Question about Onkyo TX-8522 Receiver
My FM receiver has no volume
Came home from a trip, turned on receiver, and no sound came out on FM...speakers/wires all still connected, but don't see voume indicator....don't know if a kid watering my plants fiddled with knobs, but cannot get sound to come out. All connections are fine!!
Very frustrated...longing for the good old days when receivers were simple.
  • 69 Answers
Wires are falty...replace
Posted on Sep 20, 2009
I had onkyo 5.1 hometheater i cant raise the volume more than 40 how can i fix the problem ?
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com, Thanks, JT
May 28, 2015 | Onkyo TXSR309 5.1 Channel Home Theater...
Yht 299
sounds like your speakers might not match your receiver. check the back of your speakers for the ohms eg 4 , 6 ,8 impedance.
you have to match the specs of the receiver otherwise it cuts out.
Mar 31, 2014 | Yamaha Audio Players & Recorders
HOOKED ALL MY SPEAKERS UP BUT SUB AND CANT GET ANY SOUND FROM FM OR TV THAT I HAVE HOOKED UP AM I MISSING SOMETHING ALSO THERE IS A LIGHT THAT SAYS SOUND MUTE BY FM
From the remote control ONLY:
Press MUTING to mute the sound through all
speakers and headphones connected.
"MUTING" appears on the display and the
volume turns off (the volume level indicator goes
off).
To restore the sound, press MUTING again so that "OFF" appears
on the display.
• Turning MASTER VOLUME on the front panel or pressing
VOLUME +/- on the remote control also restores the sound.
Dec 22, 2010 | JVC RX-778V
When you turn player on: Screen said "Hello" , then "Protection"
Sounds simple... usually "protection" means that a speaker or a speaker wire is shorted out. Or that the volume is just too damned high... how loud is the receiver's volume setting? If the bass tone control is jacked and the loudness button is on, even with no shorted wires, the amp can go into protection from an internal overdrive. Might be that you just need to do like your mom says and turn it down!
If you have an ohmmeter, speaker or wiring problems are easy to test, if you don't, you can still do it all mechanically... here's how
Turn off the receiver and start by disconnecting your speaker wires at the back of the receiver. With all of the speaker wires removed, does the thing still go into protection when you turn it back on?
If not, good. If it does, find a service center.
Re-connect the speakers to the appropriate terminals one speaker at a time, turning off the receiver each time you make a connection. After connecting one speaker, turn the receiver on and see if it shuts down. If not, then turn it off and add one more speaker.
Do this until you find the culprit. Leave that suspected bad speaker's wires disconnected from the receiver and test all the rest, connecting all but the bad wires.
Now, disconnect the speaker from the other end of the bad wires and spread the bare wires apart so they don't short out. Connect the wires ONLY at the amplifier end and turn the amp back on. Protection?
If yes, the wire is shorted out somewhere. got cats?? If everything is OK, turn off the receiver and reconnect the speaker and test again. Make sure the wires aren't shorted at the back of the speaker. You really need to check all the speakers to make sure their connections are "clean" and make sure that there are no stray wire strands anywhere or that the wires aren't stripped too much so they might be able to short out. After the wires are connected to either a speaker or an amplifier, you shouldn't be able top see much of any bare wire, but you already know that, right?
Some folks strip way too much off the wire and the wires simply touch the wrong things and ... badness happens.
If all the connections are clean and the receiver still shuts down when this speaker is connected and the receiver is turned on, swap a working speaker onto these wires, leaving the suspect speaker disconnected and making sure the other bare wires won't touch anything or each other.
Back on with the working speaker... good? If so, then we're determining that the problem is probably in that one speaker. If not, then we have a deeper problem.
Reconnect the suspect speaker to the other wires and try again. Good? Then you have "fixed" the problem by cleaning up the wiring connections. If it shuts down again, then you need to fix or replace the bad speaker.
If everything works now with the volume down and such, then just use a little self control. If it's still messed up, you may need a trip to the service shop
Good Luck
Jul 18, 2010 | Samsung HT-DB600 System
Regarding a Yamaha RX-V757 receiver, if I have my volume set above approximately -28, whether I'm playing a DVD or listening to a music CD, the units power shutsoff. When I turn it back on the display says...
Try turning up the volume with just the FM selected (and tuned to a station). If you can adjust the volume to an appreciably higher level when simply tuning in a radio station, then your CD/DVD player may be outputting a signal with a DC offset, which is getting amplified when you turn up the volume, and past a certain point the protection circuitry is sensing too much DC being sent to the speakers and shuts the unit down. If the unit is getting hot, there is likely an internal problem, or you have a shorted speaker wire, or even a bad speaker. Replace the speaker wires as a test, and you can also run the unit with only one speaker connected at a time to see if any are the source of your problem.
Yes, it's possible that there's nothing wrong with the wires or the speakers, and the unit simply needs a trip to the shop, but it's your job to rule out the easy stuff before you pack it up and take it in.
Nov 21, 2009 | Yamaha Audio Players & Recorders
My system shot down during a movie
The reason why your receiver is going in protect is because there is a short circuit happening. This would either be on your speaker wires, speakers or receiver itself. What you want to do to check would be:
1. Unhook all sources and speakers from your receiver.
2. Turn on your receiver and crank up the volume to maximum, if your receiver does not shutdown or go on protect then the receiver is OK. If it does shutdown and go on protect then its an internal problem on the receiver and you would need to send that over to an authorized service center.
3. Hook up a source and 1 speaker. Play something from the source or the fm tuner, Crank Up the volume to about 46 or 47 volume. If the receiver does not shutdown, its good.
4. Hook up a second speaker and repeat the process until you encounter the pop and shut down
if for example you encounter the pop on the 4th speaker, try changing the speaker wires.
5. If the receiver still shuts down then it would be a short on the speaker itself and it would need to go to an authorized service center.
Feb 23, 2009 | Onkyo HT-SR800 System
When volume is turned up the radio shuts off
Have you checked all of the connections on the speakers, stereo, etc. Being a marine CD player, the wires and connectors are exposed to more elements than a car CD unit. Check for corrosion and make sure that all the speakers are hooked up to the correct "+" and "-" terminals. Not sure if this will help, but thought I'd try. It does sound like a speaker connection problem.
Aug 30, 2008 | Clarion M255 AM/FM Marine CD Player
Overload Problem
If your rec'vr worked with the original front and rear speakers, the new speakers are either defective or ar the wrong impedance.
Also, I find this confusing: "I connected the wiring for 1 of the front speakers to the connection on the rear of the receiver". This may indicate wrong wiring connection. Make sure you have connected the speakers properly
Dec 04, 2007 | Pioneer VSX-D608 Receiver
Onkyo TX-8522 Receiver Logo
115 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
