Question about Cameras
Software for Pentax K100D - Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Http://www.pentaximaging.com/support/manuals-and-literature/
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on Mar 17, 2011
4 Suggested Answers
SOURCE: pentax K100d super
I fixed the problem. It was caused by an extra little pimple on the sirius lens slipping into the auto focus indent indent on the camera body.
It is possible to get up to a ten thou engineers feeler gauge into the gap between lens and camera body although the one that did it for me was a three thou gauge.
I needed to cut the feeler gauge square at the tip and then, even though it was only three thou, I hit the tip by resting on a vice and tapping with the ball end of a small ball pein hammer. This caused the tip to form with a small curve. I then used a tool makers file to smooth the end down to almost nothing.
Turn the camera AF MF switch to AF to raise the screw. Fiddle the feeler gauge into the slot between body and lens just near the AF MF button and very gently probe the gauge. You are trying to get the little curve you made on the feeler gauge to slip over the pimple on the lens.
Its a very nice feeling when the gauge slips right in and the lens comes free.
The next proceedure, if you want to use the lens, is to unscrew the aluminium mount at the end and remove the offending pimple on the lens.
Posted on Jun 02, 2008
mail541
  • 58 Answers
SOURCE: Pentax K100D will not power up
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
Posted on Jan 21, 2009
iwctoys
  • 126 Answers
SOURCE: hi, i have a pentax K100D but have Windows Vista,
You do not need drivers or software. Vista will load in driver. If your pictures are not sharp try another lens, this may solve the problem. You can aklso go to Pentax website to download all software and firmware updates.
Posted on Jul 02, 2009
Picture is not displaying on sony dsc-hx1
Talking about two camera's my guess is you made a picture with a Pentax K100D and you put it on the memory card in a Sony dsc-hx1.
In the manual the Sony tells what sizes of pictures it can display. None of the 4 sizes the Pentax K100D makes, is in that list.
Perhaps you don't mean this, please let me know.
Oct 29, 2013 | Pentax K100D Digital Camera
New Pentax K100D Super, shutter does not work. Av -- flashing 688 under battery sign. Replaced new batteries did not resolve problem
I suspect dirty contacts on either lens or body. Clean contacts. Should alleviate problem. This happened to my K100d.
Dec 11, 2010 | Pentax K100D Super Digital SLR Camera
Won't focus or take picture
Try cleaning the contacts on the camera body with a cotton swab lightly dampened with rubbing alcohol.
Jan 05, 2010 | Pentax K100D Digital Camera
What Memory Cards will work?
Hi,,
Unfortunately, the Pentax K100D is not SDHC compatible, which means that the camera can be equipped with a maximum memory capacity of 2GB.
It is also advisable to choose a fast version of the Secure Digital memory card, such as Ultra II or Extreme III by SanDisk. I would recommend using a memory card of at least 512MB, or even 1GB if you can.
Hope this info helps
Dec 03, 2009 | Pentax K100D Digital Camera
Memory Card error message
The K100D works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot is is electronically incompatible.
Sep 25, 2009 | Pentax K100D Digital Camera
Pentax K100D super lens problem
Read the K100D manual. Go to the Setup menu and allow for lenses with manual aperture settings.
Aug 04, 2008 | Pentax 100-300mm f/4.5-5.6 SMCP-FA Zoom...
Bad USB conection?
I assume that you are using Win.XP,
- did you check; System Properties>Hardware>Device Manager
Is there anything like yellow exclamation etc, especially on the USB section?
- Is it BIOS USB function enabled? Maybe disabled by accidentally.
- You said nothing working through USB, all ports are same?
If this ocurred all of a sudden, than I think you have a software problem.
I have a K100d, its been seven months now and ~6500 photo. My USB cables&fittings are fine, I always using USB port to transfer photos, no problem at all.
I hope your problem will be solved in a short time.
Sincerely
-halotheracer-
Feb 05, 2008 | Pentax K100D Digital Camera
Cameras Logo
20 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
