Question about GE Hotpoint Top-Freezer Refrigerator
GE refrigerator warm freezer cold
My GE TXB25PAYGRWW is not cooling well in the fresh food section (60 deg F) but is cold in the freezer section ( about 10 deg F) . The back of the freezer section is iced up . Should I defrost then try again before delving into checking the defrost timer and defrost heating . How do I get to thos componests on this model . All help is welcome - Thanks
  • rkpatt Aug 03, 2008
    GE TBX25PAYGRRW warm fridge,cold freezer (defrost heater fuses ?)
    I have checked the defrost thermostat (warm and cold ) and defrost
    heater and both are OK. However I was not getting power (even with
    defrost thermostat shunted ) to the terminals of the defrost heater and
    was puzzled until I found the wiring diagram inside the panel that
    housed the defrost control ( defrost timer ). After looking at the
    wiring diagram I noticed that the wiring pigtals to the defrost heater
    for this model are fused so now I guess have to cut them and and check
    for continuity . If fuses (or fusible links )are blown, I guess it is
    pretty safe to presume that the problem is limited to defrost heater ?
    Any other suggestions are appreciated .
    Thanks
    Guru:
  • 462 Answers
The freezer section has the only cooling coil. It sounds like it is blocked with frost and thus wont let the air circulate from freezer to refrigerator.
There is a defrost timer, (or board), a defrost heater, and a defrost safety thermostat. Any One of these or a combination of 2 can be your problem. If you have a energy efficient model that has electronic controls then you will have a board. The procedures for checking the circuit on a board vary by manufacturer of the board used and manufacturer of the appliance.
The defrost heater always has resistance and is attached to the freezer coil.
The defrost thermostat is also attached to the heater electrically, unless it is an electronic sensor type. Sensor types have a range of resistance that needs to be known to check and varies slightly with the temperature of the sensor.
If I haven't lost you here you maybe equipped with the life experiences that will allow you to do most of these checks. If its over your understanding I recommend you contact a reliable technician.
If this helps you please rate me as high as you can and thank you for using fixya.
Posted on Apr 17, 2009
  • 1 more comment
  • Farley Redfield
    Farley Redfield Apr 17, 2009
    refrigerator.
  • Farley Redfield
    refrigerator.
  • Farley Redfield
    refrigerator.
My Model #gts22wcp fridge stopped getting cold. freeezer works great. Only blows cold air into fridge if freezer door is open.
Possibly a problem with the defrost system. If the cooling coils behind the freezer wall start to build up too much frost or snow, the air flow to the refrigerator section gets blocked first. So the freezer still works but the fresh food section starts to get warm . As the frost continues to build up, in time the freezer section will only get as cold as the fresh food section should. There are 3 main parts to the defrost system. You could have a burned out defrost heater, a bad defrost timer, or a bad defrost termination thermostat. The heater is located directly under the cooling coils in the freezer. The termination thermostat is a silver round disk clipped to the top of the same cooling coils, and the timer in located in the control panel in the fresh food section.
Apr 02, 2016 | GE Refrigerators
CSX22GRZAWW freezer works, refrigerator warm
Damper problem.
This ice box has a damper which is controlled by a thermostat. When the fresh side be warm that damper opens and allows cold air to enter the fresh food section. It must be gone out. it is what i would check.
Jun 12, 2012 | Hotpoint HSS25GFP Side by Side...
My GE Refrigerator (GSS25TG) is too cold in the freezer section and too warm in the refrigerator section. Most food is spoiling within a day or so. Any suggestions?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 18, 2011 | Refrigerators
I have a GE refrigerator GFSS6KKYSS Model. Serial #: LS900091 It appears that there is ice on the back of the refrigerator and water is collecting on the floor of the compartment. What is the problem and...
This is a rather unique refrigerator in that there is a seperate evaportator (cooling coil) for the refrigerator section and the freezer section, where as almost all other refrigerators only have coils in the freezer section and use a fan to blow some of the cold air into the refrigerator section. This design will prevent cross contamination of odors between fresh foods and freezer sections, and allow lower humidity freezer at the same time as higher humidity fresh foods. All good things.
That said,..... you need to take the cover off the back wall from inside the fresh foods section and thaw out the defrost drain locted at the bottom of those cooling coils. If I remember correctly, there are a couple hidden screws, and the back panel needs to be pryed off using a putty knife, I think you will find 4 small arrows / pointers for the spots to pry at. With cover removed, use a turkey baster with warm water until the water flows out the drain.
Apr 03, 2011 | GE GFSS6KKYSS
Why does my ice cube maker quit working and temperature in freezer is the same as fridge.
ice maker will not work if freezer is too warm . it must be 15 deg or lower and if fresh food is that cold then the food is frozen. the freezer needs to be 0 to 5 deg and the fresh food side 38 def is best . / you may be having a defrost problem and the cold coil is packed with ice and prevent ing air flow .. ck for ice in back of freezer .. mm
Oct 22, 2010 | Amana Refrigerators
Feezer cold frig.warm
sounds like your freezer is not defrosting, causing lack of air flow to fresh food side
May 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Temperature does not go below 59 deg. refrigerator side.
Auto Damper models, The Auto Damper model refrigerator has
two controls and both have capillary sensing.
The Auto Damper controls the fresh
food temperature and the Freezer Temperature
Control guides the freezer temperature.
The fresh food compartment temperature
is maintained by a damper assembly located
at the back of the temperature control
housing. Changes in air temperature
cause the damper door to open and close.
A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the
COLDEST position increases the flow of
freezer air into the fresh food section. The
freezer compartment temperature control
warms at a faster rate and cools at a slower
rate, increasing the compressor run time
necessary to maintain a satisfied freezer
temperature control.
Turning the fresh food control knob to a
WARMER setting decreases the flow of
chilled air into the fresh food section. The
warms at a slower rate and cools at a faster
rate, decreasing the compressor run time
It is ver possible that the auto damper has failed and will need to be cosidered as a likely cause. Part Number Click here=> 61005971 or 1005641 Auto damper control assembly here is the Service manual=> MSD2756G Instructions can be foun on pages 38 and 39 in your manual.If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Feb 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer fine, fresh food 55 degrees max cold
Check for frost build up in freezer section. If frosting up you will need to check the heater and bi metal. If it's a ge ref. could be thermister or main board
Feb 25, 2010 | Refrigerators
Refridgerator not cold
Hi and welcome to Fixya. When a food section of a refridgerator warms up it is a sign that the unit is not defrosting or there is an air flow problem.
This can be caused by the following components:
1. The defrost timer
2. Defrost bi-metal 60 Deg thermostat
3. Heating element
4. Evaporator fan failure in the freezer compartment
Sometimes the defrost timer will just stop advancing for some reason and ice builds up in the evaporator coils that restircts airflow from the evaporator fan so the food section warms up.
The most likely failure is the defrost timer.
You can see if your uint will cool properly after a good defrosting by doing this:
1. Unplug the unit and unload the freezer section
2. Place a fan blowing into the freezer for about 2 hours. (it will make a water mess so be prepaired)
3. Plug in / restart the unit and monitor the temperature for the next 48 hours (it should be normal or near normal) After 48 hours the food section temp will start to raise again due to ice build up.
4. If the temps return to normal then the unit is not defrosting properly and will need repaired.
You can find replacement parts here:
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=KSRB22FHBL01&mfgModelNum=&fkMfgID=3
From the model number you gave the defrost timer is Item 6 of the control diagram
http://www.partselect.com/PartDetail.aspx?Inventory=372261&SourceCode=1#
It can also be found here:
http://www.repairclinic.com/Appliance-Parts?s=t-KSRB22FHBL01-%3d%3d&z=50
http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRB22FHBL01-%3d%3di844415&PartID=844415
I did not of course diagnose the unit in your home. The part above is the most common failure. Given the cost of the defrost timer I would make SURE that it was defective before ordering.
In order to perform a continuity check of the rest of the defrost system components the bi-metal 60 Deg F thermostat must be above 60 Deg (or jumpered) to read the whole circuit. Jumpering the 60 Deg thermostat will not verify it is working correctly.
Hopefully this gives you a bit more understanding of why your unit is warming up in the food section.
Feb 04, 2010 | Refrigerators
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
914 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
