Question about Ricoh Aficio 1232C Color Copier
Hello - I work through a sea RICOH C. 2500. I have no user manual AND I HAVE A PAPER JAM. I do not understand the keyboard operation (they appear on the screen) and I would like to know how to fix this problem _ Thanks for your reply ..... clara
  • 263 Answers
Hello Clara!
What do you don't understand about the operation panel??
It gives you like step to step.
On the right corner of the display shows you a wizard that you can press next-next-next.
Posted on Mar 17, 2011
  • clara438 Mar 20, 2011
    I have the manual with images and written explanation for the jam MERCI
Paper jam sign appears after first copy
if jam indicated but no paper is found. clean the roller that feeds paper out of the paper tray.also make sure paper guides are touching paper front rear and left side.
Feb 23, 2014 | Ricoh FT5832 Copier
Paper jam c
Unable to print troubleshooting and routine maintanance chapter in user's guide
Mar 23, 2013 | Ricoh Aficio SP-C210SF Printer
Hello, I have a Ricoh 1160L Fax machine and I
my fax is ricoh1160L.This fax always one fault 'CRU fuse error'show the display
Jul 20, 2011 | Ricoh FAX1160L Plain Paper Laser Fax
The Ricoh Alicio SP C410dn says to open the A tabs and remove the paper jam. There is no paper jammed into the machine. The issue only arises when printing from the manual feeder and not from the paper...
You must first try to clean the paper feed roller which you will inside of the printer (bottom) when you pull out the paper tray. If this not works, then I am 100 % sure that the magnetic clutch which operates this feed roller must be replaced. I can tell you the part number for ricoh part catalog:
GX20-0014. If you don't have tech skills please don't do it by yourself because it's a hard and precision work. Call for help tech support
pifonski
Feb 25, 2011 | Ricoh Envelope Feeder Type 610 Feeder Tray...
It says there is a document jam and i can not see a jam anywhere
check the user manual for instructions on unjamming your fax. if you don't have the manual you can get it from the internet. jaime
Feb 16, 2011 | Ricoh FAX2210L Plain Paper Laser
Paper jam
Please try to check your printer spooler which is responsible in spooling the paper and also the feeder. Check it to ensure and examine if the said components are still functioning or in good condition and still 100% - 90% Operational. If you find it that it does not operate properly then please find a technician or a computer shop that specializes the printer and let them fix the problem and replace the defective components.
Also try to see the paper you insert if it is the prescribe one or not. Please follow the prescribe or recommended paper to be used.
Thanks
Aug 13, 2009 | Ricoh Aficio 1015 All-In-One Laser Printer
Paper jam in tray 1 is so deep I can't reach it. Can I remove the tray to get to the jam?
Yes you can remove the tray. Just make sure you put everything back in its place.
Jun 10, 2009 | Konica Minolta bizhub C250 All-In-One...
I have a aficio bp 20 series pcl 6 printer its failing to print.
Is it only the 'red' light or is there another one also lit?
If it is on steadily, it should be related to a paper jam, if blinking, then related to Data in, and no paper.
Manual is here to check what the status lights mean (copy this link into your address bar):
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/bp20n/bp20nen.htm
** info is on page 6.21
Feb 18, 2009 | Ricoh Aficio BP20 Laser Printer
Paper pick-up for by-pass tray won't work
OPEN BACK AND LOOK FOR A SMALL PIECE OF PAPER FROM PRINT JOBS PAST THAT MAY HAVE JAMMED ...FOLLOW THE PAPER PRINT TRAIL, CHANCES ARE YOU WILL FIND SOMTHING BLOCKING THE PATHWAY!
Dec 07, 2008 | Ricoh Aficio SP C410DN Laser Printer
Paper Jam
Hello vidalia
(01) You can find support and downloads for your Canon Pixma MP780 AIO (all-in-one) HERE.
(02) You can find Canon's support and services for this device HERE.
(03) You can find drivers and manuals for it HERE.
(Select your computer's operating system under Drivers/Software selection and the appropriate downloads will appear)
(04) For instructions on clearing a paper jam, download the USER'S GUIDE (it might take a little bit. It's pretty extensive).
(05) Then double-click on the file name: (depending upon the operating system you selected, it will be something like: PIXMA_MP780_750_UG_WIN_EN.EXE)
The file will extract to a folder (in the same location w/ the same name as the file)
(06) Double-click on the folder.
(07) Double click on the file named "TOP" or "TOP.htm"
This will open the USER'S GUIDE for you.
(08) Now, in the left column, click on TROUBLESHOOTING
(09) Then click on the link immediately below TROUBLESHOOTING called "Paper is Jammed"
(10) Follow the instructions provided for clearing a paper jam.
Please, let us know if you have any questions at all, etc. We'll continue to work w/ you on this problem until it is resolved.
Thank you
BJ @:)
If the information I provided enabled you to resolve your problem, kindly take a moment to rate my solution w/ a "FixYa" :)
Apr 16, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Ricoh Aficio 1232C Color Copier Logo
82 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
