Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Convergence Board I was wondering if anyone can tell me how to check out the convergence board to see what is burned out. appreciate any help.
  • JVC Master
  • 8,617 Answers
Theres a kit at the following link to repair the convergence circuit for your model at the following link and they have free tech support to help you with it.
http://servicemanuals.vstore.ca/
Posted on Aug 04, 2008
When adjusting the convergence, ended up with a concave screen, then it smoked. Is this a power supply, or worse? Is there any advice that you could give me on this...
Thats usually indicating the ICs have failed. Usually with that model its best to replace the board rather than try replacing the individual components as ther are several 3.9 ohm resistors that will need to be checked and possibly replaced along with both ICs. www.tvcircuitboards.com should have the replacement board for your model if you need one.
Jul 08, 2011 | Samsung HCL473W 47" Rear Projection...
Samsung SP43J5HF Rear Projection Tv
Hi Daml
You can find this part from Samsung UK , click HERE to check it out and also to order it. Delivery is within 7 days.
Could unfortunately not find anything for Australia.
Let me know if you need any further assistance.
Thanks for using Fixya !
Apr 30, 2008 | Televison & Video
Need Circuit Diagram, or convergence resistor list for PT51D31CE
they are 2.2 ohm , i have replece many of this before
Apr 19, 2010 | Panasonic PT-51D31 TV
Sony KP-65WV600 Convergence AD Board
It should be a 4.7 OHM if its under the heatsink near the convergence chips.
You can do the repair yourself using the following instructions.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 22, 2009 | Sony KP-65WV600 65" Rear Projection...
Sony KP 51WS510 convergence problem
Please check pico fuses in D board and confirm +22 & -22 volt supply to convergence ICs.
Fuse numbers are as follows...
PS8001, PS8002, PS8003, PS8004, PS8005, PS8006
Dec 21, 2008 | Sony KP-51WS510 51" Rear Projection...
Samsung TV model HCN5527W
The actual Convergence amp ICs not located on the convergence board are probaly what killed the origional convergence module, and likewise has killed the new board. You will need to change the convergence ICs first then replace the convergence module.
I would recommend getting the service manual . I can post a link if you would like.
Mar 17, 2008 | Televison & Video
AUSTRALIAN PARTS
the convergence board has nothing to do with tuning of tv, the convergence board put three colour gun (red, green, blue) to work with each other, else you get three image, of red , green,  blue or mixture of all as seperate image, the convergence board for american tv and Australian tv is possibly the same what you check to see the board  part number is the same you possibly need to see if the convergence board has got the memory i.c. if that is the case, you need to tune you t.v reset the channel etc good luck.
need more help let me know.
Oct 09, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Need akai pt4799hd setup code
Do NOT attempt to enter the service mode to align convergence if you cannot align the convergence with the user's menu. If the convergence cannot be corrected with the user's menu, it means that one of your convergence IC's has burned out and possibly burned out the fuse next to it. If you change any settings without first replacing the bad parts, you will only make things much worse. I believe that set is actually a Samsung, and has the 2 convergence IC's on their own board mounted above the small signal board. If you do not know how to identify and replace shorted convergence IC's, allow a qualified tech to handle it for you.
Sep 03, 2007 | Akai PT4799HD Rear Projection Television
VERTICAL PINCUSHION (NORTH & SOUTH PART OF SCREEN)
DUDE!!! Both manuals are available at http://www.servicemanuals.net/ I dont know where you tryed before to get a manual for these sets but both modela are available online at like 20 differant spots.. This one site is the one I trust the most, as they have 99% of any manual I have ever Needed. Good Luck
Aug 08, 2006 | Pioneer PRO-200 60" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
35 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
