Question about Royal PowerWriter Typewriter
WHEN THE TYPEWRITER IS TURNED ON THE PRINT WHEEL CYCLES THEN THE MACHINE JUST BEEPS AND DOES NOT ALLOW ANY FUNCTIONS TO BE DONE (NO TYPING, SPACING, ANYTHING). CANNOT USE THE MACHINE AT ALL.
  • Royal Master
  • 3,594 Answers
There is a very good chance that trere are broken wires in the carrier wiring harness about 1' from the L. side or the print head.
DickyO
Posted on Mar 17, 2011
It stuck and make a buzz noise wrong character
Your ribbon may be stuck check it out, buy the way I bestow the sacred order of thee nomenclatcher Maximus for bestowing the information that is actually need in great detail, you would not beleive how non- descript some people are ie My typewriter doesn't work right? After a good public flogging I may get some information out of them, well done! Bret PS, It's rare but you may have popped a drive gear with power off, and unplugged try and move the print carriage (gently) back and forth it should move with about a Pound of resistance and not catch or sound crunchy, fluid motion will tell, good luck.
Mar 06, 2015 | Brother GX6750 Daisy wheel electronic...
During typing, daisywheel spontaneously readjusts itself and then the machine beeps and will not continue. Will it be expensive to fix? Ballpark cost?
Daisy wheel is kind of old school nowadays, you might have to go to a office supply store like staples etc, to possibly get it fixed
Feb 11, 2015 | Swintec 2600 Typewriter
Letters to close
The pitch (spacing) is set by the print wheel. 10. 12, 15 or PS.
the only way to change thr spacing is to change the print wheel.
DickyO
Feb 07, 2014 | Lexmark Wheelwriter 1500 Typewriter
How to solve a problem with an IBM Wheelwriter 10 Series ll Model 6783
It is most likely a bad keyboard. You can try my fix under WW1000 or contact Geo. Beyers Co. for a rebuild.
DickyO
Feb 28, 2013 | Swintec Ibm Wheelwriter 10 Series Ii...
Typewriter ,brother ML100 STANDARD : I CHANGED THE DAIZY WHEEL AND PRINTING REBBON. THE PRINTER IS NOT COORDINATE WITH TYPING KEYS WHEN I TYPED. EXAMPLE , IF I TYPE B , A DIFFERENT PRINT INSTEAD .
Turn the machine off and allow it to rehome itself. If that doesn't help the printwheel homing pawl is probably broken. you will need a tech.
DickyO
May 04, 2011 | Brother GX-6750 Typewriter
When I turn on the wheel riter 3500 it beeps 6 times, the ribon cycles but it won't go to left and reset and type. Seems like a board problem
There are a lot of possibilities. Look for debris on or under the boards, unplug and replug the keyboard, If all fails, take out a battery and turnoff the machine, wiat 30 sec and turn back on.
NOTE THIS WILL CLEAR THE MEMORY AND RESET ALL FUNCTIONS TO DEFAULT!!!
DickyO
Jan 22, 2011 | IBM 3500 Typewriter
BROTHER GX-6750 TYPEWRITER
change CASSETTE DAISY WHEEL,
Jun 24, 2009 | Brother GX-6750 Typewriter
The spacing lights
Check to see that the printwheel is properly installed, then check for debris in the P/W area.
DickyO
Mar 26, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
When typing, a letter is hit but a number is being printed. Typewriter is a Brother CE-500 model. We think you need to use the "Code"function but the manual has been missing for some time
Turn typewriter off, hold down CODE, turn machine back on.
Make sure you are not set for PROPORTIONAL SPACING.
Remove print wheel, turn machine off, reinstall print wheel, turn back on.
Nov 25, 2008 | Brother Office Equipment & Supplies
Royal PowerWriter Typewriter Logo
115 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
