Question about XM Radio (XMP6000)
Fix Roady xt
My roady is not working. One night we had a storm, it was plugged into a radio. The next day it didn't work. Can this repaired, or should I throw it away?
Stephanie
  • 53 Answers
The unit is shot it suffered a power surge and will no longer work
Posted on Sep 24, 2008
How to repair antenna connection on delphi roady
Copper czge? You mean the plug that goes into the base unit? Or just the antenna connection on the roady?
May 17, 2014 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT. Changes channels by itself. Can I fix that?
Try a new wall plug/adapter. You need the 5V adapter from Belkin. Worked like a charm for me--after suffering with this problem for a week....only cost $10.
Jan 08, 2010 | Delphi Roady XT XM Radio Receiver
When I press the power button the screen flashes once & then goes blank again. Some times I see a quick flash of "XM-Radio" This started happening overnight one night-nochanges on our part.
I had exactly the same problem with my Roady XT. The power supply gradually failed, with the symptom that the reception kept getting weaker and more spotty. Finally, the Roady would not turn on. The screen flashed as you describe. I happened to have another 5VDC, 2A power supply in the closet from some other electronic gismo from the past (I save the power supplies just in case). the connector on the old power supply was not correct for the Roady XT, but a little surgery put the new plug on the old supply... (verified by a volt meter). When I plugged it in the Roady quickly turned on and showed full signal strength. This had never happened in 2 years of use. Apparently this radio needs more power than the stock power supply can provide. Now it "loads" stations in 2-3 seconds and never fades.
Jul 12, 2009 | Delphi Roady XT XM Radio Receiver
Connection
If it has a radio get a fm transmitter you just plug it into the roady headphone jack, You can find them about every where they make them for iPods but they work work these way too. there about 20 to 25 dollars on the net
Feb 02, 2009 | Delphi Roady XT XM Radio Receiver
Can't get Roady XT to turn on. Previously wouldn't load signal.
there is a bad connection on the voltage input on the radio. look in the hole you will see a copper contact if it wore, you will see a hole in it, you needed to bend it towards the center contact just a little bit. then try it again I worked on mine
Dec 26, 2008 | Delphi Roady XT XM Radio Receiver
"Antenna" Appears on Roady XT Display
I had the same problem, it says antenna when you turn it on. It seems that there is a small wire that stays in the radio side of the socket right in the middle of the socket. This fine wire breaks off . I think there is no known repair for this. I took a piece of fine wire from a wire brush, and poked it into the socket . Had to get one that was thick enough to stay. Then I plugged the antenna into it, it worked.
Nov 23, 2007 | Delphi Roady XT XM Radio Receiver
URGENT Belkin F5X007*****Please Read!!!******
same thing happened to me and I had to take the radio back to Walmart...
Jul 22, 2007 | Belkin F5X007 XM Radio Receiver
BelkBF5X007in XM radio boom box
Check your Conns both on Radio and docking Bay make sure Nothing Got on them .Clean them with alchol and Swab Good luck ttech
Jul 20, 2007 | Belkin F5X007 XM Radio Receiver
Roady XT periodic errors
The pins get easily damaged when switching from the car dock to the Belkin boom box. I have to constintly squeeze very ******* the top of the xt in order for it to make contact. Belkin will send you a plastic alignment fixture but it is too late. It still does the same thing.
Jun 18, 2007 | Delphi Roady XT XM Radio Receiver
Car Audio & Video Logo
106 people viewed this question
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
Electro Med Services...
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
