Question about Keurig B30 Mini Coffee Maker
I cleaned my Keurig B31 machine last week. Today my coffee machine will not brew. It sounds like the water wants to come out but it wont. (I did put water in the chamber) This is the 3rd time this has happened. Do you have any suggestions or ideas on what the problem may be? Thanks
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Mar 21, 2011
My b31 Keurig is leaking from the bottom. What can I do?
if it is anything like my BUNN you will have to buy a new one . they won't fix .
Jan 05, 2015 | Keurig B31 Mini Plus Brewing System
Machine powers on and off repeadedly after brewing cup of coffee.
De-Scale one time to get rid of elements within the heating tank, filter, and tubes. Sensors may be getting a false-positive signal. Once cleaned out, do the normal method and see if the unusual events stops. If Not call 1-866 901 2739. Use Distilled Water and replace filter every 6 weeks. Remember...wen the unit is not being used...drain the tank or debris accumulates on the botton surface.
Jan 28, 2014 | Keurig B31
KEURIG B31
The exit tube at the top that penetrates the Kcup has debris from the minerals in the water you are using. Clean as per Pg 18 and use Distilled Water to avoid the problem. Change Filters 6-8 weeks periods, also.
Feb 10, 2013 | Keurig B31
Keurig b31 mini. Power light on, brew light not on
Water reservoir may not be seated properly or filled above the Max line. Did you do a purge and establish filling the hot water reservoir?
Feb 08, 2013 | Keurig B30 Mini Coffee Maker
Keurig mini keeps asking to add water
Needs cleaning and reset the system with a full flush and Calc.
Feb 04, 2013 | Keurig B31 Mini Plus Brewing System
I have a new B31 mini plus keurig brewer and I put the water/coffee in, hit the brew button, it flashes red then turns off after about 2 minutes without brewing the coffee.
MODEL B31: I made the mistake of not running water thru the machine first (the Initial cleaning) and was unable to get water to come thru to the K-cup. Reservoir was hot and full and would not come out. SOLUTION: I took a bendy-straw and completely covered the inside needle coming from the top (that goes into the K-cup) and pushed it up with a fair amount of pressure and blew hard into the straw. Then sucked on the straw (BE CAREFUL IF THE WATER IS HOT) and water and some coffee grounds came out. The brewer worked perfectly after this!!
Nov 27, 2010 | Keurig B30 Mini Coffee Maker
Brewer pushing water back into reservoir, not brewing... any suggestions? De-scaled last week (used all week with no problem). Cleaned needle today, no change.
I had the same problem, contacted Keurig and they suggested the descale procedure, which did not work. I was able to resolve the problem however.
First I went through a gallon of white vinegar, without results. Then I did the following:
Went to Walmart and bought "Brew Rite". Tried 8 cup mixture (8 cups of water, two tablespoons of mix), did not work. Being persistant, put in another 8 cups, let sit 2 hours and then put in clear water. By the time I got half way through with the clear water, the device started working properly, no problems since.
Jul 12, 2009 | Keurig B70 Coffee Maker
Keurig B30 Mini Coffee Maker Logo
1,375 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
