Question about Hotpoint Washing Machines
My hotpoint washing machine model wm72 ultima 1200 on the sreen it comes up asking to check dischare hose having done this several times it keeps comeing back to check the same thing the hose is not blocked or twisted as the machine was working ok until just recently any thoughts regards simon
    Passionate:
    Visited the website for 10 consecutive days.
  • 114 Answers
Simon, i would take a guess on the sump being blocked up.
remove rear inspection panel, you will see the drain pump on the left with a black hose coming out of it going up and attaching onto the drum by a clamp.
tilt the machine forward and put a basin underneath. using pair of vice grips remove that clamp and pull the sump down and off. hopefully this will be full of debris, clean out and put back together.
should do the trick.
great old machine that, wont get one like it again.
Posted on Mar 17, 2011
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error 15 on a Hotpoint WM72 Washing Machine
The problem is your pump or filter is blocked,
Remove rear cover of washer, and remove large black hose from tub, remove and clean filter inside hose, check for a blockage in pump, refit filter and hose, and it should now be o/k.
Please rate my solution.
Thanks.
Jan 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Jan 17, 2009 | Hotpoint Ultima WD72 Front Load...
No handbook
Try finding the handbook in here, if that is not available call them by phone.
Check also WM72 Quick Guide.
Jan 15, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima 1200 Wm72 Erroe E14
I think you will find that the error relates to the heating element.
E14 on the Hotpoint WM75E means that there is a problem with the water heating.
Jun 05, 2008 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT ULTIMA 1200 WM72 Error Code
f30 code means there is a problem within the motor curcuit,check connections at the motor and check motor brushes are not worn.
May 05, 2008 | Hotpoint Ultima WF860 Front Load Washer
ERROR MESSAGE ON SCREEN STATES CHECK OUTLET PIPE E15
It probably needs a new Pump, the wm72 has what they call a magnet pump and they can give false readings to the programme. Anew pump will cost sround 20 GBP. For an engineer to do it will cost around 50 GBP.
Nov 18, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint 1200 wm72
its your heater element that is faulty more than likely will need replacing m8
Aug 08, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima 1200 wm72
code e30 means motor fault. this can be just motor brushes, tacho fault or module fault. can't narrow it down more than this - you will have to dive in and check
Apr 05, 2007 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
63 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
