Question about Alpine TDA-7563 Cassette Player
Am wiring my alpine car stereo back to my old car , unfortunately i dont know were to connect the wires , the labels on the wires somehow got cut when i kept it in storage , need help figuring were the red , yellow , black , blue and blu/white wire connects to the car
  • 26 Answers
First thing you will need to do is to buy a wire adapter for your specific make & year of car. This interfaces the stock wiring plug allowing you to connect the wires from the headunit to the wires of the plug.
Here is a color coding explanation for the wires on your Alpine Deck:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
Posted on Mar 17, 2011
Pontiac grand am wiring diagram
You will need the wire harness that is designed to connect to the stock stereo. Another option is to just install your alpine stereo in the car since you have the wiring harness for that. You will not be able to wire the harness for the alpine unit and have it match the plug type for your stock stereo.
Dec 12, 2013 | Alpine CDE-121 In-Dash CD/MP3/WMA/AAC Car...
I have no harness for vehical was told the reason I have no sound is becuase the pink and black wire labeled Audio interrupt lead were does this connect 2
The install diagram indicates the Audio Interrupt wire goes to a Vehicle Phone. If you don't have one, don;t connect it to anything andmake sure you put tape over the end so it doesn't touch ground or a power source.
In cases where I don't have or cannot get a wiring harness adapter to plug directly into my vehicle wiring harness I have a trick I like to use. I don't like to cut and remove a vehicle harness socket, I may want to keep the aftermarket stereo when I sell or trade and put the original stereo back in place. Instead of removing the socket I skin back (but do not cut) the wires I need to tap into and wrap the aftermarket unit's wires around the now exposed socket wiring, then solder each one & wrap each one individually with electrical tape. This gives you a secure connection and when and if you need to permanently remove the aftermarket unit you just untape the wires, clip the fatermarket wires off one at a time very close to where they are tapped in, tape each one of them again and there you have the factory plug ready to plug back into the factory stereo.
Aug 20, 2011 | Alpine CDA-7892 CD Player
I just bought Alpine car stereo CDE-100EUB but I'm having trouble connecting it to my old car toyota Rav 4 2004 model because the wire harness are different. also the alpine wires are more in numbers than...
Please let me know if you have any questions, and thanks for using FixYa.
2004 Toyota RAV4 Car Stereo Radio Wiring Diagram Alpine wire color
Radio Constant 12V+ Wire: Blue/Yellow yellow
Radio Ignition Switched 12V+ Wire: Gray red
Radio Ground Wire: Brown black
Radio Illumination Dimmer Wire: Green none
Radio Antenna Trigger Wire: N/A blue
Radio Amplifier Trigger Wire: N/A blue/white
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Pink white
Left Front Speaker Wire (-): Purple white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Blue gray/black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Black green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Red violet
Right Rear Speaker Wire (-): White violet/black
Jan 02, 2011 | Alpine Car Audio & Video
Im putting n a stereo but i dont no the color code
The stereo side of the wires should be labeled. Check out the12volt.com for a wiring schematic for the truck side. I advise against cutting and splicing wires for a stereo installation though. They make inexpensive harness adapters that will allow you to splice into the stereo harness without cutting into the factory wiring.
May 23, 2010 | 1998 Dodge Ram 1500 4WD
AM FM CD DET FACE CAR STEREO: installed an alpine stereo in my mustang and every...
That's because the memory wire has not been connected to a permanent live supply.
There will be an ignition switched 12v supply and a memory wire. The first is yellow on many brands and the second is red, but you need to refer to your fitting manual to check or look directly at the wiring harness as the wires are often individually labelled.
Since they both take 12v some folks mistakenly think that they can just be piggy-backed to each other and feed from the same supply. They can, but only if it's to a permanent live feed but that then leaves the risk of the unit being left switched on when the car is parked and draining the battery.
May 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
I've got a 1988 Dodge Ram and I know nothing about Car Stereos
go down to a electronics shop (future shop or best buy) and they will have a connector that will fit the original plug. Some splicing will be required but its all color coded with the deck
hope this helps
Nov 15, 2009 | Alpine CDA-7840
Hi. trying to re-install a pioneer deck where an alpine used to be. can't read the japanese on the alpine wiring to know which wire is for what. What coulour goes to the ignition, what colour is for the...
dnt get confused, follow these simple wiring .......
firstly cut off the old lug from the connected place, make sure you cut each wire seperatly....and you are going ti use the wiring agin, avoid making the wires shorter...
YELLOW..12V+ DIRECT FROM BATTERY...can be joined where alpine yellow was conected.
RED...12V+ IGNITION WIRE..can be joined where alpine red was connected
BLACK 12-, NEGATIVE....BODY GROUNDING
ALL SPEAKER WIRES HAVE +AND-, PURPLE/PURPLE----------WHITE /WHITE-------GREEN/GREEN.......GRAY/GRAY..ALL THESE ARE SPEAKER WIRES, COMPARE THE CONNECTION OF ALPINE AND FOLLOW THE COLOUR FROM APLINE LUG AND JOIN THE PIONEER LUG ....THEY HAVE BAISC COLOUR WIRE AND AHVE SAME TYPE CONNECTION..DO IT
Oct 30, 2009 | Alpine CDA-9851 CD Player
Wiring diagram
Red: voltage source controlled by the ignition key Yellow: constant voltage source Black: ground Blue: power antenna activation wire (if equipped) Blue/white: amplifier activation wire (if equipped)
Jun 06, 2007 | Alpine TDA-7563 Cassette Player
Car Audio & Video Logo
150 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
