Question about Cell Phones
I just bought a new $30 dollar charger for my nokia phone.when i first bought the charger it worked for about a day and now its not charging at all.i pay alot for my bill and really need help for tmobil wont give me any answers
  • 112 Answers
I had the same problem with my phone,also 6303i classic.It cost me a new charger.Your second charger is faulty and try to use one for a test from one of your friends to see if your phone charges. If not, then the charger you bought is faulty.
Posted on Mar 17, 2011
My Lumia 520 is dead! It wouldn't charge, so I bought a new battery, the battery worked till it drained now it won't do anything. Checked the battery points & charger entry, don't know what else to do
Hi , you have to check that you might need a new battery charger. The new battery the bought had a charge then you used it up it sounds like your charger might have the light on but is not charging.
Dec 27, 2015 | Nokia 5700 Cellular Phone
NOKIA C7 WONT SWITCH ON HELP!!!!
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 26, 2012 | Nokia C7 (8 GB) Smartphone
My nokia e51 dropped in sea salt water ten days ago, I dried it and opened its cover under the keyboard and cleaned it , it worked very well for a whole week, the problem is now the battery is not...
The sea salt water has made the charging port corrode. So get a screw driver, open the phone and bring out the charging port. The charging port is where you put our charger. Use methylated spirit to brush the charging port and the panel where the charging port is place.
Dry it for 30 minutes and couple the phone and it will start working fine.
Regards
Sep 12, 2011 | Nokia E51 Cellular Phone
Problem with charging nokia 5800
If your phone was bought in the last 6 months you can go to nokia care center and demand for a new battery and charger or repair the existing ones provided you have the warranty card.You should get it done for free of cost.If 6 months exceeded then
Did u try another charger of the same mobile company,if yes ,and it works ,the problem is with your charger.You can either buy a new charger or get an all battery charger ,a china piece that recharges all batteries of any mobile company.You can get it below 2$ .
If your battery doesn't charge even with other charger of the same company then the problem is with your battery.If you are a nokia user ,here is the price list of all nokia batteries.
http://www.priceindia.in/mobile-phone/nokia-battery/
Sep 17, 2009 | Nokia 5800 XpressMusic Smartphone
NOKIA 5310 not charging? i already replace a new battery and check the power adapter,,(thanks for helping sir brukau747) and test the output voltage of my charger,,and they are all good,.any solution to...
Eventually the problem was internal hardware, the charging terminals has a problem and that's why you getting this error on your unit while you try to charge your cellphone,
You have an alternative to use a desktop charger in able to charge the battery, or you may bring the unit for repair.
Hope this helps
Sep 01, 2009 | Nokia 5310 Cellular Phone
Switch on!!!!
PLUG IN CHARGER AND SEE IF IT STARTS TO CHARGE IF IT DUSE NOT GET NEW CHARGER IF IT DUSE START TO CHARGE TRY TO TURN ON AS IT IS CHAGRIN IT SHOULD COM ON MAKE SHORE THAT THE BATTERY IS HOLDING A CHARGE
Jan 10, 2009 | Nokia 3110 Cellular Phone
NOKIA 6680 DOES NOT CHARGE
well the problem is in your phone hardware,probably the "charging I.C". try to bring it on a service center..
Oct 27, 2008 | Nokia 6680 Handheld
Sidekick3
The sidekick 3 has an issue with thte charging port. If you have a friend with a sidekick 3 or sidekick ID, try one of their batteries. If your unit powers on, the charging port has gone bad.
the repair for a charginf port runs about 80-100 dollars. A cheaper work around is to get a charging cradle that has a spare battery charger slot. They run about 30 dollars on ebay and it will allow you to charge the bettery seperate from the phone.
Check out the following link for cradles.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Mar 29, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick wont work
It seems your charger port is broken, it hapfens often on cellphones, wear and tear. Check to see if its under warranty, and it can be replaced. Check my profile if you need more help.
Jan 24, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Battery won't charge.
hello,
normally many cell phones requires 6-10hrs for its batter to fully charge up. also i have seen it where battery can be brand new but doesn't have enough juice to hold the charge.
now as far as red light on charger, remember even if you have 99% charged batter and you plug in the charger it will show you red light on phone/cradle.
FYI- all brand new phones are covered with 30 days of warranty replacement with new phone. after 30 days it covers upto 1 year from the date of purchase with refurbished phones.
In your case i think it is just the battery, try having your provider replacing new battery if no luck again then my suggestion will be to replace your phone with new battery with in 30 days.
TY
Dec 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
