Question about Danze Sheridan Tub & Shower Faucet
How to remove cartridge for soldering - Danze Sheridan Tub & Shower Faucet
  • 86 Answers
Pull handle...unscrew big nut and pull straight out...may take some force...reinstall hot side to left...after cooling...turn on water test for leaks
Posted on May 22, 2014
I have moen #3330 shower unit.All is installed but cannot get water to flow. What do I need to do???
First I would check that there is no debris stuck in the valve. In most cases if this is a pressure balanced valve if either the cold or hot water side does not have pressure the valve will not function. When installing the valve was it soldered in? If so was the valve cartridge removed when soldering? Was the valve body flushed after installation before the valve body installed if removed during installation? That model has plastic valve cartridges which are very sensitive to heat and must be removed before soldering.Also the valve body has intergal shut offs make sure that they are turned to the on position for both hot and cold. As I said above being that this is a pressure balanced valve water pressure must be available from both hot and cold. If either hot or cold has less pressure then the other the valve will balance the pressure to be equal, this is to prevent scalding.
Sep 29, 2014 | Moen 3330 Moentrol 3-Function Built In...
My gameboy color wont save is that the gameboys problem or the games??/
Hey there,
On the gameboy, the various game saves are always stored on their respective cartridges. Therefore, if the game won't save for whatever reason, it is the game's fault, not the gameboy's.
Hope this helped!
Jun 30, 2011 | Video Game Consoles & Games
Jensen MCDA1 10 CD Changer - CD cartridge will not eject.
Had the same problem. It's the microswitch/eject button-reset. The wires were-soldered.works fine.you actually have to remove the switch to inspect the soldering.
Jun 11, 2011 | Jensen MCDA1 AM/FM/MP3/ Stereo with...
When installing a shower temperature control valve should the cartridge be removed before soldering to copper pipes
Yes you need to remove the valve befor you solder the copper pipes on it. If you do not remove the valve you will melt it to the valve body and then it will not be useable.
Mar 02, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Is there a way to open up a Shure Beta 58A?
Once you remove the grill, there is a C-Clip that holds the cartridge down into the handle. Use some c-clip pliers to pull the c-clip out of the handle. The c-clip will remain around the post on the cartridge, but that's ok.
Feb 27, 2010 | Shure Beta 58A Professional Microphone
I have a Thorens TD280 Mk IV, and after 15 years am trying to replace the phono cartridge. Unfortunately, in removing the old cartridge from the four contact pins at the rear of the cartridge, two of the...
They will have to be re-soldered, there should be enough length on the wires to do this. To avoid stress on the wire, just melt a little insulation off at the end in order to strip, rather than using a knife. This will make a mess of your iron tip, so it should be cleaned before soldering the clips back on.
Jan 16, 2010 | Audio Players & Recorders
Moen single handle bathtub faucet
Something is caught in the stem. Make sure the stem is free of debris. Also check that the valve or cartridge is intact.
Jul 02, 2009 | Moen 2919 Chateau Two Handle Tub and...
Ds lite pins
From outside is pretty difficult to straight the slot 1 pins as it is small and you need very thin pliers and light source plus lots of patience.
With a plier you can straight the bent pins to its right position, but make sure the pin is not out of its place as all the pins are V wedge shaped and the pin comes from the slot bottom, the edge fits in a small hole then goes up to make contact with the game cartridge contacts. No one stay out when inserting a cartridge or you'll have a bigger problem.
If there are many bent pins I find more easy to open the DS, desolder the damaged pins and pull em out of the plastic enclosure to repair it, put it in again and re solder. No one option is easy... Sorry...
Nov 16, 2008 | Nintendo DS Lite Console
Sega Master System Cartridge Issues
I found out what was wrong. The all of the solder connections where the cartridge slot pins meet the board were broken. I was able to verify that this was the issue by pressing the connections together while trying to boot up with a cartridge and it working. I will just need to get a fine tip for my soldering iron and some really small gauge solder.
Mar 31, 2008 | Sega Master System Console
Danze Sheridan Tub & Shower Faucet Logo
101 people viewed this question
Top Danze Home Experts
Mike
Rabbit Brains
Rabbit Brains
Mike Herrington
Mike Herrington
Level 1 Expert
Are you a Danze Home Expert? Answer questions, earn points and help others
