Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Stuck grinding device
We just moved to Hong Kong, our helpper tried to assemble the coffee machine, and put the grinding part probably in the wrong position, now it want get-out or make coffee.
could not find a service for Saeco over here... pls help
  • 515 Answers
There are a Saeco service center in Japan, try to contact them to see if they can help you.
Nihon Saeco K.K.
1-4-6 Osaki Shinagawa-ku
Tokyo JAPAN 141-0032
Tel: +81 3 5436 8860
Fax: +81 3 5436 8890
E-mail: infor@saeco.co.jp
Visit the Web: www.saeco.co.jp
Posted on Aug 02, 2008
How much is PSP in hong kong
There is no direct re-seller in Hong kong but you can at least get some idea from this link PSP price in Hong Kong - Hong Kong GeoExpat.Thanks for visiting fixya
Sep 28, 2011 | Sony PSP-3000 Black Console
Makes funny noise when I try to grind coffee and no ground coffee comes down into the handle. Seems like something is stuck in the grinder.
if you hear it trying to grind, but is not, or hear it spinning and is not grinding, more than likely it is blocked, or so oily that bean will not drop. Coffee beans, have so much oils in them, that after a while it gets caked up, and beans either get jammed, or stuck. If you hear grinder low humming, then it is probably stuck or clogged, if it is on but hear like a spinning sound, beans are not dropping, because they are stuck because of oil build up. If you can get to the grinder, turn machine off, unplug, get all beans out, take like a wooden chop stick and put it in area where beans go and move the chop stick around the gears. you like your reaming it out kind of. turn machine back on, try this procedure a few times. ( MAKE SURE MACHINE IS UNPLUGGED WHEN DOING THIS) As said early if it is a low humming, like motor turning but jammed, do not use until jam is fixed, you will burn up motor, then have more expensive fix. Let me know if this helped and solved problem. Mr Bean Man from Fixya
Jun 12, 2011 | Breville BES860XL
What is the area code of Hong Kong ?
The country code for Hong Kong is +852
May 05, 2011 | Lands Phones
My one week old baby gaggia espresso machine is spraying coffee all over my kitchen. Should i take it straight back or am i doing something wrong?
Check the filter basket, if it only has one small hole, it's a pressurised filter and needs the small black Crema Enhancer fitted into the portafilter before fitting the filter basket.
Or buy a spare double filter basket which has lots of holes and does not need the Crema doo-da
Jan 09, 2011 | Gaggia Baby Espresso Machine
The nachine make all the steps, but only can get
One most posible reason is that the grinding coffee passage is blocked so the coffee is not moving up the the group piston and the machine brues without any coffee in piston and you receive only water.
We sugest to move all coffee beans from grinder by hand and the remaing with the help of vacum cleaner. Try to s.ck also everything that is inside the grinding like grided coffee which probably stuck bettween baldes.
Now udjust teh grinder to 2-3 steps more gross coffee and try the machine again. If it works then you should have coffee but not with good cream at top. So try a coplue of coffe more and if everything is ok then ajust back the position of the grinnder but one step at the time so one step back one coffee.
Goo luck
Mar 25, 2010 | Espressione Caf? Dolce Aroma
The coffee doesn't come out. I tried taking the
I think I have solved it. When it doesn't come out, I put my finger under where it drips out of and move the piece that's under their around. You can feel the kcup inside move. This seems to work. It is almost like there is an air bubble or a grind that blocks the hole temperarly. I don't understand it but it seems to be doing the trick.
Jan 15, 2010 | Keurig B70 Coffee Maker
I can't find a battery replacement for my navigon 2200T? Found a place in Hong Kong but they sent the wrong one even after I gave them P/N and S/N.
I too have a Navigon and suggest you go to their website, probably Navagon.com. They can sell you a battery. If not, go to Amazon.com and key in Navagon.
Oct 25, 2009 | Navigon 2100 Portable GPS Receiver
Filter Basket pops open while grinding and brewing
Put the handle to the basket, that holds the coffee grounds toward the front.  If it is not facing front it will pop open.
Jul 14, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Bernina Virtuosa 153 QE is jammed.
Where do you live in China? I'm in Hong Kong and have visited that dealer.
Jan 04, 2009 | Bernina Activa 130
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
159 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
