Question about Dell Latitude C640 Notebook
Charger is ok but laptop is no charging - Dell Latitude C640 Notebook
    Sergeant:
    Champion:
  • 210 Answers
Try taking out the battery and putting it back... if that does not resolve the issue... a very good solution is to contact dell.... :)
all the best
Posted on Mar 17, 2011
  • 784 Answers
Charging chip is faulty
Lattitude e5520 wouldn't charge
Ted try this once more:
1. turn off the machine.
2. keep pressing the off switch a little longer 3. remove the battery.
4. press the off button for say 15 seconds.
5. re-install battery after a few minutes.
6. connect charger to computer and see if it shows % charge.
7. when it shows 100%disconnect charger and see if the battery still shows 100% If it does you are now reset. IF not,will cross the bridge then.
Jan 24, 2014 | Dell Latitude E5520 Laptop Computer PC...
Dell latitude D420 wont charge when plugged in
If the laptop works without the battery, just the charger, the charger is OK.
Jan 13, 2014 | Dell Latitude D420 (DELLD420) PC Notebook
Compaq 510
I think you should check the charger. If your charger is ok and battery is ok, then you should go to Compaq showroom and also must be checked that what problem in your Laptop. Why your PC don't charge?
Aug 16, 2013 | Computers & Internet
Battery not charging
Is it a replacement battery ,you purchased, with the EXACT same specs? Some aftermarket inexpensive batteries do not work well with your laptop. How do you know it's not charging, by the Icon in the Tray Notification Area? Again sometimes aftermarket batteries don't have the ability to communicate with the software. The pin-outs are not the same.
Dec 09, 2012 | Computers & Internet
Aspire 5935 G plugged in not charging 0% aviable
If you are sure the charger is OK, then the possible cause could be the battery or the power jack.Take the battery out, and plug in the charger, if your laptop works, then the power jack is OK, you need to replace the battery; If not, then it proves the power jack is broken, it need to be resoldered or placed. Or you could directly test your battery with a digital multimeter.
Mar 31, 2012 | Computers & Internet
Computer wont charge with universal charger
Please check the technical specifications of your computer charger and see that your universal charger fulfills the same. Generally it is found that the universal charge may supply the required voltage but may not provide the required amperage. That is the reason most of the electronic companies insist on their chargers. If your charger is not working please get one from the company rather than using the universal charger and the spoiling your computer. Universal chargers are OK for some of the electronic devices which do not require higher currents.
Dec 27, 2010 | Dell Inspiron 1525 Laptop
My Acer Aspire 5600 has periodic charging problem. Will charge up OK when switched off. When switched on, after a while the battery indicator changes from green to amber and then starts flashing. Then the...
I guess your charger has very low power (low wattage). That is why it charges the battery when the laptop is off. But as soon as the laptop is on, the charger can't keep up with the power dreained by keeping the laptop on and eventually the battery runs outr of juice.
According to the user's manual (http://support.acer.com/acerpanam/manuals/acer/0000/userguides/AS5600_3680_UG.pdf)
I suggest you get a charger with at least 90 W.
Mar 25, 2010 | Acer Aspire 5600 Series 5610-2013 Notebook
Charger light flashes when plugged into laptop , stays on solid when unplugged,had charger checked 19v ok ,had socket checked 19v ok ,then checked to first board 19v ok ?? has a board gone down ??? annoyin...
your battery pack is causing your problem rule #1 never!! leave the charger in!! everytime you start up!! run off the batteries till the power low light come's on then apply the charger constant charging causes early failure of all/ any nican battery pack
Jan 13, 2010 | Acer Aspire 5920-6335 Laptop
I have a compac lap top and when i plug in the wall charger nothing happens it wont charge
check to see if you can hear a hum from the charger it self , push the box hard againts ear if its humbing charger is ok, if you cant hear anything from it check fuse to plug. if this is ok then charger is broken.
If charger is ok check the conection into the laptop if it feels loose and when u move it slightly it goes on and off then possible conection to laptop prob.
If this conection is ok and the charger is humbing and working, could be a possible internal switch gone in the laptop that decides to charge and not charge when battery is full. These are always failling on laptops but hopfully its not this.
If you find the charger is broken search ebay for a new or secound hand one, aint to expensive. hope this helps
Nov 28, 2009 | Compaq Computers & Internet
Was it charging ok before the damage occured?
Oct 22, 2007 | HP Pavilion zd8000 Notebook
Dell Latitude C640 Notebook Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
