Question about Whirlpool Duet GHW9150P Front Load Washer
Water pump not working - Whirlpool Duet GHW9150P Front Load Washer
  • 403 Answers
Remove the bottom kick panel. should be 3 or 4 1/4 " nut. open and check drain pump.
Posted on Mar 17, 2011
  • Dwayne Hoo-Fong Mar 17, 2011
    Drain pump is probably clogged. you may want to have a container with you to catch the water that will be spilling out and some towels. Check the drain hose, make sure it isn't clogged or kinked. Check the electrical connections at the pump and make sure the pump is running. You can check continuity at the pump using a multimeter and unplugging unit. remove connectors from drain pump. Set the meter to check continuity. Place meter leads across both terminals. If there is continuity, then the pump should be good.
    Check the drain pump filter for foreign objects.
    if all the above checks out to be ok, and the pump still isn't running, then yu may need to replace the pump.
    *Also if there is too much soap or suds, the pump will shut down. you may have to run unit several times in the rinse cycle using cold water.
My water supply pump to house works but does not pump water from tank to house
What type of pump is it? Is it a shallow well pump or submersible
pump? Is the pump connected to a pressure tank? How have you confirmed that the pump is working properly? Is there a drain valve, and is there water pressure from the drain valve when it is opened? If the pressure tank is of the pre-charged type, is it working properly? Is there water coming out of the air valve? Are there any shut-off valves in the system which may have been turned off, preventing water flow?
Apr 17, 2014 | Saniflo 021 Saniswift Residential Water...
My Frigidare Affinity front load washer doesn't pump water on the Normal cycle.
Check the water inlet electro valve at the rear of the washer and make sure it is working.
Jul 25, 2017 | Frigidaire Washing Machines
How can you tell if your water pump is even working
Water pumps FYI
A belt drives your water pump, most are the same belts that turn your altenator and air compressor. Some water pumps are turned by the timing belt. But if you can see that your belt is working the water pump, altenator and compressor, its working. If you had a water pump powered by a timing belt, you would not be able to start your car if that belt stoped.
Water pumps never stop working, they are direct shaft driven.
The only thing is they do start to leak after they get older, then need replacing.
Apr 15, 2011 | Kia Sportage Cars & Trucks
I installed this pump to company specs and don't understand why it's not working. I brought it back to the place that i purchased it and they got it to work. What am i doing wrong? Municipal water is...
How high does the pump have to lift, in feet from the water in the sump to the highest point of the piping?
While the pump is running, what is your municipal water pressure near the sump pump?
You saw it work in the store, were those conditions different?
Gary
Dec 14, 2010 | Liberty Sump Pump Jet WaterPowered Back up...
Need to now location of the water pump
Check the thermostat first. Follow top water hose from the radiator to the water pump. To check for problem with water pump see if you see anti-freeze somewhere leaking or do you hear a strange noise. Also check your top and bottom hoses.
May 28, 2009 | 1997 Cadillac Eldorado
Sump pump not pumping water properly
If your pump is turning then something is stopping the water from being removed. If you can see the pump check to see if the water is becoming turbulent when the pump kicks on? If the water doesn't appear to move or is moving only a little then either the pump impeller is damaged or the screen that keeps debris from entering the pump is clogged.
If it's never been cleaned it is most likely just a clogged filter screen. Clean it and it should work fine. If however the screen is clear then it is either a blocked line or a bad pump. And yes a pump can still run and not pump, if the impeller is bad.
May 19, 2009 | General Plumbing
I have a flotec water pump that sits on top of my pressure tank, pump worked ok last season, and when we tried to prime the pump to start this season, it wont pull water up from the well pipe, pump will...
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Apr 06, 2009 | Flotec Corrosion Resistant Shallow Well...
Stiebel Mini 4 won?t activate using 40l/min pump
You have to make sure that the pump is flowing enough water to activate the Stiebel. The tankless unit has a activation rate of a certain amount of water to turn it on.
Jan 18, 2009 | Stiebel Eltron Mini-4 Tankless Water...
Pump works but is not pumping water
IT SOUNDS AS IF THE PUMP IS NOT PRIMED. MAKE SURE THE THE PUMP IS FUL OF WATER
Jan 11, 2009 | Flotec Corrosion Resistant Shallow Well...
Whirlpool Duet GHW9150P Front Load Washer Logo
13 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
