Question about DeLonghi ® Combi CoffeeEspresso Maker
I have a DeLonghi Coffee/Espresso machine. It leaks profusely out of the bottom. Originally it was not brewing and we sent it back. They fixed the not brewing problem (I'm assuming it was a fuse) but now it leaks from the bottom. Any suggestions
    Genius:
  • 1,157 Answers
Hi Kavogel,
Leaks sometimes caused by a detached drain tube or the tub does not drain. There are some ways on how to correct the problem, either you check the sewer drain and restore the connection of the drain tube or the tub. In addition, please follow the steps below on how to determine the cause.
1. Check the tub if it's not drained. Please check the sewer drain.
2. Please check the drain tube if is detached, broken or has obstruction to water flow.
--> to fix it, just restore the connection of the drain tube or tub.
3. It might be a a hydraulic leak in the hydraulic circuit, so you need to identify and eliminate hydraulic leaks.
4. Check the O-ring or poor mechanical seal of the shaft.
--> check also the status of the pump.
5. The inlet and outlet connections are loose. Please tighten the connections.
6. Check if the hex nut of the pressure relief valve or of the filter are loose. Tighten them.
7. The gasket or the O-ring of the pressure relief valve or of the filter are defective. You need to replace the gasket and the O-ring.
--> Please make sure not to change the calibration of the valve.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 17, 2011
Internal water pipes leaking on my Delonghi magnifica. Where can I buy the pipes? Will I be able to replace the pipes myself?
DeLonghi Magnifica water leak problem - YouTube
? 2:37
https://www.youtube.com/watch?v=_mNGPs79ajY
Feb 5, 2011 - Uploaded by shellway2005
My DeLonghi Magnifica ESAM3300 is not making shots. Wateris instead coming out of the front bottom via a ...Missing: pipes
DeLonghi Magnifica leaking water pipe Questions ... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > DeLonghi
DeLonghi Magnifica coffee makers & espresso machines leaking water pipe related questions and answers. ... Delonghi Magnifica My steam arm drips when I make coffee. ... Not sure if water is leaking from water tank or internal water line.
DeLonghi Magnifica leaking water Questions & Answers ...
Order DeLonghi Parts‎
www.ereplacementparts.com/DeLonghiadvertiser rating
Buy DeLonghi Parts.
Fastest Shipping - Low Prices.
Jan 07, 2016 | DeLonghi Coffee Makers & Espresso Machines
My Espresso Machine leaks out the bottom
thier is a puddle of water that leaks out of the bottom of machine after i brew my expresso
Dec 29, 2012 | Mr. Coffee ECMP40 Espresso Machine
Delonghi bco320 t will not brew coffee
The heater element for the coffee brewing side is defective.
Jul 09, 2012 | Coffee Makers & Espresso Machines
It leaks like a sieve every time you brew coffee!
I found that ours would leak if the accuflavor knob is turned to much toward "strong"
I moved it to half way between strong and weak and it does not leak anymore.
UPDATE 1/2/16: Ours started leaking again and turning the AccuFlavor knob had no effect. However, when I PULLED UP on the lever (towards the ceiling), the leaking stopped and has remained stopped, no matter what setting the lever is turned to.
Apr 20, 2011 | DeLonghi Caffe Nabucco BCO70...
Water is leaking out the bottom while brewing coffee
It could be a problem with the hoses and valves on the inside. When the heating element gets hot it pulls water from the reservoir through the valves. The issue with this is the limited availability of parts for this particular machine.
Sep 15, 2010 | DeLonghi Caffe Nabucco BCO70...
DeLonghi Magnifica There is water leaking from the water reservoir area of the machine. After extensive testing it is not the reservoir. The water is leaking from inside the machine. We took the machine to...
This is a bit late, but it is probably the rings inside the machine. I sent mine to the repair shop in San Francisco and it was about $120 to fix. It works GREAT now. Coffee is back to like new.
Dec 06, 2009 | DeLonghi Coffee Makers & Espresso Machines
Water leaks from bottom of Saeco Caffe Charisma when brewing
Remove brew chamber, check the back of the white plastic valve make sure the chamber under it is clear of coffee grounds and water, then check the red o-ring on the brew chamber make sure there are no cracks or damaged spots.
Jul 15, 2009 | Saeco Caffe Charisma Espresso Machine
Cafe verona delonghi
You need to turn the knob on top to the steam logo. then turn the knob on the side to open the steam valve. then when you get all the steam you need turn the knob back to brewing
Sep 11, 2007 | DeLonghi Caffe Nabucco BCO70...
DeLonghi ® Combi CoffeeEspresso Maker Logo
126 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
