Question about Amana 24 in. ADB1500AW Built-in Dishwasher
I have an Amana ADB1500AWW dishwasher. It runs fine, and all of the cycles complete, but the heating coil stays on when its done. We have to leave the door open at the end of its run, and can't run it and leave, for fear of fire. Is this a control card problem?
  • Amana Master
  • 43,501 Answers
Yes, this is a control board porblem...turn off the power at the circuit breaker till you get a replacement part...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Mar 18, 2011
  • Jeeplette420 Jun 02, 2011
    There is a recall for this heating element. We had it repaired last year. I don't think it took more than an hour.
    Here is a link to the recall info (you can also schedule a repair or rebate): https://repair.maytag.com/prjjck10/defau...
Top raCK OF DIRTY DISHES ADB1500AWW
This Dishwasher although working on one side should not be an issue as long as the dishes are getting clean. If your unit has the Pots and Pans setting or heavy wash cycle with this option pushed the water pressure should be then adequate and then be seen on both sides of the arm. If you have not tried this do so. This unit has several manufacture's problems to look out for..The control relay on the board fails leaving the dishwasher useless. The door locking safety feature has a bad switch these reports are public information in many reviews with the same problem over and over. So these things you should look for possibly in the future Maybe it never happens to you. Remember to rate my solution and give testimonial this is how i earn achievements here on FixYa Thanks in advance.
Apr 25, 2012 | Amana 24 in. ADB1500AW Built-in Dishwasher
It doesn't clean well I have bought rinse lemishine and it doesn't clean dishes and leaves a white residue I'm using cascade
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Apr 22, 2011 | Viking DFUD042 Built-in Dishwasher
My dishes come out of the dishwasher with a white milky coating on them. Especially glassware is very milky.
Hi
Daniel
Apr 20, 2011 | Amana 24 in. ADB2500AW Built-in Dishwasher
Dishwasher goes thru cycles but does not fully and leave dishes with film
Hi
Daniel
Apr 20, 2011 | Admiral 24 in. DWUA800AA Built-in...
Dishwasher leaves residue on dishes. Salt levels seem fine, rinse aid ok, and cleaning block is released fine.
Hi
Daniel
Apr 18, 2011 | Dishwashers
My dishwasher is not cleaning my dishes and leaving a film is there a filter i need to change?
Hi
Daniel
Jan 30, 2011 | Magic Chef Dishwashers
Leaves a white chalk on plastic cups and runs for a long time
Hi
Daniel
Jan 08, 2011 | Bosch 24 in. SHX46A05 Stainless Steel...
We have an Amana dishwasher, model ADB1500AWW that will not drain.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 22, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Heating Element Won't Turn Off
Ok, this is a control fault that may be corrected by shutting the power off for 5 minutes. this will reset the chip set on the control board. plug the unit back into the socket after the 5 minute ait and check to see if the element is still on. If so, replace the control board.
May 29, 2009 | Amana ADW662EA Built-in Dishwasher
Stays in wash cycle Whirlpool Dishwasher Du1050SS
the stat is mounted to the bottom of the tub it will read closed if good if it reads open replace it
May 03, 2008 | Whirlpool 24 in. DU1050SS Built-in...
Amana 24 in. ADB1500AW Built-in Dishwasher Logo
332 people viewed this question
Top Amana Dishwashers Experts
Cleverer2
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
