Question about Gestetner DSm645 Digital Imaging System
Erorr cod sc542 for gestetnar 4502 - Gestetner DSm645 Digital Imaging System
  • 263 Answers
There is several post here that you could see. But i will post again the solution.
You have a bad reading of the temperature of the fuser unit.
You need to reset the code.
For that try this:
Press yellow key
On the key pad press 1-0-7
Old down the red key at least 3 sec.
Enter the service mode. For that on the touch screen press "copy SP".
Exit all the way out.
Turn the machine off/on.
If you already did that and doesn't work probably you have a thermistor or a thermostat broken.
If you do not have technical training i advise you to call your provider.
Hope that help.
If you have any question reply to me.
See you
Posted on Mar 17, 2011
HP Envy 4502 here at the house. Wireless icon is on, I go to printable......it tries to connect a connection error, stating it can't connect to the server
(answer 1)you suck.! your ignorance, does.!!!richie46
HP has great help forum. (ask, fixya is the suck form)
ask for where HP is, its not here, but vast resources do exist.
learn to use them..
not blame them for not answering 1,000,000 calls a day. (vast installed base if you learn that, you'd go OMG really)
OP
i guess this is a printer only problem.?
right?
and no service tags posted on both PC and printer
No PC stated
the
HP Envy 4502(all in one)printer I have the J4580 , use it only for scans, i hate injets. laser are my bag,
the first step is install the driver
DRIVERS
http://support.hp.com/us-en/drivers/selfservice/HP-ENVY-4500-e-All-in-One-Printer-series/5304875/model/5368521
real forum
here it is , see it? ask there,
even read 10000 of others with same problems
most are simple. but
no PC stated, nor what Opereating system it runs.,
pc example what is YOURS.
use the USB cable to print
if you dont you get to learn now to get the printer
to connect to your unstated wireless router, that I refuse to teach here, ever.(set it to a static IP for the printer , lean how)
Mar 21, 2017 | HP Computers & Internet
Canon ir 2202 erorr cod e002-0000
see if this link helps
http://www.fortwayneprinterrepair.com/wordpress/2014/08/12/canon-ir-2200-2800-reset-fuser-error/
Mar 15, 2016 | Canon Office Equipment & Supplies
Erorr cod c 610
This indicates that you may have a problem with the Dimm or the main board.A technician may be required to correct the problem
Apr 14, 2013 | Kyocera Mita Office Equipment & Supplies
I can't using my canon MP510 because i am cod erorr 5000.help me
I see the service manual the 5000 eror is not exist,sure is not error 5100 or 5C00 ?
Apr 05, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Sc542 error for gestetner 4502
error 4502
http://support.microsoft.com/kb/258442
Instead, this error occurs: The problem does not occur when you add a column to the ... Server: Msg 4502, Level 16, State 1, Procedure myview, Line 1 View 'myview' has more ...
http://support.microsoft.com/kb/958876
file is deleted from the replication partners, and event 4412 and event 4502 are ... it tries to update these files after the service receives an ERROR_DISK_FULL error.
hope this helps
Mar 17, 2011 | Computers & Internet
E000821-0002 ERORR WHY R U COM THE COD OF CANON IR5570
these means that copier is detected too much waste toner in cleaning blade assy.
Book says:
Clogging of toner inside the cleaner has been
detected with reference to an abnormal rise in the
cleaner thermistor.
Try to:
- Remove the waste toner from inside the cleaner.
- Replace the air filter of the heat discharge fan.
and I would also recomend to check waste toner stiring "snail" and waste toner container.
Hope that helps!
For service manual you can contact me on emma.servis@gmail.com
Sep 07, 2010 | Canon imageRUNNER 5570 Copier
Wats the installation code for lego creator harry
try one of these
1226-1794873-5023307-3430
or
7445-9949854-4397352-3219
or
4502-5657520-5300784-1712
or
Mar 17, 2009 | Video Game Consoles & Games
Alltel snap
If you haven't set a password already, the default password should be the last four digits of your phone number. For instance, if your phone number is 512-4502, the key code would be 4502.
Jan 13, 2008 | Lands Phones
Gestetner DSm645 Digital Imaging System Logo
281 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
ap-it
ap-it
jmartin50
Level 1 Expert
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
