Hello,i cant find any server profile for my n95 so i can update my firmware using wi fi,please help
  • 368 Answers
Glad to HELP YOU!
I found THIS and THIS for you! I think it might help.
GOOD LUCK!
Posted on Mar 17, 2011
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Tip
REMOVE UNWANTED WORDS FROM PREDICTIVE TEXT Using this trick you can remove...
Using this trick you can remove sometimes irritating and unwanted words from predictive text. Open xplore or a similar file manager, go to c:\predic\ directory and delete the .dat file or edit it by transfering it to pc, opening it with notepad and editing.
NOW SEE THEME ICONS N95
In the new firmware on N95 v20 & v21 & also N95 8GB Nokia has removed the theme icons in the menu, but by using this trick, you will be able to see the theme icons.
To do this go to Menu-> Tools Folder-> Utilities Folder-> Device Manager.
Here you will see your firmware version and device updated. press D-Pad right button and you'll see no server profiles defined. Press options and select New server profile, and name the server 'name', server id, host adress and user name 'Themes'. Choose your password and leave everything as it is. exit (if it says profile not saved because you didin't do some configurations, try changing connection type to bluetooth) and press Options and start configurations without connection. then go to Menu-> Applcations and you'll see the themes icon!
Credits to DoucheBag66.
on May 09, 2010 | Cell Phones
I need to update the firmware for my photo cube wi fi printer
This will be available to download from the manufacturer's website
Feb 17, 2014 | VuPoint Solutions Photo Cube Wi-Fi Compact...
Sony Xperia ION LT28h does not reconnect to Wi-fi
Oh dear it is really a big problem and it seems all devices of this type have the same problem . Please help us to get out of this problem
Jun 20, 2013 | Sony Ericsson XPERIA ION LT28H BLACK HSPA...
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
Why i cant open the games on my pspslim 2000 version 5.50?
You may need to clean the laser if its the disc, if it's the memory stick then you might want to update you firmware through wi-fi.
Apr 12, 2010 | Sony PlayStation Portable (PSP) Slim...
Nokia n95 keypad light is not working...
hello..
the problem is the water damage mate... cut your loses and get a new one.. spending any money on this will be a waste..
Nov 29, 2008 | Nokia N95 Cellular Phone
Wi-fi
try to download the most recient firmware from sony.
the manually put the folder name update on
X is you drive letter
X:/psp/game/update
Aug 27, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
