HP Solution Center does not load from the driver CD. I receive a notice saying that it doesn't find my printer or scanner even though the Windows wizard does find it.
  • 111 Answers
Can you do this?
1. Control Panel Check the installe Printers(If your printer is not there then do this)
2. Disconnect the printer to your computer.
3. Connect the printer to your computer..If your printer is not yet installed it should run on Installing.
4. If it runs thru intallation choose the driver that you have put to CD..
Thanks hope this solves your problem.
Posted on Mar 17, 2011
I just upgraded from an old dell (windows XP) to a new machine running windows 7. I have an hp scanjet 4570c scanner that I want to use. It ran fine on XP, including the HP director software and the HP...
if you still have the installation disc for the printer use it when adding a printer to the win 7 os
or go to hp download site and download the drivers for the printer
or may be go to the printer properties tab , click on compatibility and tick the box and high light win7 os and apply
Apr 15, 2017 | HP Scanjet 4570 Flatbed Scanner
My officejet 6210xi all in one, the scanner doesn;t work it's says need software or driver for work but web hp says the driver for this windows 7 install automatically, the printer and copier work good...
Windows 7 will just have the printer drivers for this unit by default. If you want to be able to scan, you should install the full version of the drivers which is available from the HP website. Just search for your model number, select the operating system, download and install.
Jun 17, 2011 | HP OfficeJet 6210 All-In-One InkJet...
When scanning it says no computer connection even though we can print to the printer from the PC
Hi
May be u can install the scanner driver please uninstall the printer driver and setup again with the Installation driver CD.
Good Luck
May 09, 2011 | HP Officejet 6310 All-In-One InkJet...
Hp c6180 will not print from windows vista; no error message displayed on computer or printer; print queue says error printing with no explanation wireless installation hp solution center says no hp...
This means that your system does not display any printer name under the printer's list even though you would have installed your wireless printer on your Windows Vista system. This could be caused if you have not updated printer drivers in your system or the printer is incompatible with Windows Vista. Also see if the Windows firewall is blocking the printer from being recognized by your system. get more information for HP Wireless Printer Problems . Hope this helps you.
Jan 12, 2011 | HP Photosmart C6180 All-In-One InkJet...
My HP Officejet 5610 All-in-one has a scanner problem. It was scanning documents fine. Due to some other problem, I had to uninstall and reinstall the entire program. Ever since I have reinstalled, the...
Some time reinstalling these drivers and reinstalling them could be lots of headache, up to the point of reinstalling the the entire system. I will advise if you are not to good with computer, get a technician to do it for you. But if your are good enough, uninstall your current driver for the printer and look for any entry of it on the registry and delete it also search the installation folder and delete the folder. Restart your system and install the printer again.
Sep 28, 2010 | HP Officejet 5610 All-In-One InkJet...
HP Solution Center does not recognize the scanner anymore... We are operating on a Windows 7 system... the drivers had to be downloaded from the internet because the cd that came with the printer was for...
I had the same problem and solved it. I was using HP Solution Centre to run my HP Scanjet 5590 on Windows 7 Pro 64 bit without problems. Then I ran the scanner using Windows Fax and Scan, but didn't like it, so went back to HP Solution Centre - whereupon the scanner was not recognised.
After hours of reinstalling software etc etc, without success, I suddenly noticed four device icons on the left hand side of HP Solution Centre. These were labelled (when hovered over with the mouse) hp scanjet 5590, hp scanjet 5590 #2, hp scanjet 5590 #3, hp scanjet 5590 #4. Only the top icon was active, but when I clicked on any of the four it moved to the top.
Clicking on hp scanjet 5590 #2 gave me a working installation once more - problem solved. No doubt the multiple icons arose from my desperate attempts to try different USB ports.
Feb 02, 2010 | HP Officejet 6500 Wireless All-in-One...
Scanner problems
This worked for me. You want to start fresh so delete your HP printer in "Printers and Faxes". Also delete any HP software that loaded in Control Panel "Add and Remove Programs". Next in Control Panel under "Add and Remove Programs", the "Add and Remove Windows Components" TAB, check mark the file to add called "Other Network File and Print Services". After clicking next, the extra print files will load. Reload your software/ HP drivers and it should be fine.
Jul 05, 2009 | HP Office Equipment & Supplies
3880 scanner never has worked
HP has great on line(download and lookup Q&A) support for free.     Before going to too much trouble do this for me. See if the driver you installed,the disk,is for the version of windows that you presently are running. Sometimes disk installed drivers load ,even though it is for the wrong version of windows. Another possibility is that HP updated (Rewrote) the driver because it had a particular problem. You are hooked to the phone line , of course.
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=378060&submit.y=3&submit.x=6〈=en&cc=us
Feb 05, 2009 | HP LaserJet 3380 All-In-One Printer
Hp f2180
The scanner and camera wizard is a portion of Windows XP & Vista.
If you go into the control panel, you'll find it in there. If you double click on it, it should locate your scanner and you should have functionality this way.
If you're pressing the scan button on your printer and getting this information, try opening HP Solution Center and clicking "Scan Picture" in there and see if it is any different.
May 01, 2008 | HP PSC 2210 All-In-One InkJet Printer
Trying to scan, but keeps on saying "USB not connected"
I had the same problem.  The thing is I was pressing the scan button on the printer and getting the lovely "USB not connected" message.  However, if you open the printer icon in the dock (Mine is "HP Photosmart C4200 series") and click the Scanner button in the upper right hand corner, then click "New Scan," voila!  presto! and all is right with the world again.
Yes, it is obnoxious that HP made a defective scanner button, and I may download the driver again when I get a chance.  But yay for quick fixes!
Feb 06, 2008 | HP Photosmart C4280 Aio Printer
k24674
