Question about Lanzar SDN7UD Car Video Player
We're does the rear view camra pos wire go for a lanzar sdn7ud unit
  • 3 Answers
If i remember correctly, on your back up camera there are 2 wires a red one (power) and a black (ground). you will need to pull off one of the tail lights and find the reverse bulb/ wire. u will take the ground wire and mount it to the frame of your vehicle. then u will need to find the power of the reverse light. take the red wire and splice into the power of the reverse. u will then need a separate wire and run it from the spliced wires to your lanzar player. doing it this way will make the camera come on and the lanzar to switch to view when u have your vehicle in reverse
Posted on Sep 22, 2011
Can a back-up camera be installed in a lanzar sdn695 bt if yes how to do thanks ted
sure can !! this head unit has three composite video input jacks on back of unit (three stereo sound jacks as well) if your only using say one of them for your dvd or vcr then that leaves you one to plug in a back up camera , it of course is sold separately , but any good composite output camera will do , and of course wire needs to be long enough to reach from rear bumper to lanzar head unit in dash , so be mindfull of that , after its all connected just select composite input you have it connected too , and violia !! there your view of what's behind you !! a rather neeto thing to do is connect two cameras to your spare inputs , one front and one back , if the front camera is infared enabled , it will help you see thru bad weather !!!!as infared isn't encumbered by using viable light that gets all scattered in fog and heavy weather , that's how helicopters land in bad weather !!
Oct 15, 2016 | Lanzar SDN695BT
My lanzar sdbt73n just all of a sudden stopped reading all disc. I need help
lanzar sdbt73n stop working. on the face plate the power button dont work. only way to turn on is using the remote. once turn on nothing works i.e. power, mute, open (for screen). the only thing that works is the volume knob. i have pushed the reset button but still the same.T73N S DefsdBT73
Jun 19, 2011 | Lanzar Sdbt73n Car Video Player
Pleace help ! with bypassing brake ..on a sdn7ud in dash tv
Unfortunately, I cannot find a good manual on this unit so I am having trouble determining what the wire color is for the brake wire. Usually these units need to see a constant ground in order to work. You can try hooking that wire up to your ground wire, not advisable though. You could try hooking it up to a switch. You more than likely would have to us a certain combination in order to get it to work like flipping it on and off a couple of times, but still is effective. You would have to consult the manuals to find out if there is a combination or not. The other, and most effective, way to make it work is by using a relay. You would just wire up power, ground, and the brake wire to the relay.
Apr 23, 2011 | Lanzar SDN7UD Car Video Player
Installed lanzar 266 amp yesterday it went in protect mode on a song and now everytime i turn it on it is in protect mode
most commonly that means that somewhere there was an arc in the electrical either the pos or neg going into the amp or rcas or its the speaker wire from the amp to to the sub itself look especially for little wires touching opposit polarity wire (like a little +wire has moved and touched a - wire)
Oct 07, 2010 | Lanzar VIBE266 Car Audio Amplifier
How do wire my 15'' to 1ohm
If each voice coil is rated at 2-ohm, then wire it in "parallel". This will make a 1-ohm total load.
amp pos. out to coil 1 pos. to coil 2 pos.
amp neg. out to coil 1 neg. to coil 2 neg.
If the they are dual 4-ohm, the rating would be 2-ohm in parallel.
Mar 16, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Help
one wire to pos to amp plus to speaker one. now secound speker use neg. to neg. on amp. now take a speaker wire and hook up the remaining neg. post. on the spekers. This will run them in seris like my 4000watt rms amp at a 2 ohm load. Make sur your speakers can handel the rms load of amp. If not they will blow.
Jul 19, 2008 | Car Audio & Video
Video while driving; Lanzar sdmu head unit
Just ground the "brake" wire from the unit.
Dec 24, 2007 | Car Audio & Video
Video while driving
Yes, just did this myself with a Lanzar unit. Instead of attaching the parking break wire to the parking break, attach it to the ground wire or any other useable ground connection. Works great.
Dec 24, 2007 | Lanzar SD4MU Car Video Player
Lanzar SDN7UD Car Video Player Logo
154 people viewed this question
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
xxxxxx xxx
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
