Hi there just purchased a second hand presario notebook cq62. however some of the screens are coming up with chinese writing cant find any where to change back on control panel?????? would be greatly appreciated nelly
    Brigadier General:
  • 8,909 Answers
In control panel select region and language.
Select what you require from there. If you need updates from Windows go online and download them.
Posted on Mar 17, 2011
How can I make my Compaq Presario CQ62-112TU laptop a wifi hotspot?
Possibly not compatible witht the software you are trying to run.
Aug 01, 2014 | Compaq Presario CQ62-112TU
HP PRESARIO CQ62-219WM HARD DRIVE FAILURE ID: RLHK1S-5A36M4-XD002-61BW03
Here's a link to the Manual for your unit. Looks like these units are full of bugs, since many people are having problems with them. Good luck
Compaq Presario CQ62 219WM Notebook PC User guides
Jun 13, 2013 | Compaq Presario CQ62-219WM Notebook
Will an optical drive from cq62 fit mine?
NO.
I sort of see your reasoning, but NO.
HP Compaq DC7700 Ultra-Slim Desktop PC, and Compaq Presario CQ62 series of Notebook PC DVD burner drive?
http://www.ebay.com/itm/New-For-Compaq-Presario-CQ62-TS-L633-SATA-CD-RW-DVD-RW-Multi-Burner-Laptop-Drive-/300725349252?pt=US_CD_DVD_Blu_Ray_Drives&hash=item4604a0ab84
Until I compared both units I would have stated NO.
Now that I have THANK YOU. I just learned something,
http://www.amazon.com/HP-Compaq-DC7700-DC7800-DVD-ROM/dp/B004574PEG
Referring back to the photo view, of the Compaq Presario CQ62 series of Notebook PC's DVD burner drive shown, the REAR view shows the connectors for the SATA power cable, and SATA data cable.
The connectors use the same L-shape design, and size that a SATA unit for a desktop computer, would use.
Case design looks to be similar also.
I believe you are Correct.
For additional questions please post in a Comment.
Make all checks out to; The joecoolvette Fund for Having a Good Time
Regards,
joecoolvette
Oct 08, 2012 | HP Compaq Dc7700 Ultra-slim Desktop Core 2...
My compaq presario cq62-238dx felloff my hands, no scratches or damages are visible, when I first turned it on it worked as if nothing would have happenned, but later on the screen turned pink, the next...
I suggest you start diagnosing by using an external monitor, if available.
A VGA monitor.
(It can be a VGA monitor that looks like a small TV, {CRT}, or an LCD flat screen that has a VGA cable attached.
More information on VGA connectors,
http://en.wikipedia.org/wiki/VGA_connector
Laptop off, and VGA monitor off, connect the VGA cable of the monitor to the Left side of the laptop.
(Rear top port)
Turn the monitor on, and then the laptop.
Do you see a display on the external monitor? (VGA monitor)
No?
Press, and hold down on the Fn key (Function Key), and tap once on the F4 key.
A) If BOTH the external monitor screen, and the laptop screen have the same pinkish display, the problem is the graphics chip. (More on graphics chip in a moment)
B) If just the laptop screen is pinkish, and the external monitor graphics are okay, the problem is inside the laptop display.
1) Could be a loose connection of the Display Panel Cable.
{The Display Panel Cable attaches to the motherboard, and the LCD screen in the laptop display}
2) Could be a bad Display Panel Cable.
Possible damage to the Display Panel Cable is the the laptop display was open.
Look for signs of damage to the sheath of the Display Panel cable.
However the damage may not be apparent. The Display Panel Cable could have been stretched.
(Laptop display open when dropped)
The tiny wires inside the Display Panel Cable could have become damaged.
Testing requires that the Display Panel Cable be removed.
A multimeter is used to check continuity of each wire.
{Multimeter function knob is set to Ohms. 1K or 10K if these settings are available.
The Positive probe lead (Red) is touched to a wire at one end of the Display Panel Cable.
The Negative probe lead (Black) is touched to the other end of the wire.
Analog multimeter needle swings up, you have continuity. Don't worry about the Ohm reading at this point. As long as the needle moves.
No movement? Have a helper gently move the Display Panel Cable around.
See if there is continuity shown, or is intermittently shown.
Indicates a break in the wire.
Solution is to replace the Display Panel Cable.
Same with a digital multimeter. No reading, or intermittent reading indicates a broken wire.
Display Cable Kit - HP Part Number 595196-001
I have seen several listings on the internet.
3) Could be a bad LCD screen.
Check the connections.
Check the display panel cable
If this checks out okay suspect the LCD screen.
Compaq Presario CQ62-238dx Notebook PC - Service Manual,
(Free from HP Support),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=4252487&
Left-click on -
Compaq Presario CQ62 Notebook PC and HP G62 Notebook PC - Maintenance and Service Guide
This is a PDF file. (The computer you are using now has Adobe Reader on it, which uses PDF files)
It may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
In the Bookmarks menu on the left, click on the + sign to the left of Removal and replacement procedures.
Now click on the + sign to the left of Preliminary replacement requirements, then go on to Component replacement procedures
For additional questions post in a Comment.
Regards,
joecoolvette
Aug 19, 2011 | Compaq Presario CQ62238DX Laptop
Nokia 2118 language setting
you first go to the menu, then settings ( on my phone the bottom right, an icon that looks like gears coming out of a folder). Go down ten spaces to phone settings (screen with a wrench as the icon). The language setting is the very first one. In that there is automatic, which is the first setting, or english, which is the second setting. hope this helps!
Feb 14, 2008 | Cell Phones
Computers & Internet Logo
David Payne
David Payne
