My panasonic na-f60gt problem - after wash - drain the water - cannot spin
2 Suggested Answers
  • 6277 Answers
SOURCE: Model : panasonic na-f60gt problem
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 24, 2011
Why the Panasonic Washing Machines error code "h 02" displaying?
Google "panasonic washing machine error codes"
Jun 11, 2016 | Washing Machines
PANASONIC-na-f70B2 drains as it fills to begin wash cycle. Error code U14
You water drain line needs to be curved above top of tank Water finds its on level The water level is stuck on the full position shake the washer lightly with water inside to release it. It works almost as a toilet tank.
Feb 15, 2015 | Washing Machines
Loud wheezing noise on spin cycle
you need to unblock the pipe work from the tub to the pump ,,then the pump,, and the pipe from the pump to the drain
Jan 12, 2014 | Panasonic Washing Machines
Model : panasonic na-f60gt problem - after washing, drain the water wasn't being drained completely and it couldn't spin to dry the load. i switched off the power and tried many times. it...
John C
Aug 24, 2011 | Washing Machines
How to do manual setting for Panasonic Washer NA-F701GS
I keep program to normal, water level 51 and wash,rinse & spin but half way the washing machine go to reserve button (9 hrs).
how do i cancel the reserve button?
Nov 28, 2010 | Panasonic Washing Machines
Got error code u11
u11 is not a valid error code - please recheck.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2009 | Washing Machines
Washing machine
something caught in pump or bottom drum hose,check filter also!!
Mar 19, 2008 | Washing Machines
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
