Question about Sony Handycam DCR-TRV460 Digital Camcorder
I have a SONY Digital video recorder model #DCR-IP7 that junst started playing the tapes all choppy. It might need cleaning of something needs repail don't know.
  • christianhes Sep 28, 2008
    When i replay my tapes on my camara it ia choppy and kinda skips like a cd player so i tried a 8 mm cleaning tape and it didn't work do i have to get it clean professionally and if so where
  • Sony Master
  • 2,794 Answers
You can try running an 8mm cleaning tape.
Posted on Aug 02, 2008
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In...
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Dec 03, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
Handycam DCR-TRV22 Records Audion no Video
Need go buy a cleaning tape from any local retailer and play for one minute. Video should comes back up.
May 10, 2010 | Sony Handycam DCR-TRV22 Mini DV Digital...
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
Video and audio play back is choppy
OK, yes, it probably does relate to a tape tracking problem, but does knowing that help you out at the moment, I had this same problem and I scanned for solutions and somewhere I seen this remedy and it worked, remove the battery and take your open palm and give it a sharp rap at the bottom rear corner, a good solid one but not enough to damage the cam. Hope it works for you.
Jun 21, 2009 | Sony Handycam DCR-TRV103 Digital Camcorder
Sony DCR-TRV33 not recording well
Use Sony Video-8 Head Cleaning tape to clean video head of camcorder that seems dirty / clogged and causing mosaic noise in picture.
Apr 02, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Sony DCR-TRV510 Playback Blank or Choppy
I recently had similar problem. Sony Phone tech support was very helpful. The answers were strange. You need to make sure the cameral is turned off, unpluged and take the battery out for at least 5 minutes. (something to do with reseting firmware). That sort of worked when coupled with there last comment which was to RECORD about 15 seconds and play it back. Mine was instantly healed!
Jan 13, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
Playback choppy
Camera needs Tape Path adjustment and qualified camera tech person can do the job.
Nov 06, 2008 | Sony Handycam DCR-TRV265E Digital...
Sony TRV510-playback, audio choppy, image isn't clear
I was having the exact same problems, and I read a post on this website somewhere recommending that I just record a few seconds of video on a blank portion of tape and then the camera should start playing video normally again.
I tried it, and IT WORKED!!
Jul 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Sony DCR-HC42 Partial Screen Display
Sony has had some CCD problems with this and other model I think it is important to contact Sony at 1-866-703-7669
Nov 05, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Playback is choppy
I had this problem very recently. In fact I borrowed camcorders from my friends too and after short periods, they too started having the same problem. Essentially, it looks like there is some choppiness every second or so - like there is noise in the audio and video. After a lot of looking around, I finally found a suggestion posted that ACTUALLY WORKED on all 3 camcorders:
I placed an empty tape in the camcorder and recorded a few seconds into it. Then I removed that tape and tried to play the previous tapes that were showing the choppiness. No problems any more. Everything works fine.
What I still do not understand is why 3 camcorders (all DCR-TRV103s) all showed the same problem (with different tapes by the way). And since I still have lots of tapes to copy, I need to know why this problem is happening so I can minimize its occurrence while I complete the copying process.
People have suggested that my tapes are old and may be offering resistance to the camcorder. So I have ordered a rewinder to spin the tapes a bit before trying again. The two possibilities suggested around this was (1) some mechanical switching took place which got reset when recording; and (2) something got corrupted in the software that manages the playback buffer and that software was rebooted when it went to recording mode.
So while this will hopefully answer your question, I'm also looking for explanations for why this happened to me on 3 different camcorders.
Oct 05, 2007 | Sony Handycam DCR-TRV260 Digital Camcorder
Sony Handycam DCR-TRV460 Digital Camcorder Logo
154 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
