Question about Xerox Phaser 7760DN Laser Printer
Hi, Having a problem with our Werox Phaser 7760 - there seems to be a white line on the black running the length of the sheet - have changed the toner, transfer roller and imaging unit to no effect. When you take out the imaging unit and shine a torch into the machine, there seems to be some sort of magnetized roller and you can see a mark running round it at the position of the mark on the sheet. Can this roller be removed or cleaned or something? Thanks for any help in advance. Lee
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
If the white line only appears on a signle color (black) then it has to be either the image unit, laser, or developer. You can try cleaning the top of the laser using the arm located in the front door, because toner ofter spills onto the laser window causing white streaks. However, Judging by your desription the part you are referring to is the developer. You can attempt to clean it if you can reach it or replace it. The assembly is part# 802K60191 and you must also purchase the devloper charge (black) part# 604K22550. This isn't a very easy fix, so if you are not very technical you may want to bring it to a copier technician. If you wish to fix it yourself and order from ItemIncOnline.com they will send you instructions with it. If you are still confused call 1-800-367-4836 (free tech advice, specialize in this machine) Hope this helps. - Steven
Posted on Apr 05, 2011
The accumulator belt on my 7760 phaser is giving a past end of life message. How can I find out how many copies it has remaining?
Try printing the full status sheet. If you print out all the setting it should cover all the information you need to make your judgement.
Good luck.
Mar 26, 2015 | Xerox Phaser 7760 Laser Printer
Xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 776
When you have a sensor failure, you need to replace the black ATC sensor and recalibrate it. Another reason for sensor failure is you are not getting toner moved down to mix with the developer...the toner tube/auger spring could be clogged up or not functioning.
Also if you changed the developer housing when you changed the developer, you need to change the value to the new sensor # that comes with the housing.
Feb 16, 2014 | Xerox Phaser 7760DN Laser Printer
I have a hp officejet pro 8500a and it has started leaving a black line on all copies when the original is fed thru the ADF. What is causing this??
Hi, Change first black color print head cartridge just open cover then replace black print head cartridge.close cover wait for ink cartridge reinitialize if ready print test again.if same print having black line all copy needs to replace also black ink cartridge.
Jun 30, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Phaser 7760 Error message: "Imaging
The black image unit of your machine should be replaced soon. It is a maintenance item and is very easy to change. They cost about $350 new, but you can buy one much cheaper rebuilt. Here is a video I made to help explain what it is you need to change and how to do it. Good luck
Nov 16, 2010 | Xerox Phaser 7760/YDX Laser Printer
Phaser 7760 dirty printing
Dear User,
This is a common problem of all laser printers, don't worry i will give you solutions for this. If you can able to remove the DRUM set from the printer and check that any power leak or not, IF yes clean it well and insert into printer again take a printout , afterthat also coming like dirty. So please change the drum and put a NEW DRUM. Your drum capacity is crosed beyond the limit.
I hope that my suggession will helpful to you, if yes please rate this ...
Feb 27, 2010 | Xerox Phaser 7760/GX Laser Printer
Phaser 7760 only prints using black toner (no C, M or Y)
did you try adjusting the settings on the printer driver itself as in go to printers and faxes....right click on the printer and left click properties........under the advanced tab choose printing defaults and change the settings on the printer driver
Nov 05, 2009 | Xerox Phaser 7760DN Laser Printer
Printer lines
did you check the drum? it could be coming from the drum blade.
Jul 17, 2008 | Xerox Phaser 7760/YDX Laser Printer
Xerox Phaser 7760DN Laser Printer Logo
210 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
