Question about Home
I was changing out the silicone calking in our shower and had a carpenter tell me I should calk the inside AND outside space between the glass and base on the 2 outside walls. Only the outside was calked previously. Now I have a leak on the outside near the wall - should I remove the caulking on the inside of the stall between the glass wall and the base, as before? Is this somehow what's causing my leak? I just can't seem to figure it out! Thanks! Barb
  • barbiel143 Mar 18, 2011
    Yes, that's exactly what I did. It's all brand new caulking with the old stuff removed and cleaned with rubbing alcohol thoroughly. I JUST need to know if with this particular model - MAAX ANSI Z124-95 Series - needs to be caulked on the OUTSIDE below the glass walls as well as on the INSIDE. I think it's not supposed to be caulked on the inside, but not sure. Thank you.
    Barb
  • 325 Answers
The best thing to do is to remove all calking before applying new. You must also have a clean, dry surface to apply the new calk. I would recommend scraping the old off completely and applying rubbing alcohol throughly. Then, allow it to dry completely before re-applying new calking. This will guarantee a good bond and no more leaks!
Thank you
Posted on Mar 17, 2011
  • Andrew P.
    Andrew P. Mar 18, 2011
    He was completely correct is telling you that both sides needed calked. If the outside only is calked you are creating a channel that will build pressure and leak. Both sides must be done. Much like roofing, you need to make sure there are no channels for water to build pressure otherwise you will have a leak in due time.
    Please rate if this helped :)
  • Andrew P.
Replaceing front bumper chrome trim
Put a couple lines of silicone calk on it and stick it on there
Aug 02, 2016 | 2007 Chrysler Pacifica
Oven door glass slid down, how to refit
take off stove then look around outer edge for screws .have laying flat when you do this on a good table .the door has 2 halves that clamshell together . a bit of silicone calk will help prevent it from happening again . put screws back and put door back on oven
Oct 08, 2015 | Ovens
My tub is plastered into the wall with caulking. Recently, I have noticed that the caulking is dissapating and loosening up the tub. Fortunately, I have not see a change in my water flow. I want to
Unfortunately this is usually caused by a leak and the drywall is wet , and or the tub is sinking due to water damage to floor. If the drywall is solid then use a utility knife to remove old caulk, then after area is clean apply silicone caulk around the tub. apply neatly but with plenty enough to fill the void. I then spray a dish soap an water mixture on the calk then remove excess by pressing thumb down and sliding it long caulking. This presses it into the gap and also removes excess, which leaves you a neatly caulked tub.
Jan 23, 2015 | Pfister Tub and Shower Repair Kit SK0275
Ow do I fix leaking door on Danby countertop dishwasher?
Either replace gasket or calk it with clear silicon.
Sep 14, 2014 | Danby Dishwashers
Glass shower leaking into wall, can't figure out how.
Hi dont know about shower,but think it would not hurt to take one screw out at a time and and squeeze a little water proof silicone in the screw holes then put the screws back in,and putting the silicone down the joint proberly would work but you would need to use a good anty mould silicone sealent(but if possible would be better to take the joint apart and seal it if posible,hope this was some help.
Mar 02, 2017 | Home
My air condition is leaking over the floor
THERE MIGHT BE A CRACK IN THE BUCKET, O PIECE OF TAP ON THE INSIDE OF THE WELL DRIED BUCKET CAN BE A QUICK FIX.. USE A SILICONE CALK TO DO A PERMANENT REPAIR .. ALSO MAKE SURE THE UNIT IS LEVEL..
jay the pool pump motor repair guy longwood Florida
Aug 01, 2011 | Windchaser PACR10 Portable Air Conditioner
Shower stall in master bath of a 15 yr old home. the shower started having water problems after about 1 year, leaking water onto the drywall next to the stall. we have tried everything-recalking, sealing...
Did you use plastic pipe? What about the shower head? Does it have a rubber o-ring in it? Pull the pipe out of the wall at the shower head and peek inside for the o-ring. If it is there, just snug up the pipe, do not over tighten. We were ready with crow bars in hand to destroy a brand new shower we just finished, because we thought we had w broken pipe, Then the owner says he torqued up the shower head as tight as he could and I read where it had to be just finger tight. One more place to check is the faucet itself, take off the trim ring and look in there for drips. It could be filling up the wall cavity and stay wet for days. I would take apart the drywall on the other side before busting up the tile again. Check it out.
Apr 24, 2010 | Kohler Home
Shower leak is it possible from Moen diverter to shower head
Check around the the front of shower and make sure there is no place that water can seep thru such as old calk and or loose tile and around fixture molding
May 28, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
