Question about HP Officejet 5610 All-In-One InkJet Printer
Have error code: cartridge on right not intended for this product. It's the same cart I've always used, but hadn't been active in a couple of months. Usually this code means you have moved overseas, which I have not. Any suggestions?
  • 10,515 Answers
This printer is in limelight for many wrong reasons. You need to follow the below troubleshooting steps given by HP :-
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=vn&docname=c00249451
If the problem persists, repair would be on the cards. On most occasions, if you call HP for this error, they would ask you to follow the above mentioned steps in the guide they already published and if the problem persists, they would offer you a new printer in lieu of this printer.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 17, 2011
Printer keeps flashing print cartiagein right not supported..alos comes up on screen stating cartiage on right side is not intended for this printer. I have been using this cart. for awhile now it is the...
There is a problem with the computer sensor in the ink cartridge. That is what is causing this error that you are seeing. Is it a refilled cartridge or did you buy it new from the store? If you bought it new and it is doing this, then take it back to the store and tell them it is a defective cartridge and you want to exchange it for a new one. If it is a refilled cartridge and you bought it from an ink store, take it back to them and tell them that the sensor is failing. They will replace or repair the sensor and then the cartridge should work properly.
Hope this helps?
Nov 08, 2010 | HP PSC 2355 All-In-One InkJet Printer
Error #12 Shows on my lexmark x4270 all in one how do i clear it
Hello there,
In my experience I've never come across an error #12 on a X4270. I've seen an error 1200 & error 1203 a couple of times. Did you get this error after installing a new cartridge? then there are chances that the new cartridge that you installed is defective. The best way to figure if out is to take both the cartridge out and power recycle the printer with the cartridge out. Check out if the operator panel says "cartridge missing" when it is powered back on. If it doesn't say "cartridge missing" then the printer hardware is defective. You would need to get it serviced. If the printer comes up with "cartridge missing" message, then either one of the two carts that you have is defective. I would suggest you to insert one cart first and close the cover and check if it says "cartridge missing" If it does come up with that message then insert the other cart too.. If you get Error 1203 on after inserting a cart, then that cart is defective and needs to be replaced.
Merry Christmas!
Dec 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x5495
Lexmark advertises the cartridges supplied with this printer as cart. #28 and #29. They claim these are nonrefillable. The refillable cartridges are #28a,29a, 34 and 35, the last two being the high yield carts. Make sure you have one of these.
Mar 29, 2008 | Lexmark X5470 All-In-One InkJet Printer
Error message on Canon Fax Machine 2050P check cover/cart
there are a couple of things did you buy genuine or reman cartridges and check if they are seated properly.
some remans dont work properly so you have to be sure and always get a money back guarantee from the seller
Feb 26, 2008 | Canon FAX-L350 Plain Paper Laser
Error 1203
Are you using a refilled cartridge1.gif or refilling your cartridge yourself?
Error 1203 is an issue that occurs either when a cartridge is bad or the printer1.gif cartridge Slot is bad... Try to cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work, then you might try a new black cartridge and possibly a color cartridge too.
Hope this helps.
Good luck.
Mac
Please remember to post a feedback and or rating if my suggestion has helped you fix your problem.
Note: Refilling carts may damage the contacts of the carts as well as the printer (From a printer companies website)
(repeating this message again, for some reason this site logged me off and It didn't give me credit for the post)
Mac =)
Feb 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
New ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Jan 28, 2008 | Brother Multi-Function Center MFC-240C...
"Install Yellow" Error - Machine is frozen.
Check all other carts. It might be that one (or more) carts are empty, too. Thats why the machine refuses to work properly.
Unplug from power, wait  two minutes and replug again.
If it doesnt come up correctly the maincircuit baord might be defective due to a defective electrical part.
Do leave the machine always on power connection. You can turn it off by pressing the stand-by-fax button, but you have to keep the machine with power supplied. Set date and time. The machine runs some automatic cleaning cyles every 20 days to keep the nozzles alive and that prevents the permanent ph from drying out!
Dec 31, 2007 | Brother MFC 240C All-In-One InkJet Printer
Inputting new ink cartridges
Error 1102 means cart error. Try cleaning the copper contacts on the cart and the contacts in the printer also. If still fails, then put old carts and check if u still get same error. If u dont get the error then there is a problem with the cart itself. But if you have bought a refilled cart then the print heads on the carts are bad. Needs replacement.
Sep 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
Error code
hi peepz,Just to share CANON MP800 Error CODE 6502:I have been using INKRIS.com CISS system for years now until this stupid problem came up.to further clarify,
1)Lift the Lid.
2)switch off the printer by pulling out the plug.
3)then shift the ink cartS to the right.
4)close lid,plug in power.
5)HOLD DOWN power button then press STOP/RESET button twice.
6)Then press STOP?reset button 4 times.
7)the screen on MP800 will go white.with SPF test mode Idel written on it.
8)then power off and power on again.
THANKS for SAVING MY PRINTER!
Dec 12, 2006 | Canon Pixma MP500 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
