the door open?
Posted on Sep 27, 2008
just keep trying and it will open. i had to try like 20 times the other day and it finally opened. good luck because these safe's are junk !
Posted on Nov 09, 2008
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
Have key and code...safe will not open
Sentry Safe not unlocking - YouTube
? 0:36
https://www.youtube.com/watch?v=4mbtSUAoS6w
May 8, 2013 - Uploaded by 1diazsantana1
When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
Jan 05, 2016 | Sentry Safe Fire-Safe .8 Cubic Ft....
I have a sentry safe model OS0810 and i need a factory code as I cannot recall my pin code
There is no 'factory code'. If there was anyone who knew it could open anyone's safe. You will need to take it to a locksmith. They will drill the door and put a new one on for you.
your safe here
http://www.sentrysafe.com/Products/230/OS0810_Electronic_FIRE-SAFE_
What they tell you if you have lost your combination. You may be lucky if it hasn't been changed.
Sentry Safe Lost Your Combination
Dec 09, 2015 | Home Security
How do I open sentry H4100 file safe
Proceed to watch this video link that I added. It will guide you on how to open your stuck file safe. HowTo Open Stuck Sentry Safe H4100 Others
Oct 19, 2014 | Sentry Safe Products Sentry Safe H4100...
Cant open my brinks safe model #5050
I need a replacement key for Brinks model 5050 key # 21
Sep 25, 2012 | Sentry Fireproof Safe
We have a Sentry safe model number SC 3877. We just changed the batteries. We are imutting the correct code, the light turns green but does not give the 1 beep and we cannot open the safe. If we put in...
http://callitout.com/quotes/index.php/kick-it-to-the-curb/55/sentry-fire-safe-wont-open-its-broken/
Its the most reazonable answer and it worked!!!!!!! dial the code and tap on the handle so it would get lose
Jan 16, 2011 | Sentry Fireproof Safe
I lost the combination to my sentry safe serial numbers 4895857 had it for 10 year geting kida old can you help
Sentry Safe lost combination. First, find your Sentry Safe's Serial Number. The Serial Number is printed on the small label on the right side of safe, on paper tag near bottom hinge, below the cover plate or you can look behind the handle with a mirror. Just note your model # and the serial #.
Sentry Safes express combination research is fast with a next day Service. The email is sent the next business day with the sentry safe combination and opening instructions. Although there is a service charge it's still cheaper then locksmith drilling a Sentry Fireproof Safe open.
Jan 29, 2010 | Sentry Fireproof Safe
Cannot open sentry safe, model 1230, have combo
cannot open sentry safe, model 1230, do not have combination
Nov 03, 2009 | Sentry Fireproof Safe
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
I have sentry safe that i bought with keys need reset combo
If there is a reset combination it's unlikely anyone is going to tell you otherwise you would have free access to any other locked Sentry safe. A locksmith who deals with the brand or Sentry themselves will probably be able to do it for you if it's possible.
Nov 25, 2017 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
564 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
