I am looking for a device that cuts off the power to a disco when the decebel level gets too high in a public hall. I know that there is something on the market but don't kn ow what its called
  • 3,400 Answers
It's called a compressor/gate. Check w/local Guitar Center then offer a range of them.
Posted on Mar 17, 2011
My 2007 kia cerato deisel speedometer stopped working, is there a common fix for this , are they fitted with speed sensors or cables im just a baffled pensioner can anybody help
you meant Sorento, right>? or i tell you wrong.
speedo and Odometer dead? a key point. in most cars.
check all fuses first , those facts are in the glove box opr. guide.
RTM on fuses
alldata.com $15 to look in the FSM for 30days.
is that too much? $$, say so and ill look for you. ok I did... just now.
keep in mind most cars 2007 an newer are NASA level complexity ,looks like MIL equipment i cut teeth on..
(things talk to each other, and diagnosis can be complex with out the factory scan tools. (CAN bus tools)
btw, im retired too. retired, electronics, tech.
did you know most pub. libraries have this books or esources?
you can go to mitchells fantastic service for free in my LIB.
diesel. wow. ESP, wow2,seat warmers, and 100s of pages on electrics. vast complexity,
IM ONLINE NOW>looking at your dash drawings.
7 pages just on the cluster
ok on page 5 is the MICOM unit, its in the dash, l/P cluster
and is has a Hall sensor called a speed sensor.
this device sends speed to many places not just the dash
to PCM , to A/C controls (cruise)
there IS no CABLE, those were Olden days.
so which is bad.?
easy
scan car moving or with one drive tire off pavement, in drive.
use the scan tool see if MPH reads right. (test 1) afterfuses.
if reads right , the HALL sensor is working.
if not its bad.
Any scan tool works, even a $7 scan tool to see RPM, and SPEED
and all std, scan data.
if the HALL speed sensor reads right scanned then the IP gauge
is bad, the Micom unit and im sure that $$$ to fix.
my guess, is you are flummoxed now.?
it can be wire fell off, or corrision in any connector related to that HALL sensor. btw 2 the sensor is on the drive axle to measure
tire RPM, and coverts that to MPH.
Oct 23, 2013 | 2001 Kia Rio
Tip
I get error IE on my LG dishwasher.
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
on Jan 31, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Drivers disco duro hp pd 500a
http://h20565.www2.hp.com/portal/site/hpsc/public/psi/home?sp4ts.oid=5179191&ac.admitted=1401035468572.876444892.492883150
Feb 09, 2013 | EliteGroup ECS H61H2M2 Intel H61 Sandy...
95 pontaic bonneville intermittant loss of power
Could be crank sensor , ignition module and i wouldn't rule out the PCM . But before you start replacing parts test these componets . If you don't have diagnostic skills or a lab scope i suggest you take to a qualified repair shop that does . Hall effect cam crank sensor operation and testing Part 1 an SD Premium...
Hall effect cam crank sensor operation and testing Part 2 an SD Premium...
Apr 02, 2017 | 1995 Pontiac Bonneville
VW CADDY 1996 KEEPS CUTTING OUT
It is possible that the float level is set too high or even that some part of the air cover assembly is putting on something. It sounds strange that the engine seemed to run alright with the cover removed. It's possible that it could be a combination of things and you would have too know what to look for.
VW engines especially.Regards
Feb 20, 2012 | Cars & Trucks
VW golf cabriolet do not give petrol. The petrolpump is ok...? Codes are checked (problem, HALL something, but has it something to do with the petrol?
I suggest you do a fuel pressure and volume test also.
But first, you need to ensure you have good spark. Make a spark tester by gapping an old spark plug to 0.200" and sticking it on a plug wire. Lay it on a metal ground and crank the engine over and see if there is spark. If no spark, then the problem may lie in the ignition system.
Check for battery voltage at the positive side (15) of the coil with the key on. If there is no voltage check the yellow wire from the ignition switch. If there is power there you have a break in the wire somewhere in between.
If you have power to the coil, stick your spark tester in the end of the coil wire.
Then, with the key on, hook a jumper wire to the negative (1) side of the coil and MOMENTARILY ground it. If you get a spark, then the Hall Effect sensor in the distributor is either bad or not getting power.
At this point I would recommend getting a Car Service Manual from the reference section of your local public library. It has a more detailed testing procedure for the testing the Hall Effect sensor and ignition module. It is much too long for me to describe here in this forum.
Good luck...
Sep 30, 2011 | 1994 Volkswagen Golf
HOW DO YOU TURN DOWN THE HISSING NOISE
You can cut the treble gain some BUT most importantly is to send adequate signal to this speaker so volume level does not have to be set high when sending LINE LEVEL signals to it. Hissing noise is a product of the statistical noise that occurs in electronics. Running any device at high gain invariably brings up the hiss level. Managing thee signal levels is the responsibility of the sound engineer.
ALSO feed ALL interconnected equipment from the same receptacle or power source, even if it means running a power cable to a mixer alongside the snake. ALWAYS USE BALANCED audio cables whenever possible.
Dec 24, 2010 | Samson Auro D415 - 2-Way Active Speaker...
Light in one sections will not go on with the switches (2) at both ends of the hall, but all house on lights the hall but all off will not turn off the lights. also cutting power and turning it back on...
I answer questions for free.
I know electric wiring and can help.
But you need a better explanation.
What are you doing?
Did you replace something.
What device did you put in?
Is this a 3-way device at one end of a hall?
And I'm a little unclear about " all house lights on light the hall but all off will not turn off the lights'
If you add a comment I will answer
Oct 30, 2010 | Lutron ELECTRONICS CO. Q-603PH-WH "QUOTO"...
Need to set low level on my compressor
That would depend on the type of pressure control switch it had on it, but all of the ones I've ever seen have it near the high pressure adjuster under the pressure switch cover- VERY HIGH VOLTAGES- RISK OF INJURY OR DEATH- UNDER PRESSURE SWITCH COVER WITH UNIT STILL CONNECTED TO POWER-
On the common switch used (A condore mdr 5) the differential is adjusted by DEPRESSING the nob & turning it.
On MDR 4 the adjuster is directly behind the high pressure adjuster. it is a flat bladed screw attached to a spring-screw in to increase cut in pressure.
You can also get pressure switches with a higher cut in pressure.
In Australia from a company called Ross Brown Sales in N.S.W
Hope this helps
Regards Andrew
Jul 17, 2010 | Ingersoll Rand Type 30 Fully Packaged Ir...
Lost manual..do not know what is the difference sound surround
Hi use this link to download the manual .
manualnguide.com/manual/teac-ag-v8060-receiver.../page/2/.
Take care.
May 18, 2010 | Teac AG-V8060 Receiver
20 people viewed this question
 Grubhead
Grubhead
